Question about IBM ThinkPad R52 Notebook
Drives are opened in other window
Whenever i restart my laptop the autorun.inf originated and drives couldnt be opened up in same window
i have deleted them 100 times through CMD but couldnt rectified
how it can be deleted forever without reinstalling the operating system
How to delete this threat autorun inf everytime i scan my computer it always appear
Posted on Aug 12, 2008
    Genius:
  • 2,785 Answers
Have you tried msconfig, if not then type in run msconfig then in startup tab disable all apply then ok, restart
Posted on May 29, 2008
Whenever i used to insert chip drive with chip it is showing autorun.inf virus
How to remove autorun.inf in your flash drive or hard disk
Sometimes for virus or trojan horse you may difficulties opening your drives. Your autorun.inf is infected if you find any abnormal language when you right-click on a drive. This autorun.inf file is hidden and you will not see the file even though you select to show your all files from Folder Options.
1. Goto Start --> Run and type cmd then click OK.
2. If you want to remove the infected file from drive C: then type C: then press Enter.
3. Type "autorun.inf" and press Enter.
4. Type "del autorun.inf" then press Enter. The file is in the drive but not showing or you can't delete it now.
5. Now type "attrib autorun.inf -s -h -r" and press Enter.
6. Now delete the file by typing "del autorun.inf" and press Enter.
7. Restart the computer.
Good Luck!
Mar 02, 2011 | Computers & Internet
Tip
Drive not open on 'double-click'
Open 'Notepad' and write following code.
[autorun]
open=C:\Windows\explorer.exe
Save file as 'autorun.inf'.
Copy/replace this file on all drives/partitions that are not opening on double-click.
Restart PC and now all drives should open with normal double-click.
on Aug 26, 2010 | Computers & Internet
Tip
How to remove Autorun.inf
Here are some typical malware which can install autorun.inf.exe file to your computer and give your computer a critical strike.
Autorun.inf virus contains three execute files which are kavo.exe, ntdelect.com and autorun.inf. All of them are hidden files. You cannot find the by showing hidden files. The only way to find them is to use DOS command.
Not all user have computer savvy. I was suffered from this virus a lot. Success got rid of it using RegTool and want to share it with you.
To remove Autorun.inf
Tools you need RegTool and AVG anti-virus.
Also here is an easy way to remove Autorun.inf manually!
click Start>Run>enter “CMD” them you will see and command window. In the command prompt, you can search for any exe.files. First we can disable “read only” and “hidden” attributes.
Enter the word in prompt.
Check C drive: key in dir c:\/a/w
2 then
attrib -s -h -r c:\autorun.inf
attrib -s -h -r c:\ ntdelect.com
You can use the same way to disable attributes of other drive such like D, E, etc.
3 OK, everything is done, we can now remove these two files.
For C drive, you can enter
del c:\autorun.inf
del c:\ntdelect.com
The same to D drive
How about kavo.exe? You need to repeat step1 and step 2 to disable attributes.
The delete command is different with them.
attrib -s -h -r c:\windows\system32\kavo.exe
del c:\windows\system32\kavo.exe
last thing you should do:
Open registry editor by entering Regedit.
Go to HKEY_LOCAL-MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Remove Kavo value.
on Jun 01, 2010 | Computers & Internet
D drive not open.
If it happens to you that you are not able to open the drives by double click, then your system may be infected with virus. When this virus infects your windows, it automatically creates a autorun.inf in the root directory of each drive. This autorun.inf file is usually hidden, read only and is a system file. This virus also disables folder option. This is not a major problem and can be fixed by deleting autorun.inf file.
  1. Open Start > Run. Now type cmd and press enter. Command prompt window will open.
  2. Type cd/
  3. Type attrib -r -h -s autorun.inf
  4. Now type del autorun.inf
  5. Now type d: and press enter for d: drive partition and repeat steps 3 and 4.
  6. Repeat step 5 for all your hard disk drives.
  7. Restart your computer.
Jul 30, 2010 | Symantec Norton Antivirus 2009 1-User -...
