Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
1/2 horsepower unit......it hums when turned on but does not turn. I have also been able to turn manually with the wrench.
  • Ace Hardware Master
  • 43,501 Answers
Hi, The motor has gone bad...
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Posted on Oct 22, 2010
Kitchen aid kadette 250
with the power "off", check inside the unit to make sure nothing is jammed in there. assuming the interior is clear, try the reset button which is usually located on the bottom of the unit. may need to use a mirror and a flashlight to locate it. if the unit hums (indicating power is there) but it does not rotate/turn/work, use your "disposal key" or a hex wrench to turn it manually: usually inserts on the bottom-middle of the unit; turn it both ways to free it up.
Jul 05, 2013 | Garbage Disposals
Disposer is making a humming sound.
If your disposal is humming but not grinding then shut unit off and use a 1/4 allen wrench in the opening on the bottom of disposal in the center and turn it back and forth with the wrench till you get it freed up. There should be a offset wrench that came with the disposal for this purpose but if you don't have it a regular allen wrench will work. Try running hot water thru disposal while you are turning with allen wrench to help loosen up grease. After you get it turning freely remove allen wrench and turn disposal on . Hopefully this will take care of it but if not repeat until it frees up.
If your unit stops look on the bottom of the disposal for a small red button. This is a reset button. Push it and see if it will run. Hope this helps you. Thanks and have a good year.
Jan 04, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator hums but does not gring. What to do? Tim
Hey Tim. I can help you look into the obvious and perhaps most inexpensive problems to fix.
At the bottom of the ISE there is a hex type hole in the center of the bottom plate. This is for an allen wrench of the appropriate size, a wrench usually comes with the units when they are new. UNPLUG the unit under the sink and insert the allen wrench into the hole. You can now use the allen wrench to manually turn the cutting blades inside the ISE. You may find something wedged in the blades that needs to be removed, family silverware, dog collars, etc. As long as the unit is unplugged you can reach inside and clear any debris. You will also find a small button on the bottom of the ISE. This is a circuit breaker and does trip from time to time. You just need to push it in to reset it. But since your unit is humming, I doubt the breaker is tripped. Feel free to contact me if you have questions.
Sep 15, 2010 | Emerson Vacuums
Garbage disposal won't turn on; when I turn on switch, I can hear a humming sound.
Sounds like the cutting blades are bound up. Unplug the unit under the sink and insert an appropriate sized allen wrench into the center of the motor shaft on the flat end of the ISE; the lowest point of the unit under the sink. This allen wrench will allow you to manually turn the cutting blades and possibly free whatever may be binding them up. DO THIS WITH THE UNIT UNPLUGGED! You may have to look into the top of the unit to see if there is something you have pulled free that should be removed prior to using the ISE again.
Sep 06, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sinkerator will only "hum" and not run to grind food
On The bottom of the unit there should be a place to put an allen wrench. Unplug unit, Insert wrench and turn the wrench back and forth this moves the blades if the blades move freely then nothing is stuck. If wrench does not move freely, with flash light inspect inside of disposal (the rubber flaps are usually removable to gain better eye site) if objects (bones, utensil, etc) are noticed remove them and try the wrench again if now freed problem solved. If wrench turned freely from the beginning and motor still hums. Replace disposal.
I hope this has answered your question, please rate how helpful the answer was. Good Luck and Have a great day.
Apr 03, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Still doesn't run.
well, the impeller is slipping on the motor shaft, you need to remove the unit and see whats up
Aug 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In sink erator( 5 horsepower) doesnot function
On the bottom of the disposal is a place for an allen wrench. Take and turn the unit with the allen wrench to break it loose. It sounds as if has something sticking the blades.
Jun 03, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Kitchenaid Kadette hums and does not run
Mine does this when it is clogged, one time my daughter cleaned out the fish take and filled the disposal with pebbles. You should have recieved an Allen wrench with the unit. You will be able to put the Allen wrench in the bottom of the unit and turn the disposal manualy, this should break loose any jammed blades.
Apr 02, 2009 | Kitchen Appliances - Others
My Badger 5 garbage disposal will not work. It makes a humming noise but will not spin. I hit the reset button, used the hex wrench provided and turned it clockwise, used a broom handle through the top and...
I had this same problem after my wife tried to clean out a fish bowl (she said she skimed out all of the little pebbles). She still missed a lot of them and many ended up in the disposal. Anyways it made the same humming sound when turning it on. This humming noise means something is jamming it from spinning. The hum is just the sound of the motor trying to spin (DO NOT LEAVE IT HUMMING FOR A LONG TIME)
HERES HOW TO FIX IT:
-If you have a lot of whatever's causing the jam still in there, I suggest you take out the disposal and flush as much as possible out with water (I had to do this to get majority of the rock pebbles out) while holding it upside down.
-Now you need a decent tool set, get a 3/8" ratchet, 7/16" deep socket, and a 3" extension.
-It's easiest if you put the disposal back in the sink to do this step as it may take some muscle and the sink will hold it in place.
-If you look down into the disposal from the top of the sink you should see a nut in the middle of the disposal (and the 2 silver spinning teeth on the sides).
-The nut in the middle is what you need to get the ratchet on.
-Now just muscle the ratchet clockwise for awhile then counter-clockwise for awhile and repeat if necessary until the rotor spins completely freely. When there is completely no reistance when turning it you are done.
-Pull the ratchet out and try turning on the disposal. If you did the above step correctly then if should turn on like normal.
Congratulations you just saved yourself from calling a plumber!!
Apr 17, 2008 | Badger Basket 1905 Round Doll Bassinet
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
154 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
