Question about Kirby Ultimate G Bagged Upright Vacuum
My Sentria always runs in the drive mode and it is so fast it seems out of control. If I push the neutral pedal it stays in drive. I can push it the regular way when it is turned off, whether the pedal is in the drive position or neutral.
  • 171 Answers
I sold vacuums for almost 20 yrs and the Kirby gets lots of complaints. The transmission that it has in it breaks as your has and they are costly.The best thing to do would be to take the maching to the local vacuum store(eg. sewing and vacuum are often in the same store).Bring it to a used vac store and they all repair kirby and thay can give you the best advice. I dont recommend going to kirby as thay will spend four hours at your house trying to sell you a newer model and they have not changed enough to get another one in hopes it will be betrter. Good luck
Posted on Oct 07, 2010
  • kwithkirby Dec 08, 2010
    transmission needs adjusted not replaced in all likelyhood.
My Sentria is possessed......when we put it in drive......it goes backwards!!!! Help???
I saw videos it may be the transmission because it makes your kirby easy to push. It is working backwards so it may be the gears. This video will work for any Kirby that has TechDrive
Aug 17, 2014 | Vacuums
How do I replace a kirby g7 drive pedal?
Here is a step by step walk through with pictures on how to replace the neutral / drive pedal on any Kirby Generation vacuum (G3, G4, G5, G6, Ultimate G, Ultimate G Diamond Edition, Sentria and Sentria II)
Kirby Neutral Drive Pedal Replacement Guide
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 04, 2014 | Kirby G6 Bagged Upright Vacuum
Kirby Vacuum Cleaner on/off switch won't stay switched on
If the motor turns on turns off in the course of the vacuuming, check the cord or the switch This is how you replace your cord on a Sentria vaxuum.
Jan 15, 2013 | Kirby Vacuum Cleaner Switch For G3-Sentria...
When you turn the sewing machine on it constantly keeps on going almost like you have your foot on the pedal all the time the machine is a contessa 410 model
the foot pedal controls the voltage to the machine. If it is running to fast then the foot control is bad
Apr 18, 2011 | Vacuums
How do you replace the drive/neutral lever (foot pedal) if it falls off? (The yellow and gray lever that you step on to put it into drive or neutral.) Not sure what happened but it just fell off. Now I...
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items
Feb 28, 2011 | Kirby G5 Bagged Upright Vacuum
Hose for G3 Kirby doesn't fit Sentria
Yes G3 and G4 had different gasket thus the suction blower connector connecting Kirby hose to the unit on later models is different. You do not need to replace entire hose but just the plastic part that connects to the vacuum. You can find it HERE. To remove old connector you may have to submerge the end of the hose into hot water (not to hot to touch) so the vinyl becomes soft and you can bend it in with finger bringing plastic end over the lip on the molded end of the hose.
Good Luck
Jan 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Self propelled function
There are few things that may have gone wrong:
First thing to check is if when pushing pedal it moves gears located on the rear axle (you will have to take cover shell off to see that)
If that works fine then primary belt may be broken (see it here). Then just replace entire set to make sure that belt type matches gears
Last - the most expensive problem - the main transmission belt within transmission is broken (then I would recommend replacing entire transmission)
Sep 10, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby
machine will not come on
Sep 04, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
140 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
