Question about Refrigerators
Where is the drain llocated and how do i unclog it?
  • 121 Answers
The drain is always under the freezer coils. On a lot of side-by-side models you can see the drain without taking anything apart just look at the bottom back of the freezers. On some side-by-sides and all top freezers you will have to remvoe the cover off the freezer coils to access the drain.
Once you access the drain remove all ice that is on top of the drain. Then use a turkey baser to force hot water down the drain untill water flows freely. The mix baking soda with water and pour it down the drain. Check out this page http://www.appliance-repair-it.com/refrigerator-leaking.html
Posted on Oct 07, 2010
WATER IS RUNNING FROM SOMEWHERE (UNKNOWN) DOWN INTO THE LOWER COMPARTMENT, AND FREEZES. ANY SUGGESTIONS FOR A REPAIR?
Most likely your defrost drain line is clogged. Best cheapest method is to unplug & empty the whole fridge and leave both door open for 24 hours. This might unclogged the frozen drain line. If the problem comes back then you have to unclog the drain line with other means. May need a
Sep 18, 2014 | Whirlpool Refrigerators
How do you unclog washer drain
Hey friend, thanks for your inquiry!
I understand that you would to unclog your drain on your Frigidaire washer. I would recommend having a professional come out to unclog your drain because this would acquire some disassembly of your washer. These intricate parts do require precision and patience and I would suggest having a technician come out to avoid any potential harm. -Matt
Aug 22, 2014 | Frigidaire Washing Machines
How to unclog KFCP22EXMP drain line
You could... run a pipe cleaner upward from the drain tray, Jeannie. I'll bet that it's frozen, though.
Aug 12, 2014 | KitchenAid Pro Line Series Counter Depth...
Unclog a/c drain on mitsubishi ductless mr. slim
you should have a drain on the outside of the house take a shop vac and suck this drain line out, Make sure your filter is clean.
Jul 15, 2014 | Mitsubishi MS-A12WA & MU-A12WA Mr. Slim...
How do i unclog passenger side sunroof drain on 2002 monte carlo ss?
The way I did it was I used an air hose and blew out the trash
Apr 30, 2014 | 2006 Saturn Vue
Can't unclog stubborn bathtub drain
find a local hardware store or depot with a plumbing department and get a drain auger, it is a long wire with a spring around it that ends in a few hooks you can use to manually remove the clog if chemical clog removers do not work.
Aug 21, 2011 | Home
How hard to unclog condensate drain on 2001 intrigue? Pretty sure not heater core issue as wetness on pass side floor is not antifreeze smelling....
you will find a drain hose located on the fire wall 9 times out of 10 build up of debris not hard to unclog at all.
Jul 13, 2009 | 2001 Oldsmobile Intrigue
Water puddles front left of side by side ge profile fridge
If you clear the drain, the water will not fill up again. (try hot, but not boiling, water, forced into the drain hole with a turkey baster) When drain is clear, water will run into the drain pan located near the compressor. The fan will cause that water to evaporate.
Jun 07, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
HOW DO I GET TO THE PUMP TO UNCLOG IT
siphon to drain the water then flip the washer sideway and locate the motor cuopling or broken belt and change this to a new one
Jan 07, 2007 | Maytag Neptune MAH5500B Front Load Washer
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
