Question about Kodak EasyShare P850 Digital Camera
I dropped my fujifilm camera, and the lense is stuck and when i try to turn it on/off the screen just flashes and it won't work. have i broken it? :(
    President:
  • 4,070 Answers
Hi! This will require a lens and lcd replacement for sure. Im sorry but they surely are busted.
Posted on Oct 07, 2010
Film is stuck
Film stuck is cause by faulty gear. camera most like had been dropped. gear is damaged.
Jul 28, 2013 | FUJIFILM Instax 210 Film Camera
I need to download a driver for my FinePix JV300
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 21, 2012 | Fujifilm FinePix JV300 Digital Camera -...
My camera is zooming in and one edge of the lenses is higher than the other one
Due to regular dropping it internal parts seem to have become loose and thus are not in control. Try getting it checked it at the service center to change the loose parts
May 16, 2017 | Fuji Cameras
The automatic flash is constantly 'off''. Have
Well, try to go through your menus to understand what the problem is. Also, check to see what mode you are one. It is possible that that mode is preventing auto-flash. Good Luck!
May 09, 2011 | FUJIFILM Finepix S1500fd Digital Camera
Lensis not coming out
If you turn it on in photo review mode the lense will not open so turn it on in photo capture mode or if dirt gets caught in the lense it would jamm it shut so try to clean it, or if the lense is dented it would jamm, or if at one time the lense tried to open indide a case or in a position where the lense was blocked the motor mioght have burned out or the gear that pushes the lense out might have broken, in the case of the last three answers then a specialist might be able to fix it , or you might need a new camera, (i reccomend a fujifilm)
Jul 23, 2009 | Kodak Easyshare C813 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 08, 2009 | Kodak EasyShare V1003 Digital Camera
Kodak EasyShare P850 Digital Camera Logo
74 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
