Question about Panasonic SC-VK31 220 Volt 5-VCD/CD Changer Shelf System
Model SA-VK31 1. Auto Off message is displaying in the screen. How to remove this message. 2.Though CDs are getting changed but it's not reading. 3. While running FM, Channels are not getting connected 4.Sound is not clear
Sa-vk31 remote number
Posted on Oct 10, 2010
Programming the cn101a timer
CN101A programmable weekly digital timer
Buttons
C = Master Clear, erases all program settings and current day/time.
C/R = Control/Reset, used to access programming mode and to clear individual programs.
You must press and hold this button for approximately 4 seconds to enter programming mode if there is a lower case "a" to the left of the time display. The system will revert back to active mode (with the lower case "a" to the left of the time display) after 30 seconds with no buttons pressed.
If this button is momentarily pressed while viewing a program, that program will be erased, but ONLY the On or Off program that is being viewed will be reset. The corresponding On or Off program in that cycle will NOT be reset.
Clock = In programming mode, this button is held depressed at the same time as one of the D+, H+, or M+ buttons to set the current day and time. When editing the programs, this button is used to exit when done.
P = Program select, each press will advance through the On and Off programs (presets). There are 16 On/Off cycles available (1 On, 1 Off, 2 On, 2 Off, ... 16 On, 16 Off).
D+ = Used to change the day when setting the time, or day(s) when changing a program.
When changing a program,
the following 15 different day combinations are available using the "D+" button.
MO; TU; WE; TH; FR; SA; SU; MO/WE/FR; TU/TH/SA; SA/SU; MO/TU/WE; TH/FR/SA; MO/TU/WE/TH/FR; MO/TU/WE/TH/FR/SA; MO/TU/WE/TH/FR/SA/SU.
H+ = used to change the hours when setting the time or a program.
M+ = used to change the minutes when setting the time or a program.
Manual = This button will cycle the output relay from AUTO to Manual OFF, back to AUTO, then to Manual ON, and finally back to AUTO. Programming mode must first be accessed using the C/R button to use the Manual feature. The manual On or Off settings will override all programs until switched back to AUTO.
There is a Lithium Ion battery which is intended to keep the clock going for up to 3 years during loss of external power, but the output relay will not work on internal battery power.
Jan 17, 2012 | Hardware & Accessories
I have a blue ray Prayer connected to my Panasonic SA-HE100 via a toslink digital audio cable. I don't get 5.1 surround sound. I do get stereo but not 5.1 where the back speakers sound. Any...
hi,
do one thing
1. press and hold DIGITAL INPUT button on the remote( will display AUTO--PCM FIX--DTS FIX)
2. select AUTO among them. and the try
ok
Jan 31, 2011 | Panasonic SA-HE100 Receiver
Cidco caller id model SA-60A-20 how do we change the language on it
I was able to reset my GTE Cidco SA-60A-20 caller ID unit with the following procedure:
1. Remove the battery.
2. Wait several minutes after the display fades away.
3. While holding down the "Delete" key, reinsert the battery.
4. Release the "Delete" key.
5. The unit will come up showing a boot process and end with a screen allowing you to choose the English or Spanish language.
Sep 21, 2010 | Cell Phones
Retune Panasonic SA-EN38DB DAB radio + ipod dock
Original manual found - note the Model No. is listed as SC-EN38DB i.e. complete system (main unit = SA-EN38DB; speakers = SB-EN38; remote control = N2QAYB000245):
"Press and hold (PLAY MODE) until 2DAB AUTO SCAN' appears. When a frequency is tuned by Auto scanning on this unit, the ensemble corresponding to the frequency is displayed for approximately 2 seconds"
Nov 17, 2009 | Panasonic Electronics - Others
How do I change from Spanish to English on my caller ID screen? Cidco Model# SA-60A-10
Nov 19, 2008 | Lands Phones
7 cd disc changer will not open or work properly
I took off the top then took off the cover of the CDs and took out the CDs then I took out the cd holders and placed them back in and put the top back on and it works now
May 12, 2008 | Audio Players & Recorders
Print Qualityfor DC12
I am not 100 percent what you are asking but I will answer the best I can with your question.
  1. Press the [Administration] button located above the numeric keypad on the Control Panel. The Administration button has a wrench symbol located above it. The Access screen will be displayed.
  2. Select [Tools] on the Touch Screen. The Tools Access Number screen will be displayed.
  3. Enter your numeric password using the keypad.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111.
    If the administrator encounters a problem with changing or forgetting the machine password, a service call must be placed:
  4. Select [Enter] on the Touch Screen. The Tools screen will be displayed.
  5. Select [System Image Quality]. The System Image Quality screen will be displayed.
  6. Select [Image Recognition]. The Image Recognition screen will be displayed.
  7. Select 'Screening Adjustment' by selecting the [Up] or [Down] arrow buttons.
  8. Select [Change Settings]. The Screening Adjustment screen will be displayed.
  9. Select [Apply to Copies Only] then select [Save]. The Screening Adjustment screen will be displayed.
  10. Select [Close]. The System Image Quality screen will be displayed.
  11. Select [Auto Screening Adjust]. The Auto Screening Adjust screen will be displayed.
  12. Select [Halftone Screen]. The Halftone Screen will be displayed.
  13. Select either [Halftone 200 line screen] or [Photograph 200 dpi].
    NOTE: Do not select 'Printer use' as this will effect print calibration; which will be handled directly by the color server set up to print to the copier / printer.
  14. Select [Save]. The Auto Screening Adjust screen will be displayed.
  15. Insert at least 2 sheets of white, 216 mm x 279 mm (Letter, 8.5 x 11 inch) paper in Paper Tray 5 (Bypass Tray).
  16. Select [Print Test Original] to print a sample of the settings. The message 'Please wait…Printing test original' will be displayed and the test original will print.
    NOTE: If selecting [Print Test Original] displays the message ‘System Disabled' then Screening Adjustment is disabled. Select [Close] and repeat steps 5 to 16.
  17. Open the Document Glass Cover.
  18. Place the test original face-down on the Document Glass with the two magenta squares against the left edge of the glass.
  19. Place 5 sheets of blank white paper directly on top of the test original.
  20. Close the Document Glass Cover.
  21. Select [Start Adjustment] from the Touch Screen. The message 'Please wait….Adjustment in progress' will be displayed, then the Auto Screening Adjust screen will be displayed.
  22. Select [Adjustment Complete]. The message 'Please wait…Printing current settings' will be displayed and the adjusted original will be printed.
  23. Examine the adjusted original to make sure the image quality is satisfactory and continue to the next step. If the image quality is not satisfactory repeat steps 12 through 22.
  24. Select [Close]. The System Image Quality screen will be displayed.
  25. Select [Close]. The Tools screen will be displayed.
  26. Select [Close]. The default copy screen will be displayed
Dec 27, 2007 | Xerox DocuColor 12 Printer
Monitor message
hello this is nichu ,your monitor is not supporting your cpu .hence you are getting the message "processing auto config message from screen display".either you have to change your monitor or you have to change your cpu.next time while purchasing the pc get the help your hardware vendor to check out the compatibility
Nov 04, 2007 | Gateway FPD1530 15" TFT LCD Flat Panel...
Panasonic SC-VK31 220 Volt 5-VCD/CD Changer Shelf System Logo
304 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
