Question about Bosch Nexxt 500 Dryer
Drum makes grinding sound when turned manually. Is it bearnings, belt, or other?
  • 171 Answers
The grinding noise is probably the bearings as the belt usually squeels and then breaks.I m not 100% sure with your model # but some have wheels that the drum runs on and they will wear out after time ;and they also have a bearing in them. Replace the whole set of wheels if that is the problem otherwise the others will wear faster.good luck
Posted on Oct 07, 2010
Drum will not turn
there is a belt that drives the drum in your dryer it is broken
the grinding sound is caused by the the wheels that the drum rides on broke or the bearing went out
Apr 14, 2014 | GE Dryers
Dryer making a grinding noise when turned on. How do you get the top off to check the barrel motor?
Clanging Sound
1. If the noise coming from your dryer can be described as a clanging sound, the solution is probably well within your grasp. This common sound is typically the result of loose debris accidentally put in with the load of laundry. Change may be left in pockets of pants or other objects may be dropped in the laundry basket by children --- perhaps a toy car. The objects may not be noticed when put into the wash, and the water in the washer may have dampened the sound. Simply remove these items, and restart the dryer to resolve the issue.
Sometimes the clanging is from snaps or buttons that are actually part of the clothing. If you are drying a jacket with metal snaps or another garment with metal attached, you should expect this clanging sound as they tumble and strike the inside of the dryer tub.
Humming or Whistling
2. Many Roper dryer models are equipped with a safety feature known as a lint signal, which is usually a light that often accompanies a warning signal, telling the machine owner that the lint trap has become clogged. When the dryer cannot pull adequate air through the lint filter, it can overheat and become a fire hazard. The warning alarm may sound like a hum or whistle to get your attention. Look at the lint signal light, clean out the trap and the noise should stop.
Thumping or Grinding
3. If the noise you are hearing can be described as a thumping sound or a metal grinding sound, the device that turns the dryer drum, known as the drum rollers or glides, can be worn out. As the drum turns, there may be a constant and rhythmic thump each time the drum rotates. A severely worn or broken roller could cause the metal of the drum to rub against the metal housing of the machine, causing a louder grinding noise. The rollers will need to be replaced to remedy the problem.
Squeaking or Squealing
4. Most dryers work by using belts to turn the rollers, which in turn make the drum rotate and tumble the clothes dry. When these belts get loose, a worn belt or a malfunctioning tensioner spring may keep the belt tight. In either case, belt slippage may occur and will produce a squeaking or squealing sound that is easily recognized. The problem is likely to be the tension on the belt since most belts will break before wearing out to this degree.
Feb 24, 2011 | Whirlpool Dryers
I have a Maytag front load Mod. # MFW9600SQ1 and It is making a grinding sound when the drum is rotating. I took off the back and belt to see if it was the motor but it is still making the sound. Is...
Is it making the noise with the belt removed ?? If so it is the pump has an obstruction in it most likely. As for the bearing it is not an easy job . The whole drum assembly must be removed from the case and separated.
Dec 07, 2010 | Maytag EPIC MFW9600S
Bosch AXXIS dryer # WTA 3510 uc slipping / grinding sound when drum reverses direction. Difficult to turn drum by hand. Belt or motor?
drum baring or rollers if you can get belt off try to turn drum if it still hard to turn you will know its not the motor may be something in blower give it a try
Sep 30, 2010 | Bosch Axxis WTA 3510 Electric Dryer
When turned on, the drum makes a grinding noise as
The main bearing may be worn out at the back of the drum allowing the drum to wobble.Reach inside the drum and lift upward. If you can move it up and down this is probably the problem.
Nov 05, 2009 | Whirlpool LER4634J Electric Dryer
It makes noise during the drying cycles
There are 4 possible sources of noise:
1) Drum support assembly - Open the door and turn the drum by hand. If there is a grinding sound and it feels rough, the roller suppot bearings are suspect.
2) Belt tension assembly - Same test as 1 except if you hear the grinding sound but it feels smooth, check the tensioner roller bearings
3) Fan assembly - this can have bearing failure or get foreign objects in it. Access isusually via the back panel
4) Foreign objects - check for things like coins in the space between the front of the drum and the trim around the door opening
Sep 09, 2009 | GE DBSR453EBWW Electric Dryer
Noisy grinding sound when drum is turning
Remove drive belt, and spin drum by hand from inside of drum, if it is noisy or rumbling, then main bearings have failed
If no noise with belt removed, then check elsewhere to pinpoint noise.
Please rate my solution.
Thanks.
Jul 06, 2009 | Electrolux Washing Machines
Chirping or squeal when idling
it could be a few thing.it may be your belt/pully /or alternater. it sound like it the bearn in the alter. try spaying p b blaster on the bearns. when the nose stop . that were the prolbems is.
Mar 22, 2009 | 1999 Ford Explorer
Ge dryer makes grinding noise when drum is turning
If youve made sure that its not a roller thats dry or a belt idler pulley that dry,than yes its the motor,and oiling that will only make it worse.
May 20, 2008 | Dryers
Open Questions:
See all Bosch Nexxt 500 Dryer Questions
Bosch Nexxt 500 Dryer Logo
216 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
