Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
For some reason every time i enter it on my comp it needs to be scanned and fixed even though i'd properly removed it. And it doesn't actually store my data it keeps icon of them with 0KB HELP really need it
I cannot install my data traveler 2 gig on my laptop
Posted on Jun 01, 2008
2003 gmc yukon acts like its not getting fuel. I have replaced the fuel filter but still have the same problem. If you spray starter fluid in it, it will start up and run, sometimes rough and sometimes...
A fuel filter won't fix anything
Just like replacing a blown fuse does nothing
You need to diagnose the problem first
It may act any number of ways to you
Have you confirmed fuel pressure on a gauge
or looking at scan tool software?
Does the pump come on when it doesn't start
& what does the gauge say when you cycle the key?
Do you have a check light on dash or stored codes
you can only see on professional scan tool?
Do you even know how long the spark plugs are
in the motor or looked at fuel trim,or module voltage,
or O2 sensor data?
Right now it sounds as though you have no knowledge about
vehicles & haven't actually done anything
What does work & how do you know that
You have to test the entire truck,then work on the faults
you find
Jun 11, 2012 | 2003 GMC Yukon
I used a PS/2 Keyboard and one day it stopped working. And I found out that when it's installed even the mouse doesn't work, so I bought a new USB keyboard though I can't enter the BIOS with it...
Hi, you maybe just need a driver for the mainboard.
You can download here:
Try the chipset driver first.
Please unzip the file before installation.
You maybe also need the driver for the usb controller.
Try to use a PS/2 mouse until the driver is installed.
Aug 28, 2011 | Biostar G31-M7 TE Motherboard
The service engine soon light is on and i took it to get a reading.they told me it had to do with the emissions.they said either a line was clogged or not properly on.I never got the code as to what the...
as long as it runs alright, drive it-but you will need to get the actual code to determine exactly what the issue is. Make sure your gas cap it on tightly, and you might consider just replacing it (they are less than $10 and 90% or the time are the reason for a code). Go to a commercial parts store like a Pep Boys, Advance Auto or Auto Zone and they will scan it for free, tell them you want the actual code. You could also disconnect the negative battery clamp, leave it off for a few minutes, and hook it back up-it might clear the check engine light, if it comes back, get it scanned again.
Jun 22, 2011 | 2003 Suzuki XL-7
Got virus
check if internet is working in safe mode with networking.
shut the comp off//
restsrt the comp and immediately tap f 8 cont....
will take you to adv boot option//
select safe mode with networking//
hit enter once and again enter//
login and the comp should be directly connected with the modem//
if internet is working then download malwarebytes s/w and do the quick scan//
once the scan is over also remove the virus from quantrine (4th option) on the top//
if you find difficult then call up hp smart friend support and they will do for you. phone number is 1866-211-5207. charges is $59.99.
security tool is a virus and can create lot of other problem and crash the computer. so if you want to be on safe side and if you are not sure what you are doing then go for techj support. will save your time and lot of money too.. which you are not aware of.
May 09, 2010 | Microsoft Windows XP Professional With...
Every time I hook it up to my computer it says installing device, even though I already have the software on my computer and my computer doesn't detect the device
run the wizrd intallation your comp should all ready have 'wizard' the reason its doing this is because you removed/unplugged the device with out safetly removing it from the computer the icon should show up on the right bottom of the computer just for further ref
Dec 21, 2009 | Microsoft Zune JS8-00001 Digital Media...
Cartridge is not recognized
Try it a few more times, if that doesn't work, you'll have to get a new cartridge. (I believe your cartridge comes with a new head, it's actually the printing head that you need)
Canon cartridges are infamous for failing for no apparent reason.
Aug 26, 2009 | Canon PIXMA iP1300 Printer
'unable to save file. the system cannot find the path specified'
Had this same problem and just fixed it. You need to actually change the button settings in Navigator. Open MP navigator and choose One-Click, then click Button Settings. You can choose a new save destination from here. Even though you are using the software instead of the button on the device, it works.
Dec 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
No preview on scanning
You may need updated softwqare.You can go here
to look for your software and it has the option to actually test it on site. It is not free. You have to order it. Good Luck.
Aug 08, 2008 | Office Equipment & Supplies
Xerox 510 will not scan from ADF
If it is new, and not assuming there is a hardware problem with the scanner (some fault), might be a software problem. If the scanned image from the flabed is OK the drivers would be installed properly. You do not say which software you are using but when you have a "Professional" documentscanner and intend to use it for "production" scanning you need proper software also, To scan, to mix documents, rearrange pages, auto remove blank pages, deskew, produce small PDFs even when scanning color and so on. Look at PixEdit - it will do the job for you.
Jul 16, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Missing dvd drive
I'm not familiar with daemon tools, but check what Device Manager (right click My Computer, Manage, then Device Manager)things about your drive. If it shows up incorrectly there, try deleting it, then rebooting or doing a "scan for hardware changes". And it's always a good idea to go to the manufacturer's website and checking for updated drivers, I've noticed especially with laptops, they come out ALL the time. Good luck!
May 09, 2007 | Toshiba Satellite M45-S355 Notebook
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
Top Kingston Computers & Internet Experts
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
