Sony baio laptop boots to black screen and mouse arrow the light blue screen , mouse works
    Master:
  • 515 Answers
It seems to be something wrong with the system core. Try push the processor towards the motherboard a bit to make sure it fits tight and the cable connection of your disks are connected well. Then reboot it. You can try to boot in safe mode or perform a system restore to factory default to remove all hard disk issues.
Posted on Oct 07, 2010
Error message 8801 sony laptop windows 7 black screen F8, F11 will not work i have a system image on a disc
You can restore the image to your laptop or use a software to directly fix the issue after boot from a bootable disk, Windows Boot Genius should be available for you, it can fix all kinds of computer errors. Or the below artilce related may do you a favor:
http://www.squidoo.com/computer-black-screen-and-computer-blue-screen
Mar 20, 2013 | Computers & Internet
How to remove black screen from my laptop
If you have a repair disk, boot from it and run a "Start up Repair". On a Dell machine I think it's "F10" during the boot process to get to the BIOS settings, change the setting to boot from CD to run the repair. After running the repair, reboot and enter the BIOS again, change the setting back to boot from the Hard Drive, save and exit. Hopefully this will solve the issue.
Feb 16, 2013 | Dell Inspiron 600M Notebook
Light blue screen with enlarged mouse arrow can't log in
This sounds like it is going into safe mod or descreasing resolution. What has transpired before this problem? Did you upgrade video drivers?
Jan 21, 2013 | HP TouchSmart 600-1120 All-in-One PC Black
Screen wont come on, on my Toshiba laptop computer
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel.
Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on.
If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective.
If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps.
Jan 15, 2013 | Toshiba Computers & Internet
Just have a black screen with mouse arrow after input password
press f8 , when it turn on go to start and use system restore
Mar 11, 2012 | Computers & Internet
I was working on my laptop samsung Q430 and it suddenly turned off . Its boots to the windows stage and then blanks out(blue screen)..I have tried to reboot and recover it several times but it still is...
The blue screen (BSOD) is usually caused by a new piece of hardware or driver. But there is a code on the screen which will give you more information about the problem. Put the code into a websearch site and the possible cause should be given.
Feb 23, 2012 | Samsung Computers & Internet
My laptop is not booting. its showing enter passward in blue screen.
somebody set the bios password to reset the bios password open the back cover of ram u see a small battry like a coin remove it fo10 to 20 second and remove laptop battry at same time then plug the adapter u will see baios was reset if u have any qury plz tell me the laptop model no and manufacturer
Sep 15, 2011 | Computers & Internet
It won't finish booting up; it shows the windows xp logo then it flashes to a blue screen with writing on it and then it shuts down: it shuts down after a second so there isn't time to read what is on the...
You are probably heading for a reinstall of the os (or restore). You can try booting in safe mode (f8 after acer logo goes away, then arrow up on keyboard to safe mode (mouse wont work in this mode), then hit enter.
If this still doesnt work, check your manual on restoring your system.
Sep 25, 2010 | Acer Aspire One Netbook 8.9" Notebook
Need to reset display settings
Hi
Take a look at the keyboard and find the FN button on the bottom left. (The letters FN are in blue)
Now look at the F keys at the top of keyboard and find one that has either a couple of monitor symbols or the letters CRT/LCD - again in blue
Holding down the FN key and press the other key, this should change screens between the external and internal monitors. Don't expect an instant change - it sometimes takes a couple of seconds to do the job.
If that does not work then attach another external monitor, right click on the screen and select properties. Now select the far right tab (settings) and then go to Advanced tab and then select Monitor
Here you should be able to change screens back to the LCD of the laptop
Dec 09, 2008 | Toshiba Satellite P30 P35 Series Notebook
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
