Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
The Expandable Tube has come out of its plastic holding leaving the plastic holding still in the wand arm how do I release this Plastic hose clip so I can replace the flexible hose
  • 171 Answers
If you force anything on these plastic vacuums you will break something and be worse off. I recommend taking it to your local used Vacuum store as they can give you the best advice by seeing the pieces. Thanks hope this helped
Posted on Oct 07, 2010
Take hose off to clean
Pull out handle as usual.
Release hose from wand and handle by pressing the pair of release clips on the handle just above where the hose enters. I have to press these clips quite hard and pull quite a bit to get the hose to come free. All the above is as you would normally use the hose.
Lay hose down to rear of machine. Just between the bottom of the hose and the machine body is a small plastic tab: pull this a little away from the machine body.
Slide bottom end of hose upwards and out of the machine.
The hose can be dismantled from the plastic fittings at each end but has not been designed for the user to do so: the hose and fittings are bought as an assembly (not expensive at about GBP15).
Jul 05, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
The telescoping wand on my Dyson DC 25 will not retract back into the hose.
Hi Nina, it's Jack at Dyson.
Difficulty collapsing the wand can mean that the plastic handgrip section hasn't been correctly placed on the machine. When you replace the wand on the machine, make sure the handgrip section clips onto the main body and is down as far as it will go.
It's also a good idea to make sure that the hose isn't twisted, as a twisted hose can create resistance as you try to collapse the wand. Remove the wand again and allow the hose to untwist itself fully before attempting to replace the wand on the machine.
I'm confident these steps should resolve the issue, but if you would like some further guidance after you've given this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 20, 2014 | Dyson DC-25 Lifetime Washable & Reusable...
Where to buy the plastic ends on the extension tube for DC 05
As the DC05 wand is supplied as a complete assembly, we're unable to offer the locking clips separately. If you'd like to buy a replacement wand, you can do so directly from us by visiting our online store:
http://www.dyson.co.uk/store/spares.asp
If you'd prefer to order over the phone, or speak to one of our experts before making a purchase, please call us free on 0800 298 0298. Our Helpline is available from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Dyson Online Customer Support
Nov 10, 2011 | Dyson DC05 Bagless Canister Cyclonic...
The clip inside the hose for holding the tube (small yellow spring clip) is broken or needs anew one
I'm sorry to hear you're having difficulties with your DC07. If the wand release button on the hose cuff has broken, the hose assembly will require replacement. If you wish to order a new hose assembly, you can do so by visiting www.dyson.com and clicking on 'Spares'. Alternatively, if you'd like to order by phone, you can get in touch with us directly by calling free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Sep 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Power nozzle shuts on and off
HI There, When a Kenmore power nozzle cuts on and off, this usually indicates that your electrical hose has gone bad and has a short circuit somewhere. You can try and troubleshoot the hose to find out where the short is by trying to determine what position the hose is in when it cuts on and off, and try to isolate the short circuit by spinning the hose on both the end that plugs into the canister, as well as the end that plugs into the wand. Sometimes the short is in the wands, or even the swivel neck assembly on the power nozzle where the wands connect. I would say 9 times out of 10 though on Kenmore canisters, the problem is in the hose. Kenmore is actually manufactured by Panasonic, and the two brands use a lot of the same identical parts, including the electrical hose (most cases). If your Kenmore has a two position switch, with a setting for floors and carpets, then here's a link to the corresponding Panasonic hose that you can buy. The Panasonic hoses are a little more expensive then Kenmore, but the huge benefit is that they come 100% completely assembled, where as the Kenmore hose has to be assembled (which is extremely difficult even for me to do). Panasonic 3 Wire Electrical Suction Hose To Fit Kenmore Canisters On just a handful of Kenmore models, an additional modification has to be done with the internal switch. Kenmore must have had the hose modified so you'd have to buy the genuine Kenmore part, but luckily simply switching two wires on the switch will allow the Panasonic hose to work. Try just plugging in the hose into the vacuum first, and if it still doesn't work properly, then you can modify the switch. If you find that the short is in the wand or swivel neck, just use the comment field on this repair page and let me know, I'll be happy to follow up and walk you through either of these repairs as well. If this was helpful to you, please be so kind and rate the repair, or leave some feedback for me. This is greatly appreciated. Chris Jones GoVacuum.com
Jun 15, 2010 | Kenmore 22612 Bagged Canister Vacuum
When running the 2100 Electrolux vacuum, it is stopping and starting when pulling or pushing the floor attachment. Seems like the connection at the top of the handle is a little loose or the electric tabs...
Depending on the age of your 2100, you will need to replace, the wand cord, the handle wiring and perhaps theh upper wand inner tube and handle as well.
If you examine your cord contacts they will be blackened from slippage, so will the female socket they plug into. On and aging 2100 the 1/2 inch groove at the front of the chrome handle tube begins to wear and the metal inner tube clip under the thumb button of the wand develops play back and forth. The wand comes apart into 4 pieces, plastic sheath, upper and lower tubes and cord assy.
If the hose handle groove is worn enough to allow in and out play, you will need to replace the handle, it's wiring, and at least the clip button on the upper wand as well as the wand cord.
You will find these wand parts at a pro vacuum shop but if your hose is original you will need to go to an AERUS Electrolux repair center for parts.
Post back with your results.
Nov 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Got pipe out - can't get it back in
The pipe should have a plastic holder at the bottom of the hose, providing its still in tact.
If it is then do the following:
1 take the wand off the hose so the hose is bendy
2 the plastic holder at the bottom of the hose should slide in to the main body and clip in if you are still having problems take off the inspection valve where the hose fits in and then try again.
If the plastic on the hose is broken, then buy new hose.
Sep 18, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC-07 Hose Wand Spring Came Out. How to put back in?
You'll see that there is a round piece with a cross shape on the inside of the button wand release button - place the end of the spring over the cross - you'll see the same cross on the collar of the machine...it'll take some doing, but line the other end of the spring up with the cross and pop the button back into place - be sure to click it onto those two gray circular/oval shaped divets at the bottom where the release button connects to so that the button stays in place.
Jun 25, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc07 animal bagless
You probably have a blockage somewhere in the hose or in the base where the hose goes in. Remove the plastic tube at the base of the hose by simply unclicking it and remove the obstruction.
Nov 07, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
48 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
