Question about Freezers
Electrolux frost free fridge freezer not workinge
Fridge is room temperature. freezer does,nt seem to be freezing food well. lights are working,
  • samsonli Jul 26, 2008
    Hi to everyone,
    My KF48 was running good before I pulled out the power cord since ten days ago.
    Right now I connected the electric again but it only blow out the hot air, I checked the R-404a still enough.
    Can you tell me if it stuck in defrost how to fix it ?
    Or it has another problem?
    Thanks a lot!
  • samsonli Jul 27, 2008
    Finally...fixed it tonight.
    Keep search, will find your answer on line.
    Save money save time.
  • 1,122 Answers
Think your frig heater or terminnator is bad,all this is behind the freezer panel,also but i'am not sure your frig. might be stuck in defrost,you find this out by pulling the frig. out and listen for 25 minutes to see if it cuts on,if you hear it running already then it's one of the other problems,hope this helps-mike
Posted on Jun 02, 2008
2 lights on bottom outside on food defrosting
5 Common Freezer Problems - APWagner Appliance Parts ...
May 22, 2008 - Answer 2: The first thing to do is to set the thermostat to a colder setting. ... The compressor is at the back of the freezer near the bottom. ... You can manually defrost your freezer by turning it off for 24-48 hours and turn it back on to see if it begins to work ... Verify that the door light switch is working properly.
Why is my freezer suddenly frosting over? - Askville
May 30, 2009 - For the last 2 months my freezer has had a layer of frost over ...Normally when frost build up occurs its because warmer outside air is getting into thefreezer and the ... Or you may have an issue with the defrost heater, thermostat or timer. ... If there is no light you may not have a frost free freezer which means ...
Why is my upright freezer freezing at the bottom but warm on ... > Patricia Delugas > Questions
Food in the drawers is still frozen, but above this level is room temperature to the touch. ... the lower inside pane to remove ice from around the fan and evaporator (mostly refrozen fluids from thawing foods on the upper shelves). ... 2 Answers from these members: ... Outside is not warm (as usual). Yellow light remains on. 2 ...
[PDF]All about the of your Freezer - AJ Madison
Jan 20, 2016 | Freezers
The top two shelves are not freezing and the food on those shelves and that area of the door have defrosted. The bottom seems to be freezing. I can hear the fan running and do not feel any drafts from
Obviously that freezer is not achieved the required temperature. There are several reasons for that:
- Defrosting system is not working, which leads to accumulation too much ice on the evaporator that prevents heat transfer and reduces air circulation despite the fan is running.
- The problem with draining condensate after defrosting cycle which also leads to accumulation of ice.
- Leaking gas from the cooling system (reduced cooling capacity)
- Faulty compressor
Jan 05, 2015 | Electrolux Freezers
Why is the pilot light on my ERN7926 frost free flashing?
To Start the Appliance
Allow the appliance to stand for 2 hours after
installation. Plug in the appliance and switch on at the mains
supply. Turn the thermostat control (B) to a midway
setting and adjust the slider control, situated on the
back wall of the fridge section, to a midway position
between "MIN" and "MAX".
The pilot light (A) will illuminate. Leave the appliance for approximately 4 hours for the correct temperature to be reached before placing food inside.
To switch off the appliance turn the thermostat
control to position "?"
After 4 hours, measure the temperature in the refrigerator and freezer. Should be between 2 and 10 degrees centigrade in refrigerator and app. -18 in freezer.
Sep 07, 2014 | Electrolux Freezers
Top shelves in freezer not freezing food. Also no ice from ice maker. Seems cold air has stopped coming out of top vent
We had the same problem with our refrigerator just yesterday. Defrosting (even tho frost-free) cleared up the airflow problem-- If it's frost-free, when it defrosts enough to allow air flow, the automatic defrost can take over. Cause was stored food blocking the vent between the freezer and lower part of fridge.
Mar 02, 2013 | Freezers
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Freezers
I have a Beko frost free fridge freezer but the freezer part has stopped freezing, the fan is working although it is not on all the time and the freezer is getting cold but no cold enough to freeze, have...
have you checked the door seals, if it has split it won`t freeze 100% as warm air will get in and keep the temperature up, bit like leaving the door slowly open hth
Oct 12, 2009 | Freezers
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Working ff freezer unplugged 1 year now does not freeze
Hi!!! You seem to have a seal system problem..A leak of refrigerant or a restriction in the seal system..Good luck...
Jan 20, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Freezers Logo
180 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
