HP PRINTER C7280 ALL IN ONE PRINTER. ERROR CODE ON printer LED SCREEN- INK SYSTEM FAILURE as above code.
    Sergeant:
  • 260 Answers
Getting the blue screen on the printer LCD with the on/off switch symbol and the error 824C1500. Get a new and different error message each time I unplug the printer, wait a minute or so and then re-plug it in. I responds to no button pushing and will not turn off at all. Is there a simple fix for this problem or is it a throw-away?
for more help visit https://cbrtechsolutions.net
Posted on Oct 06, 2015
  • 1684 Answers
SOURCE: Ink System Failure: Errow:Oxc18a001 with a HP C7280
Check our web site at: www.ccl-la.com/hp.htm We have a step by step guide to correct this problem. This error is caused by air in the ink feed tubes and the guide will help you do a purge on the lines.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 19, 2009
Testimonial: "Thanks a million!!!!. Saved the day. Instructions were on point... Reply was timely. THANKS."
bandana_gyrl
  • 181 Answers
SOURCE: I have a printer ?HP c7280 All-in-one?a message,
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Posted on Jan 21, 2010
pineworks
  • 4041 Answers
SOURCE: Ink System Failure code appears on Hp Photosmart D7360 printer
Hi ok try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
  • 30 Answers
SOURCE: How do i repair: hp Photosmart C7280 Printer ink
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Posted on Jul 26, 2010
  • 214 Answers
SOURCE: HP photosmart C7280 ink system failure 0xc05d0281
Go here
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&rule=11380&product=1153494&key=null
Posted on Nov 04, 2010
HP C7280 ink system failure error: 0xc18a0101
just had this exact issue with my C7280. I called HP Tech support, got a body in Bangalore or someplace, and was pleasantly surprised that they were prompt and knowledgeable, and solved the issue very quickly after transferring my call one time to a hardware support expert.
I hope this help those who have similar issues
Jun 16, 2011 | HP Photosmart C7280 Printer
Ink system failure on my HP C7280
The 'ink system failure' is caused by air in the ink feed tubes. This problem caused by either a poorly refilled ink cartridge or by fully using all of the ink in the cartridge and then the unit sucks up air instead of ink. You will need to purge the air from the ink lines to clear the error. We have a step by step guide posted in an article on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ The purge will take about 5 -10 minutes to perform and sould get you back printing.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 14, 2010 | HP Photosmart C7280 Laser Printer
Ink system failure code 0xc18a0301
I had the same error and found a posting that recommended that you press * and # and then release at same time. The screen states that you need to enter a Special Key Combo. Enter 1 2 3. From here press the right arrow until you get to System Configuration Menu. Press OK three times. Then press Cancel until you are back at the main screen. This clears the hardware failure status.
Jan 13, 2010 | HP Photosmart C7280 Printer
HP C7280 All in one. Ink delivery system failure.
check original ink cardrige. And send to the repair store.
Dec 20, 2009 | HP Photosmart C7180 All-In-One InkJet...
HP 6280 INK SYSTEM FAILURE
Try This :
First check with a new set of orginal HP catridge ; if still it doesn't work then the printer needs to be replaced ; call HP if the printer is in warranty they will do it free of COST ; No. for HP is : 18004746836;
Sep 16, 2009 | HP Photosmart C7280 Printer
Same as above: error that ink cartridge is damaged or missing
Try simply turning off the printer, disconnect from power, and let sit 5 minutes. This will bleed out the printer's internal memory. Reconnect and try again. Otherwise, if you can't get the reset procedure to work, unfotunately, these printer have an integrated printhead system, and the printer will need to be replaced.
Jul 23, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C7280 Ink System Failure
Contact HP for Care at 1-800-585-2494 Toll Free
Oct 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
51 people viewed this question
jasbo
jasbo
