Question about Hawking 802.11g Wireless-G Range Extender
Hawking 300N Wireless Range Extender Setup OK and can get internet OK but can't print to network printers. Can see them OK if I access the "base" wireless network. Any ideas?
2 Suggested Answers
SOURCE: hawking extender hangs
They just issued new firmware: http://www.hawkingtech.com/support/details.php?CatID=32&FamID=105&ProdID=394#Firmware
You might try that...
-Tom-
Posted on Dec 31, 2008
Hawking Hi-Gain Wireless 300N Range Extender Pro installation
How far did you get when you followed the user's manual?
What stumped you?
Sep 02, 2014 | Computers & Internet
Hwern1 hi gain wireless 300n range extender
what issue are you facing? its not connecting to your existing wifi network ? let me know if you want me to call you if u r in US
Dec 06, 2013 | Hawking HWREN1 Hi-Gain Wireless-300N Range...
My Hawking 801 is 2 years old. It has started losing its configuration. I launch the set up CD, follow the instructions, put it within range of the main wireless router and in less than 30 minutes it...
First thing you need to do is setup the IP, Subnet Mask, and Gateway of
your extender. Before any connection of the extender, we have to find out the IP of the router. Start Menu Run Type "cmd", hit enter In the black command prompt window, type "ipconfig" The ###.###.###.### to the right of default gateway is the IP of your router.
For example...192.168.1.1
Now you can either connect the extender directly to your computer or
to the router.
Use the wizard to find the extender and to change the information of your
extender to...
For example based upon the above #...
IP: 192.168.1.*** (Subnet: 255.255.255.0
Gateway: 192.168.1.1 ( The *** can be any # up to 250 except for the routers...typically we use 235.
After the wizard saves and reboots the print server, connect it back to the
router or leave it there.
Then open up your Internet Explorer and in the address bar, put in the
Address of the router in (192.168.1.235).
It should come up and ask your for the username/password (admin/1234) if it
doesn't then power cycle the device.
On the main page of the extender, fill in exactly the wireless
settings of your router here.
Make sure you fill in...
SSID Channel
Encryption
After you save, you should be able to disconnect the extender via lan cable
from the router and use it wirelessly.
link is here
Oct 09, 2011 | Hawking 802.11g Wireless-G Range Extender
How to setup up for repeater mode
This particular Hawking device must be configured after it is connected to your LAN and powered up.
Before you can do this, you will need the software from Hawking. If your devices Serial Number begins with HEMCHWREN1 use the link below"
http://hawkingtech.com/products/downloadfile/114.html
If you have a Revision 1 device with a Serial Number begins with HEMCREN1R1 use this link:
http://hawkingtech.com/products/downloadfile/117.html
Once you have the software, here are the steps you need to follow:
  1. Connect the A/C power adapter to an
    electrical source, and then connect it to the
    'Power' socket of the Range Extender.
  2. Connect your Range Extender to a LAN
    port on the Router or AP that you would
    like to extend (repeat) the range on.
  3. Connect your PC to any of the LAN ports
    located on the back of your router/AP.
  4. Now run the appropriate program you obtained from the instructions in the beginning of the answer.
When the auto-load page appears, click the Setup Wizard option on the right and follow the Setup directions.
Scan for your Range Extender by clicking the 'Search' button. Once found, click the device to highlight it and click 'Next".
Choose a name for your Range Extender. You will use this name to identify and connect to your extended network. Optionally, you may change your login username and password. Click 'Next'.
At this point, the Setup Wizard should automatically obtain a new IP address for your Range Extender from the Router. Please wait for this IP to generate into the IP address field. Note the new IP address and click 'Next' to continue.
In the Search box, find the Wireless Network that you would like to extend. This Range Extender works best with other wireless-N networks, but also supports wireless-B and G networks as well. Select your preferred network and then click 'Next'.
For Security Settings, you must make sure that the Range Extender's security settings are identical to that of the Router/AP that is having the signal extended. If you do not know these settings please contact your network administrator.
At this point the Setup Summary displays all configured settings of the Range Extender. If the information displayed corresponds to your desired networks settings, you can go ahead and click 'SET' to apply the settings. The HWREN1 will automatically reboot. Please be patient.
More information can be obtained on the hawking site:
http://hawkingtech.com/products/hi-gain_wireless_networking/range_extenders_&_repeaters/hwren1.html
Sep 24, 2011 | Hawking Hawkin HiGain HWREN1 Wireless300N...
How To Use a Belkin Wireless G Router as a range extender? I'm trying to hook my Xbox to the internet, the problem is that the xbox isn't wireless and internet comes from a wireless modem and is...
You can Convert the Router as an Access Point But your Wireless Modem Should Be Hard wired to router. But if your Router has an wireless Bridge Option in it you can Convert it as an Range Extender. Check For the Wireless Bridging Feature on your Router or Please Post your Router's Model Number Here. I Will Be Glad to Help you out... :)
Mar 12, 2011 | Belkin N1 Vision Wireless Router
Hawking wireless 300n Won't Reconnect if Router
try turning on an open NAT configuration, opening your ports on the router, look for tutoriales on how to do so.
this will probably solve your problem
Mar 03, 2010 | Computers & Internet
Hawking Extender- Connected to WiFi but cannot access Internet
First think I always do is Reset Linksys Router and disconnect extender. Then turn off all security on router. Do soft reset on ipod. leave extender off and see if you can connect to the linksys. If you can then plug in extender (still with security off) then see if ipod connects to extender.
you might have to soft reset ipod again once you connect the extender.
if that works. reset security. Let me know how that goes.
Jan 01, 2010 | Hawking 802.11g Wireless-G Range Extender
Wireless extender Hawking 300N. Can you tell me what color the wireless connection light should be, green or yellow? If green what does yellow emply, on steady but not blinking even during operation?...
Green is good, yellow you can have several issues. The least obvious is a loopback which is usually caused when the primary wireless and the extender are duplicating IPs between themselves or another unit. This can also happen when two extenders come within range of one another or when the extender is also used as a wireless node and the IP range is the same as the primary network.
Dec 11, 2009 | Office Equipment & Supplies
Hawking extender hangs
-Tom-
Dec 26, 2008 | Hawking 802.11g Wireless-G Range Extender
Open Questions:
Hawking 802.11g Wireless-G Range Extender Logo
184 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
