Question about GE Spacemaker JVM1540 Microwave Oven
Re JVM1540 DN 1BB: Less than 1 year old; getting message of "possible keypad short. Keypad will not work at all. This problem may have occurred after cleaning the microwave. Please advise.
5 Suggested Answers
Richie_asg1
  • 1036 Answers
SOURCE: GE JVM1540 keypad only works for some buttons
Membrane keypads are not very durable, and do fail after a relatively short time.
The only method is to replace them as a spare part.
Posted on Aug 20, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: keypad not working after boiling water below
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
Otherwise, the keypad may be damaged or worn out, or control unit may be damaged.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
Your full model number would be one of these: JVM1540DM1BB JVM1540DM1CC JVM1540DM1WW JVM1540LM1CS JVM1540SM1SS
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 10, 2010
  • 512 Answers
SOURCE: I have a two year old GE JVM1540 Over the oven
These units are known for this problem. You cook on stove and stream gets into keypad causing keypad not to respond anymore. The good news is keypad can be replaced, the bad news is it will happen again and the keypad costs around $125. GE will not admit to any problem, but I see this problem alot. You can get a new keypad at appliancepartspros.com
Posted on Aug 27, 2010
  • 93 Answers
SOURCE: Microwave keypad shorted
looks like your buying a board unfortunately not worth the repair get a new microwave boards cost way to much
Posted on Nov 15, 2011
How do I remove the keypad on JVM1540?
Remove the air grill first. Should be a couple of screws. Then you will see one screw holding the keypad in on top. Take it out and it will tilt forward. Make sure you unplug any power source first before you try removing any screws. Once you have the keypad leaning forward there will be some connectors holding the keypad in. Unplug those and lift the keypad up and out.
May 13, 2014 | GE JVM1650 1000 Watts Microwave Oven
Microwave stopped working
The main fuse in the microwave is probably open, causes are! door switch, magnetron, inverter board, "if 7 years old or less" and possibly the keypad control board. I recommend having it checked out.
May 08, 2012 | Samsung Microwave Ovens
The glass turntable broke. Where can I find a replacement?
Go to www.ebay.com Type: make and model of microwave, and refine search to glass plate.
Apr 02, 2012 | GE Spacemaker JVM1540 Microwave Oven
We have a GE JVM1540 space saver microwave. It is less than a year old. Will not heat and immediately starts smelling like burning plastic. Any ideas as to what is causing that?
CHECK THE MICROWAVE MANUAL LOOK FOR FACTORY WARRANTY ,MUST BE A BAD COMPONENT ,IF YOU MICROWAVE IS UNDER 1 YEAR WARRANTY THE FACTORY WILL REPAIR IT AT NOT COST TO YOU..CONTACT GE FACTORY.
Feb 18, 2011 | GE Spacemaker JVM1540 Microwave Oven
I have a two year old GE JVM1540 Over the oven microwave. For some reason the keypad does not respond to any touch. It just has the display panel scrolls press start but doesn't allow any action.
Aug 27, 2010 | GE Microwave Ovens
GE spacemaker HVM1540DNWW. After I cleaned touchscreen the buttons don't work anymore. i unplugged it for a while, still only get "press clock" message
Take a hair dryer in low / no heat setting or a plain old fan and let it blow on the keypad for a while. Do not let the key pad get overly warm. You got a bit of moisture in the pad membrane and the goal here is to evaporate the moisture. It may take longer than you think to evaporate the moisture. If you let the moisture stay in the membrane too long it will cause corrosion and the key pad will NOT be usable.
Apr 22, 2010 | GE Spacemaker JVM1540 Microwave Oven
My keypad is also dead.
No, but as with all electronic items faulty ones typically show themselves up during the first few months of use.
You've probably just been one of the unlucky ones.
Sep 08, 2009 | GE Spacemaker JVM1540 Microwave Oven
Aug 20, 2009 | GE Spacemaker JVM1540 Microwave Oven
GE Spacemaker JVM1540 Microwave Oven Logo
62 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
