Question about Compaq (153515-001) Touch Pad
How do i disengage my touchpad when i am using a mouse?
  • 590 Answers
There should be some button near to the touchpad itself which is used to disable the touchpad. find the button near your touchpad to achive your need.
Thanks
Posted on Oct 07, 2010
How do i disable touch pad when mouse is in use
      Click the "Start" button and click "Control Panel." Click "Hardware and Sound" and click the "Mouse" link under Devices and Printers to open the Mouse Properties box. Click the "Touchpad" or "Buttons" tab depending on your PC, then select the "Disable" option next to thetouchpad installed on your computer.
      How to Disable TouchPad While the USB Mouse Is Plugged in
      smallbusiness.chron.com/disable-touchpad-usb-mouse-plugged-52685.html
    Feedback
    How To Turn Off Touchpad When Mouse Is Connected In ...
    www.intowindows.com > Windows 10
    Dec 14, 2015 - How To Turn Off Touchpad When Mouse Is Connected In Windows 10/7/ ... who always use a mouse and don't want to use the built-in trackpad ...
    How to Disable Your Laptop Touchpad ' PCWorld
Jan 31, 2016 | Toshiba Satellite C655D-S5120 Notebook
How do I disable the touchpad? I am running Vista Home Premium. There is no Function key to enable/disable the touchpad. I disabled the touchpad by going to Control Panel, Mouse, and disabling the...
have u gone to control panel - device manager - then on pull down menu's show hidden devices ; click on all the + boxes till you see touchpad ( mouse and pointing devices) right click mouse and click on disable.
i always go through device manager as all devices are in one place!!
Apr 11, 2015 | Gateway M-6827 Notebook
Cursor problem
Disabling the touchpad on a Dell Inspiron can be useful when typing for long periods of time, or using an external mouse. Bumping or tapping the touchpad while typing can cause cursor jumping and unwanted results. Use the touchpad software to enable or disable touchpad controls. Download the driver for your touchpad at the Dell Support website.
Click on the "Touchpad" icon in the task bar. If the icon doesn't appear, you can download and install the driver for the touchpad from the Dell website, or choose "Start" and "Control Panel." Choose "Device Select" on the touchpad menu, or choose "Mouse" in the "Control Panel" menu and "Device Select." Click "Disable" under "Touchpad" to turn off the touchpad, or click "Disable Touchpad/Pointing Stick When a USB Mouse is Connected."
h
Feb 28, 2013 | Computers & Internet
Mouse pad stalls and i see a little red light on the mouse pad....i have a compaq laptop but not sure what version...how do i disable thi feature so i dont have to use a physical mouse
The little red light is likely from the red LED underneath your optical mouse. If the mouse cursor/pointer on the screen is jerky, it may mean the mouse pad is dirty and/or if the mouse is wireless, its battery is low and should be replaced. Most laptops have a touchpad as part of the keyboard. If you want to use that instead of a physical mouse, just put the physical mouse away and use the touchpad. Both should be active unless the touchpad was disabled. If the touchpad is disabled, you can re-enable it by clicking on control panel > mouse > device settings tab > enable button.
Mar 16, 2011 | Computers & Internet
I am using wireless mouse. How do I disengage the cursor pad on my sony pc? Thanks
I stole this directly from a Yahoo answer for this problem. Credit goes to Piyush Garyali
Go to C:\Program Files\Sony\Setting Utility Series and run VCCPointingDevice.exe. Untick the “Enable” checkbox and voila – this would disable the touchpad. You could create a shortcut to the file above for easy access!
To get to the executable without a mouse, press {Windows-Key]-E, then use the tab key and the arrow key to navigate through Windows Explorer. Just highlight the file and click {Enter} to launch it.
To enable the touchpad you need to run the same executable and tick the “Enable” checkbox. You need to have an external mouse to move around and if you are a GNU-Linux freak, I guess you can make you way around without the mouse.
This worked when nothing else did!!!!
Sep 05, 2010 | Computers & Internet
I want disengage the laptoptouch pad when I'm using a regular mouse.They seem to interfere with each other
Try turning off your printer or other hardware when not in use. Often a hardware conflict can be solved this way
Sep 20, 2009 | Dell Computers & Internet
Can move the mouse but not clikc with the touchpad
if you installed an external mouse, it would over-ride the touchpad.
try removing the external mouse, and tap the touchpad twice as if you were double clicking it.
also you could try re-installing the touchpad device driver, usually synoptics or similar.
Mike @ compurepair.
Jun 11, 2009 | Acer Aspire 5610-4648 Notebook
Mouse or touchpad not working
add an external mouse/keyboard to fix the onboard fault.
check the device manager for any yellow exclamation marks. as there may be a faulty or corrupt. keyboard/mouse touchpad driver.
other option, is to add remove touchpad drivers, and re-install.
finally, you could check if the settings are correct in the bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 05, 2009 | Toshiba Satellite A105 Notebook
Dell Latitude D630 Touchpad/Pointer
Do not check the check box as leaving the touchpad enabled while using an external mouse will not cause any harm.
Dec 11, 2008 | Computers & Internet
Mouse/touchpad issues
Try to connect a external mouse.
If it does work ok with the external mouse . It means that their is a problem the touchpad.
Who can take it to a service center for repair or you can use the external mouse.
Thank you
Thewho1
Jun 29, 2008 | Computers & Internet
Computers & Internet Logo
113 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
