Question about Samsung NV10 Digital Camera
Samsung nv10 digital camera, the lense is stuck in zoom position. if i turn on my camer i cant get it to close and then it shuts off
    President:
  • 4,070 Answers
Hi! As a first course of action please remove the battery and press hold the power button for 10secs. while the battery is removed. Install the batter, turn it on and see how it goes.
Posted on Oct 07, 2010
My samsung pl50 won't turn on it just bleeps at me when i try and the shutter is stuck out. it was working fine when i was taking pics of my sister then it just shut down n won't turn back on
I've sent back 2 phones with this exact problem. Came on here and found the solution on the blog from another camera. It works! Here it is:
Figured it out....the zoom lense, while in the open position, was a little out of line, thus preventing the camera from retracting it. After gently re-aligning the lense, it retracted properly and the camera resumed normal functioning.
So basically, wiggle the lens every so slightly then try the power button again. Hope it works for you!
Jun 05, 2010 | Samsung L200 Digital Camera
Kodak V1253 lense won't close
Use the vacuum cleaner to suckout the dust/sand particles stuck between the lens casing and the body.
Aug 11, 2009 | Kodak EasyShare Z1275 Digital Camera
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Lens is stuck open - will not close. still takes pictures
you must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Nov 24, 2008 | Samsung NV10 Digital Camera
Problem with camera
The lens is sticking, I had same problem, thought it was the battery. It kept doing 4 beeps and turning off, but the lens would be out.
Lightly lube the lens area with WD 40 worked, be real careful and don't use alot of it. My camera works fine now. I actually read the solution someone on this site, can't find it now, but wanted to post that it worked for me. I love the camera and was bummed it wasn't working. Works great now!
Aug 04, 2008 | Samsung NV10 Digital Camera
Lens problem
I have had the same problem with a different camera, the problem started when I did not have sufficient battery charge to turn the camera off completely. The camera shut down, but the lense did not retract.
You can try a few things:
First try remove the batteries and holding the power button as if you are going to start the camera, then reinsert and try again. (make sure they are fully charged first)
You can try connecting the camer to the computer before you turn it on. Connected to the computer the camer goes through a slightly different start up procedure.
Try switching it to playback mode on restart.
If these fail I have a couple of tricks up my sleeve, but need to know the answer to these questions:
1. has it suffered water damage?
2. has it been dropped recently?
3. what happend when the lense did not close properly? Is this the first time?
4. Can you access the menus when "restart camera" is on screen?
Just post a comment back
Jun 13, 2008 | Canon PowerShot SD1000 Digital Camera
Zoom and camera shuts off
Verify you have the right kind of battery and fully charge it.
The lense issue you describe commonly happens when the device cannot access enough power to function correctly, so it retracts and powers off to avoid getting your lense stuck in the 'out' position if the battery goes dry.
Apr 27, 2008 | Kodak EasyShare One Digital Camera
Samsung NV10 - 4 bleeps on switching on then turns off
my camera started doing the same exact thing, did you ever get an answer?
Jan 20, 2008 | Samsung NV10 Digital Camera
Samsung nv10
I too have this problem. I sold the broken one on ebay, and bought a second hand one and low behold - it TOO has a stuck lens.
unfortunately warrentey ran out months ago. How depressing.
Dec 14, 2007 | Cameras
Samsung NV10 Digital Camera Logo
622 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
