Question about Kenmore Dishwashers
Broken glass went through pump cover openings. How do I remove this cover to remove the glass. My model # is 565.13572K700. I don't want to run the dishwasher with the glass particles inside the pump cover.
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
I could explain exactly how to do what you`re asking..."How do I remove this cover to remove the glass"
...however Its like the old saying, "pictures are worth a thousand words", the link below will direct you to a great video detailing exactly how to and what to do for your inquiry.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
When you`re finished run it through a test cycle and see how it goes. You may even want to run it empty with just a bowl of "white vinegar" placed on the top rack for a dishwasher cleaning.
Let me know how you make out. Thanks for choosing FixYa.
Good luck.
Regards,
Macmarkus :)
Posted on Oct 07, 2010
How do I remove air from pool filter lines?
with out seeing your set up not to easy,but lets try
1 your pump room is below surface of pool, make sure your pool level is high enough to return water to pump via the skimmer hole in side of pool at surface level. water should fil pump basket. check that you have a good seal on glass cover. no water in basket check if valve from pool is open still no water close valve fill filter chamber with a hose close glass cover start pump and open valve immediately.
2 pump room above pool level, close inlet valve fill pump filter with water close glass cover securely start pump and open valve.
a good drawing of you equipment and its position relative to pool how and ware u connect vacuuming hose
May 30, 2012 | Hayward Pool & Spa
Avanti dishwasher won't drain
hi could be two things... 1 could be you have food or broken glass in pump..it wont spin if anything there... u need to unplug from mains ...undo filter and remove ..you may have a larg metal filter remove too... you now have access to pump sump area... empty all water left in there with cup... it might SMELL :) when pretty much empty run VERY GENTLY around bottom of pump well... could be broken glass so do it slowley ... remve aything in there .. you will find a hole at bottom put finger in and turn propeller pump see if its stuck.. it it turns .and nothing is in way.. put back together and test dishwasher on quick wash.. if still not emptying change pump..
mark 07779933829 ===== TURN OFF AND UNPLUG FIRST=====
Nov 23, 2011 | Avanti DW18 Built-in Dishwasher
Changing light bulb when broken? I need to unscrew what is left, don't know how to get to it.
I assume you are referring...that you don't know how to get the rest of the broken bulb out?
Do you have a potatoe? Hopefully, you do! Cut it in half and stick the inside of the potatoe onto the left over glass and turn it! This is the best and safest way to remove any broken bulb!
Remenber,...Lefty,...Lucy....Righty,...Tighty!
If there is a cover over where the bulb is...this cover should just pop off!
If there is no potatoe...you can use a pair of pliers, but...please unplug your refrigerator...First!
Kind Regards!
Sep 09, 2011 | Maytag MLE2000 Front Load Stacked Washer /...
I cant open the glass on my back hatch any suggestions?
The glass hatch release handles fail all the time on these models (which is why the system was eliminated in 2009 models).
The glass hatch handle is $32 list from the dealer.
Removal and replacement requires a philips screwdriver and a 10mm socket and ratchet with extension.
Open the glass hatch by manually activating it through the access hole on the inside of the tailgate (small square panel covering it)
Remove the two philips screws and the one pop fastener holding the plastic trim on the back of the glass hatch handle area.
Remove the two 10mm nuts holding the handle on, unplug the wire and remove, noting the routing of the wiring on removal.
Reassemble in opposite order, being sure to route the wiring correctly.
Oct 29, 2009 | 2004 Mitsubishi Endeavor
Broken glass stopped machine want to take apart and remove pieces. I think spinning arm can be removed, but don't know how
The problem is in the pump not the arms. must take the top of the pump off to cleen out the glass. if you try to run it without getting the glass out it will distroy the pump blades and it will need to be replaced.
Sep 09, 2009 | Whirlpool DU912 Dishwasher
Mine is humming too but cycle not starting
THERE IS A SMALL INSPECTION COVER OVER THE PUMP UNDERNEATH THE FILTERS IT IS REMOVED BY UNSCREWING A TORK 20 SCREW HOLDING IT IN PLACE THIS WHEN REMOVED WILL REVEAL DRAIN PUMP IMPELLOR SOMETHING IS JAMMING IT PROBABLY A PIECE OF BROKEN GLASS REMOVE PUMP SHOULD RUN AND APPLIANCE WORK.
HOPE THIS HELPS
Jun 26, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher wont drain. At end of cycle is full of cloudy water.
It is possible if you have broken a glass recently that the piece of glass has made its way to the drain pump impeller. You need to remove bottom basket. Remove the filter strainer clamp by rotating CCW. There may be another round filter under the strainer (depending on model). Then with a torque screwdriver remove one screw which holds the plastic pump cover on. Remove the pump cover and pay close attention to the pump impeller. Does it rotate by finger movement? If not it could be jamed with a piece of broken glass. You must remove any obstruction to allow the impeller to turn. I usually force a paper towel piece (half piece while rotating the impeller by finger to allow the paper towel to bring up any obstruction below the impeller) Reassemble the cover and filters carefully and make sure the final strainer clamp aligns correctly with its marks. This insures nothing will make its way to the impeller in future.
Regards Sam
Jun 15, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Dishwasher was making whirliing noise during wash, now no wash, only fill and drain
there is a #10 torx screw holding that cover down.do not drill it out. after you take it off you can tell if the chopper is broken.be careful for broken glass.
Oct 17, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore built in dishwasher~2001 model year ,noisey when running.
HI remove the spray tube. remove top cover. look inside that could be a broken piece. this patr can break with pieces of glass going through it. thanks
Oct 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
I have LG dishwasher for 2 years now. Working perfectly until one day one glass gets broken during washing cycle. Immideatly we get EO error. We check possible reason of error in the manual then decided to...
In order to fix problem we disconnected dishwasher, put it on one of side, opened bottom cover - the one that is outside of dishwasher. We find out the part that is
connected to the drain horse. We take of 3 screw and open that part too. We discover
few small peices of glass that were preventing to rotate one plastic part of dishwasher. We removed that pieces of glass. Put all back and connected dishwasher. All was working fine. I am suggesting to everybidy try these steps before calling for any service.
May 19, 2008 | LG Dishwashers
Dishwashers Logo
70 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
