Question about Kenmore 57029 Side by Side Refrigerator
The unit is not cold or freezing anything at all but it is running
  • Kenmore Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
Why doesn't it freeze or make ice?
The freezer fan motor is running slow, replace this part, this is a common fault
Ian
Aug 14, 2015 | Daewoo Refrigerators
Freezer not freezing and fridge not getting cold
How old of a unit do you have? Can you hear anything running like the fan or compresdor?It could be ice build up in the ductwork, It could be low refrigerant pressure, an electric issue, Your unit may have a bad fuse or tripped breaker(if it is an older unit.), the thermostat may be bad. Or ot could be the compressor. Did you check the electrical socket the unit was plugged-into?
Maybe these suggestions will help you.
Feb 18, 2015 | Maytag Refrigerators
ATB1935HRW
hi john.not freezing could be anything but i would start by checking if u have any ice build up in the freezer.if yes defrost everything first completely and try.if ok great.if same again after a few days then i think your problem will be either 1-defrost timer 2-defrost heater 3-t/stat 4-if not iced up at all check door switch/fanmotor 5-check/clean condensing unit 6-check cond/fan 7-check motor (visual/feel/noise (hot or cold and running noise) 8-condenser warm(if cold could be lack of refrigerant;internal leak or motor)hope this helps good luck.Ali
Jun 30, 2012 | Amana Refrigerators
Problem with 2 Musso Pola Machines
Depending on the ingredients, it could take 40 minutes to make a batch. Make sure you mixture is very cold before it goes into the unit by chilling in the coldest part of the refrigerator until very cold. If anything less than a very cold mixture goes into the unit, the freezing time will be quite long. The outside of the unit will not feel cold, just the inner wall of the bowl. Also, if your recipe includes any alcohol, this will inhibit the freezing process.
Mar 15, 2010 | Musso Stainless Steel Pola Ice Cream Maker
My Amana side-by-side has the same problem - won't cool or freeze
the capillay may have got choked partially.... get a service person to look into it
Jul 28, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Central air unit problem.......It starts out blowing cold then will only blow room temp air after some time. I don't see anything freezing up..Filter is clear. The unit outside is not clogged up. The...
Check your outside unit to see if fan is running. If it is running check to see if air is blowing out if not you have a bad capacitor. Some times if a capacitor shorts out the fan will run backwards and the line will get very hot same as if the fan is not running. Russ
Jul 20, 2009 | Heating & Cooling
Compressor runs for 5sec.
your relay and overload on side of compressor is bad.you can replace with original parts or a 3-n-1 hard to start.
Mar 09, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Amana side by side not cooling well, will not freeze water.
if you are only seeing frost on the top portion of the evap coil then you then it sounds as if the unit has sealed system problem (low freon or bad compressor). if the unit is less than 5 years old and made prior to nov '06 it should have a sealed system warranty. if the unit is out of warranty you may want to start looking at new refrigs. good luck peyton
Jan 24, 2009 | Amana ARS2464B Side by Side Refrigerator
Central air unit
Make sure you let the blower run for a while after it freezes to make sure there is no more ice. Then run the unit. Check the refrigerant lines the large copper line that has insulation on it should be cold to the touch. If it runs for 10 minuits and is barely cold or warm you are low on refrigerant. If its starts out nice and clod then check your filter and retun ductwork for blockage you should not have noisy return air vents or that can indicate you have too small a return.
Also are the outdoor unit and indoor coil a match? Same tonage?
Is the furnace big enough to handle the tonage? (fan size)
Aug 17, 2008 | Coleman Propane Forced Air Heater...
Kenmore 57029 Side by Side Refrigerator Logo
32 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