I Have a computer its local drive d,e,f cant open when we double click over it give massage open with to select a program but when i explore local disk it has been open plz give me proper solution to solve...
Its Virus Problem.. Install Bit Defender Total Security 2010 or Mcafee Enterprise 8.7i with latest patch. Scan the entire Drive.. Delete all Autorun.inf files on the above said drives.. this solves your problem..
May 29, 2010 | Computers & Internet
Tip
How to remove AUTORUN.INF file from pendrive or block AUTORUN in PC
The Microsoft Windows Operating Systems use the AUTORUN.INF file from removable drives in order to know which actions to perform when a new external storage device, such as a USB drive or CD/DVD, is inserted into the PC. But there is large amount of malware-related problems associated with Microsoft AutoRun.
Follow the steps below to remove Autorun.inf from Pendrive:
1.) Open Notepad and do not write anything in it. Go to File > Save as autorun.inf
2.) Copy the autorun.inf file that you have created in the above step and paste it in your “Pen Drives”
3.) Remove your pendrive.
4.) Re-insert your PC. Now your pendrive is safe to use.
5.) Or simply use Panda USB and AutoRun Vaccine utility.
on May 13, 2010 | Computers & Internet
Tip
Windows Cannot Find "Copy.exe"
When i installed AVG Free last time it removed few virus including "copy.exe". so whenever i go to "My Computer" (win key + E) and double click on any hard drive then i find an error stating that (Windows cannot find "Copy.exe").
Solution:
Well the solution for this "copy.exe" conundrum is to get rid of a file called autorun.inf in each of the infected hard drives. here's the solution for the problem......
Make sure you or the virus scanner is run through the infected hard drives/flash drives. to make sure the virus files is gone.
Now, some forums said you could just select "Show Hidden Files" from the option and this would enable you to see "autorun.inf" file.
Also, some entries in the "autorun.inf"may be legitimate. so to check the file (even when you can't see the file) do this: Type in the infected hard drive label followed by autorun.inf for example f:\autorun.inf
This will load autorun.inf file in notepad.if the only entry is that incriminating copy.exe then this is what i did. i tried to overwrite the file with the same name autorun.inf. that din't work because autorun file was readonly. so i saved that blank file on the desktop and simply cut it and pasted it into the drive, then selecting the overwrite option. that should stop that annoying windows cannot find "copy.exe" message every time you double click into a drive. this will solve the problem!
Read more: http://comsguru.blogspot.com/2009/12/windows-cannot-find-copyexe.html#ixzz0nMpOFGpo
on May 08, 2010 | Computers & Internet
Autorun.inf open error in flash drive
open My Computer, and right click on "explore" to get your files. Then install a good anti-virus program, such as Avast! Anti-virus (avast.com) and clean off your (possibly) infected hard drive and computer.
Dec 28, 2009 | Microsoft Windows Vista Home Premium with...
Error : em8tqm.cmd
may be it cause virus praveen
go to start button and click run
and type cmd
then type
cd\ and press enter
then type
attrib -r space -h space -s space autorun.inf then enter
ex: 1. attrib -r -h -s autorun.inf enter
2. del autorun,inf enter
after that go to d: and press enter
Apr 08, 2009 | Microsoft Windows XP Professional for PC
Unable to delete the autorun.inf
hi azhar here form Karachi it is very easy. do, the below steps
reboot ur PC in safe mode with command prompt
when u bring a dos screen just move to ur drive mostly virus stayed in d: drive got d: drive and type
d:dir/ah and press enter
if u see there any auto run.inf file there also should be another file like .exe file or .bat or any kind of unknown , file so for delete the auto run file type attrib -s -h -r autorun.inf and press enter
then type del autorun.inf and hit enter here u go u have done.
do the samr process in all drives because mostly autorun.inf file make copy in all drives
remember autorun inf is just a file which help the virus to run autometicly
Feb 12, 2009 | Microsoft Windows XP Professional With...
IBM ThinkPad R52 Notebook Logo
51 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
