Question about Sony Playstation 3 (PS3) Console
PS3 has YLOD. It's a 40gb model, 2 yrs. old. I pulled it apart, used a heat gun to reheat the CPU and GPU. I put it back together and it worked for a few days. Then YLOD again. Tried the fix a second time, only it's still dead. What are my options?
    Scholar:
  • 100 Answers
I've done this successfully using a method close to actually Sony's from what I've been told. First take your time on unassembling and assembling the parts as most owners attempting this have broken other things while handling it. When you strip the motherboard bare with no cables attached. Heat in the oven for 7 minutes on about 410 degrees. Its best to put it on a flat pan first. Then, let it cool for awhile and heat for another 4 minutes. Stay close to the oven and you will smell the motherboard melting a bit(if it starts smoking turn it off immediately and turn the fans on) Let it cool overnight because if you handle it while it's still hot, you will break connections on other parts of the motherboard. I've fixed mine 3 months ago and also got a 120 slim version as a gift (still unopened lol because I fixed my old). And the old one is still working. Another important thing you should do on your fixed or next ps3 is to go to settings and turn on the "automatic shutoff when inactive for an hour" feature. Hope this helps!
FYI Using heatguns don't last a long time, mine is going 3months +
Posted on Dec 03, 2010
  • Abcd Dec 03, 2010
    Oh also get a thermal compound called arctic silver and reapply to the 2 chips with a credit card or something flat. Take the old compound off carefully with an approved solvent, (I used my nails to scratch it off).
PS3 yellow lite of death
What is your question about the YLOD? Typically, it happens for different reasons. Check your A/V connections. If they are not connected, you'll get the YLOD. 2, it has over heated, and has to be taken apart, heated by a heatgun to reform the solder, then new heat gel put on between the board and the cpu/gpu. Pretty easy really. Here is a youtube vid to get you started.
PS3 PlayStation 3 YLOD Repair the proper way to reflow your board
Feb 08, 2014 | Sony Playstation 3 (PS3) Console
After playing a disc for a few minutes, my Ps3 starts making a noise --constant low whirring sound as if the fan is on overdrive. Any idea as to what might be causing it?
if you have any of these gb consoles these are the first ps3s 20gb 40gb 60gb 80gb.okay these consoles are all dying.see when sony made these they did lead free solders for the cpu and gpu and they used crappy thermal paste on these processors.so now when your ps3 gets to hot or just old it heats up so bad that these solders melt and cpu or gpu come off motherboard its called ylod ur ps3 is in the process of going down at this point u can do nothing for it its pretty much done.u could try replacing thermal paste it may help but i think the damage is to far along to repair if u have the new models like the 160gb slim or 250gb or 320gb then i wouldnt worry about it.
Apr 17, 2013 | Sony Playstation 3 (PS3) Console
MY PS3 LED LIGHT WILL GO GREEN TO YELLOW AND JUST KEEP FLASHING BOTH COLRS
http://www.youtube.com/user/gilksy1 guide found here
PS3 MoBo Reflow Guide
This will only fix certain motherboard issues. This fix will solve YLOD issues cased by the system getting so hot the CPU / GPU or direct chipsets get shifted. This fix uses a heat gun to heat up the CPU / GPU and direct chipsets and allows them to fall back in place.
I used a standard heat gun (dual, High, Low settings). Check the temp on it though. You want it around 700-750 degrees Fahrenheit.
Some Additional Tips Not In The Guide:
If you have worked on PCs this shouldn't be that hard. If you have worked on Notebooks, you shouldn't find the PS3 to be very difficult at all. Most notebook chassis are far more tedious then the PS3's.
DOWNLOAD THE GILKSY GUIDE!!!! Read the guide a couple of times. Note the manner in which the PS3 is sitting in each photo.
Have the guide open on your notebook or PC as you work. Otherwise print it out.
Make sure you have enough time to take it apart and put it back together. It will take about an hour maybe an hour and a half. You don't want to take it apart then try to put it back together the next morning.
Make sure you have a clean work area. With PLENTY OF LIGHT, I used my kitchen counter.
Have places to sit parts out of the way.
Have the right tools, you don't want to strip every screw.
Get a ground strap in addition to the tools outlined.
Have several containers to keep the screws in, one for each level of "disassembly" is what I used.
Careful getting the first rubber foot off, I trashed mine.
Keep track of where the coarse threaded vs. fine threaded screws come from. The coarse threaded screws generally screw directly into the plastic chassis.
Clean the pieces as you disassemble the PS3, a vacuum with a hose attachment and canned air work great. Stubborn dust bunnies may require a paper towel dampened with alcohol.
Keep the work area clean as you work. Be careful not to vacuum any screws. This will insure no dust (or pet hair) get into the new thermal CPU compound which could severely effect it's performance.
When you get inside the system get a sniff of your power supply, if it smells burnt, this fix MAY not work.
A few minor steps are missing from the guide, but they are fairly easy to figure out.
Careful with the ribbon cables, each one has a clip to hold them on. Some release the opposite way of others.
Righty tighty, lefty loosey!
When assembling the PS3 make sure you have all the cables where they should be as you put it together. You don't want to have to take it back apart a bit to get a cable where it's supposed to be. Be sure ports meet the port-holes as they are supposed to. Over all everything should have a tight fit.
When you put the screws back in you just need to secure everything, you aren't entering a strongman contest. Over torquing these screws may result in a funny looking PS3.
