Question about Olympus SP-570UZ Digital Camera
When I try to download pictures onto my desktop, nothing happens. I usually will connect the USB cable and I hit a button that says PC and it downloads. Nothing is happening. HELP!!
  • kakima Oct 07, 2010
    Have you considered NOT connecting your camera to your computer?
    The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
    Brigadier General:
  • 11,967 Answers
Try using a card reader instead of the camera.
Posted on Oct 07, 2010
I have a fujifilm s2950 camera and I'm trying to upload photos onto my computer. For the first time yesterday when I plugged the cable into the computer and turned the camera on nothing happened o
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 23, 2012 | FUJIFILM FinePix S2950 / S2990 Digital...
I have my G60 laptop connect to an LCD projector. I wanted to turn off the screen on the laptop and hit Function F4 which i have done in the past and it took the picture off of the LCD projector and now...
Disconnect the cable that is connecting the laptop to the projector. Sometimes this will happen if the projector or device you're connecting your laptop to does not support the current resolution that the laptop is displaying. Reconnect the cable and try using Function F4. If that does not work then disconnect the cable from laptop to projector, reboot the laptop then repeat connecting it to the projector and pressing Function F4.
Feb 23, 2011 | HP G60-120US Laptop
Purchased a Polaroid x800 camera and can not transfer photos to computer (and I have tried 3 computers - 2 running XP Pro and 1 running Windows 7). Upon connecting the USB cable it shows up as a removable...
Just did this with my daughter and it worked:
1. Turn PC on.
2. Plug camera cable into Camera.
3. Plug camera cable USB end into computer USB port.
4. Turn on Camera... wait until camera show message 'USB, PC, Pictbridge'.
5. PC should be selected if not select by highlighting and press shutter button.
6. Press 'Shutter' button.
7. Window 'Autoplay' appears on PC. Select 'import' in Autoplay window.
8. Another window will ask you to name your picture folder. Give it a name.
9. The pictures download to the picture folder automatically.
10. Turn the camera off and disconnect cable from camera and from the PC
11. ENJOY!!
Nov 10, 2010 | Polaroid Cameras
My compaq presario V6000 is stop working out of blue..Don't know why..the power cable is connected but hit the power button,nothing happens..any solution ??
Disconnect all cables from the computer. Press and hold down the power button for about 20 seconds. Reconnect only the power cable and try to turn on the computer on pressing the power button If it turns on then good otherwise, switch the power cable of the computer with the power cable of the monitor as they are the same cable as the power cable could be bad but this rarely happens. Open the computer and see if you see any light on the motherboard, if you do then the power supply is bad. If you dont then both power supply and the motherboard could be bad.
May 03, 2010 | Compaq Presario 5000 PC Desktop
Cannot download pic.s from camers to pc.
I would remove the memory card and use that to transfer the media to your pc.... I can't tell you why it is not showing up on any of the pc's. The only thing I can think of is possibly the usb cord is bad or that vivicam has special software you need to download. But you can definately get the media onto to your pc by bypassing the usb cord and remove the media from the card and place it in a folder on your pc .. hope this helps... good luck
Oct 19, 2009 | Cameras
I am trying to scan photos onto the computer
How is it connected? Via usb?  Have you tried powering the printer and pc off and back on?  Try to print something, go into your print que and make sure that there are no errors.  If using usb, try another port if you have one.  Also check your ink levels.  HP AIO wont work with low ink levels.
Mar 27, 2009 | HP PSC 1210v All-In-One InkJet Printer
I would like to know how 2 upload pictures from my At&t tilt phone to my computer
You need to sync your phone to your PC using a usb cable and Activesync 4.5 ( free from Microsoft) or Windows Mobile Device Center ( for Vista, also free on MS download site). Download either of these programs onto your phone,
and plug your phone to your computer with the usb cable, The wizard will help you setup your connection. Once the connection is established, Activesync will generate a sync folder on your desktop. Your pictures will sync from your phone to this folder
Jan 28, 2009 | HTC Tilt 8900 Smartphone
How do i upload photos from my v547 onto vista?
Vista should auto-detect your phone when you connect it via the USB cable. Make sure the phone is turned on before you connect it to your PC.
Most new equipment now requires you to download the latest software from the 'net instead of supplying installation software on-disk.
Dec 02, 2008 | Motorola Mobility V547 Cellular Phone
How do I get my Kodak Easy Share Printer #7330 to print pictured from my Compaq computer?
first install the printer onto the computer, downloading the drivers or using printer disk.
If your printer is already installed on your computer and working you do not need to install it , skip this step.
Then download pictures onto computer, using USB cable.
open downloaded picture by double clicking with left mouse button.
Once you open the picture with picture viewer open file menu and chose print, or click the small printer sign.
If you use oprint preview iit may be easier for you to change printer settings to print the pictures.
Sep 03, 2008 | Computers & Internet
Usb problem....please help!
if u want to connect through a USB cable u need to install a suite for ur samsung phone called "handset manager / easy studio"....after that u can fix the cable at both ends and transfer ur data and applications on ur phone with ur pc...
Sep 29, 2007 | Samsung SGH-E900 Cellular Phone
Olympus SP-570UZ Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
