Question about Acer Aspire 5315 Notebook
We just bought this acer aspire 5315 lap top brand new charger but battery still wont hold charge even plugged into the wall can anyone help please its for my kids to play?????????????? i have a gateway mine works fine and hubbys is dell his works fine just the kids doesnt?????????????
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Oct 07, 2010
My daughters Acer wont charge so the battery is dead. The laptop wont even come on when the charger is plugged in but i have an Acer an charged her battery in mine then it charged and it worked in hers. Is...
first try to use your charger into another laptop, if the the another laptop was charged using your charger, it means your battery is the problem, but if it is still not charging it means the problem is your charger. then try your battery to use it into another laptop, as same as the i mention in the charger, if they or both fine, maybe the problem is the batery terminal of your laptop.
Dec 07, 2010 | Acer Aspire 5315 Notebook
My lap top wont turn on i have a blankj screen the
Please try these. After on your pwoer botton wait 2 minites and the press FN+F6.
Let me know what happening.
Thanks.
Jan 30, 2010 | Acer Aspire 6920 Notebook PC
Acer Aspire 5315 randomly stops charging.
I think u just answered urself, replace the power jack should solve the problem
Oct 10, 2009 | Acer Aspire 5315 Notebook
Problem with charging adapter on my laptop acer aspire 5335
the charger gets real hot??????? O really? wonder why?....Charger defect... guaranteed
Jun 27, 2009 | Acer Aspire 5335-2257 Notebook
Concerning the battery chargers for 5100 and 5315...I had the Amps backwards...5100 is 4.74A and the 5315 is 3.42A..so the question now is: can i use the 4.74A charger to charge the 5315 lap top (which is...
Hi there.
You must only use power supplies which are specific to that particular laptop, even if you have a power supply of the same voltage but the amps are different it may power the machine but in my experience they have blown the PB (power board) which has resulted in no charge at all right down to the motherboard itself being blown.
I suggest you use the power supply specific to that laptop.
Good luck and thanks for using Fixya!!!
Mar 02, 2009 | Acer Aspire 5100-3357 Notebook
Using battery charger with 3.42A vs 4.74A for lap top
YOu can always use higher amps when required but not lower than required. Voltage should stay the same as original charger - keep it in mind.
Acer aspire 3500 wont hold charge or turn on
I had to buy an new ac/dc plug piece off of ebay (cost only like $3 bucks) to sodder onto the mother board of my Acer. Somehow the little plastic/metal piece you plug into your computer comes off the mother board really easy. Acer wanted me to purchase a whole new mother board (at frigging $350), which, frankly wasn't an option. So I bought the little plug gizmo, soddered it on, and I'm doing good now.
Apr 09, 2008 | Computers & Internet
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Nov 11, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 5315 Notebook Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