Dec 08, 2011 | Sony PlayStation PS3 Slim 120GB Bundle...
I dropped my Ps3 on the ground & now it just has the YLOD. Is it completely broken or could it be fixed?
  • If you have worked on PCs this shouldn't be that hard. If you have worked on Notebooks, you shouldn't find the PS3 to be very difficult at all. Most notebook chassis are far more tedious then the PS3's.
  • DOWNLOAD THE GILKSY GUIDE!!!! Read the guide a couple of times. Note the manner in which the PS3 is sitting in each photo.
  • Have the guide open on your notebook or PC as you work. Otherwise print it out.
  • Make sure you have enough time to take it apart and put it back together. It will take about an hour maybe an hour and a half. You don't want to take it apart then try to put it back together the next morning.
  • Make sure you have a clean work area. With PLENTY OF LIGHT, I used my kitchen counter.
  • Have places to sit parts out of the way.
  • Have the right tools, you don't want to strip every screw.
  • Get a ground strap in addition to the tools outlined.
  • Have several containers to keep the screws in, one for each level of "disassembly" is what I used.
  • Careful getting the first rubber foot off, I trashed mine.
  • Keep track of where the coarse threaded vs. fine threaded screws come from. The coarse threaded screws generally screw directly into the plastic chassis.
  • Clean the pieces as you disassemble the PS3, a vacuum with a hose attachment and canned air work great. Stubborn dust bunnies may require a paper towel dampened with alcohol.
  • Keep the work area clean as you work. Be careful not to vacuum any screws. This will insure no dust (or pet hair) get into the new thermal CPU compound which could severely effect it's performance.
  • When you get inside the system get a sniff of your power supply, if it smells burnt, this fix MAY not work.
  • A few minor steps are missing from the guide, but they are fairly easy to figure out.
  • Careful with the ribbon cables, each one has a clip to hold them on. Some release the opposite way of others.
  • Righty tighty, lefty loosey!
  • When assembling the PS3 make sure you have all the cables where they should be as you put it together. You don't want to have to take it back apart a bit to get a cable where it's supposed to be. Be sure ports meet the port-holes as they are supposed to. Over all everything should have a tight fit.
  • When you put the screws back in you just need to secure everything, you aren't entering a strongman contest. Over torquing these screws may result in a funny looking PS3.
after following that there are 6 more parts to it ... (linked in the Description of that Video)
Mar 02, 2011 | Video Game Consoles & Games
Hi, when we turn on the PS3 the light goes green for no more than 2 seconds, flashes Yellow/orange and goes to red. Nothing comes on the screen. Where to from here? Lance
its call YLOD...just happen to me b4...u need to heat the 2 cpu n gpu with heat gun about 5mins with 400-500 degree..this procedure is to resolder the gpu/cpu.tQ
Oct 22, 2010 | Sony PlayStation 3 40GB System
I repaired my Dad's PS3 (YLOD) by heating up the CPU & GPU then putting some Artic Silver on the processors. It worked. So I decided I was going to buy someones broken (YLOD) PS3 for about $40 I did...
Ok first the heating up. You may find that the reflow did not quite get hot enough to melt the solder back onto the ball grid arrays enough. You could try another reflow and see if this works however every time you do a reflow you risk permanently damaging the CPU/GPU. The other thing you could try is bending the heat sink clamps a little to apply more pressure on the CPU/GPU but again this could cause more damage.
Secondly the display. If this reset sequence does not work then you have probably damaged the GPU in the reflow process :-
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Sep 06, 2010 | Sony Playstation 3 (PS3) Console
Ylod
The wonderful Yellow Light Of Death, if I am correct, is the PS3 has basically pulled the cpu/gpu off the motherboard and needs to be reheated to resit them on the board. If you are not tech savy, then you should consult your local repair shop.
Mar 28, 2010 | Sony Playstation 3 (PS3) Console
Hi ive just turned my ps3 on it stopped and went off now it wont play just got a red light when pushed it flashes green and blue the goes red when pushed again it flashes red help
Yes this is the YLOD the (Yellow light of death) it happens when the GPU and the CPU overheat and you will need to fix this by stopping the heat build up, you can sned it in and they will fix it for you for $130.
Or you can fix it yourself using a good PS3 Repair guide in under an hour!
Mar 07, 2010 | Sony Playstation 3 (PS3) Console
Have the same problem with my 40gb system after 2 years...
I fix ti!!!!, Use a heat gun over the cpu and gpu 15 seconds per section at 350° C, then replace the thermal compound and you got it!!!! It works I did it!!!, you can see more details at youtube search for ps3 YLOD fix part 1 gilsky.
Sep 07, 2009 | Sony Playstation 3 (PS3) Console
Does a new power supply fix the YLOD on ps3?
YLOD can be PSU or system bus (reflow CPU and GPU). It is not however a HDD issue. Inorder for it to be an HDD issue you would have to damage the HDD in susch a way that there is a dead short between +5V and GND or +12V and GND. This is very unlikely.
Reason why it would do it with PSU is that 12V is present but under load can't supply enough current to run PS3 system so voltage drops and resets PS3 system, hence the reason why it can be turned on again everytime but resets itself and gives so called YLOD.
System bus problem (reflow CPU and GPU) system shuts it self down due to internal bus failure.
Aug 15, 2009 | Sony PlayStation® 3 (60 GB) Console
Sony Playstation 3 (PS3) Console Logo
64 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
