Right, i just installed ubuntu, then overwrite my vista drive, i have a vista disk but i don't know how to overwrite the linux bootloader with vista. last time i tried this if failed.
  • 25 Answers
To re-install Windows Vista please do the following:
Put the disc in and restart the computer
Boot from the disc
Do a full system install
Delete your partition [contains Ubuntu(Linux)]
and install.
I recently did this last week, went from Ubuntu back to windows 7, and currently I duel-boot both Operating Systems. I hope this helps!
Please don't forget to rate :), Thanks!
Posted on Oct 07, 2010
Testimonial: "will this work for windows 7 enterprise trial, my vista disk just broke :)"
  • satorey Oct 12, 2010
    I apologize for the late response due to Thanksgiving weekend, I am not 100% sure if it will work on a trial. If you haven't used your trial and you still have xxx amount of days then I don't see why not. As long as it will allow you to install the windows 7 OS then yes this will work. I would back up all your ubuntu files just incase you need to do a new ubuntu install.
Can i reboot my ps3 using lenux boot disk
Yes, Ofcourse.
Instructions
    • 1 Select and download a Linux distribution to download. Your options are Ubuntu, Fedora, OpenSUSE and Yellow Dog. Ubuntu and Yellow Dog have better support for PS3 than OpenSUSE and Fedora. Links are provided in the first Resource.
    • 2 Locate the boot loader included with your Linux distribution of choice and rename it to "otheros.bld" so the PS3 recognizes it. Your bootloader is either named "kboot" or "petitboot" followed by a version number.
  • Create a folder named "PS3" on the CD or Flash drive. Create another folder named "otheros" inside the "PS3" folder. These folder titles are case-sensitive--enter them exactly as they appear here.
  • 4 Save the "bootloader.bld" file in the "otheros" folder. If you are using a CD, burn it now. See the second Resource on how to burn a CD using tools included in Windows.
  • 5 Insert the Flash drive or CD into the PS3.
  • 6 Go to the "Settings" column of the PS3 main menu, select "System Settings," then "Install Other OS." The PS3 then searches for and starts installing the boot loader from the Flash drive or CD.
  • 7 From the "Settings" column again, select "System Settings," then "Default System." Choose "Other OS" from the options listed on the right.
  • 8 Burn the .iso of your Linux distribution of choice to a CD, if you want to boot the PS3 from a CD. If you're using a Flash drive, see the third Resource on how to put a running Linux installation on a Flash drive.
  • 9 Remove any disc already in the PS3 and turn it off.
  • 10 Insert the CD or Flash drive. The Flash drive goes into one of the PS3's USB ports, located on the front face, in the bottom right-hand corner. If you insert a CD, the PS3 automatically turns on.
  • 11 Turn on the PS3, if it hasn't turned itself on already. Select your Linux distribution from the boot loader menu to boot the PS3 from the Flash drive or CD.
  • Jun 05, 2013 | Computers & Internet
    Where can i get a copy of the operating system for an acer aspire 4720z vista
    Its normally stored on the hard drive of the PC in the recover partition of the hard disk drive.
    If you've formatted the hard drive without burning a recovery disk, you can try contacting ACER via their web site and ask for assistance. You could buy a copy of Window Vista. But if you decided you need to buy a new operating system buy Windows 7 instead, its much better than Vista.
    If however you don't want to buy an operating system and be legal. Then you can download and install one of the Linux based operating systems for free. I like Ubuntu best, but there are others.
    Just google Linux or go straight for Ubuntu :- http://www.ubuntu.com/
    Apr 08, 2011 | Computers & Internet
    I will ask if i can download windows 7 on linux acer aspire 4738?there will be a problem?
    there won't be any problem as far as Windows and Linux, but this is a fairly involved procedure.You'll first need to create a Windows partition on your hard disk in NTFS file system format. Otherwise,Windows might overwrite / erase your linux installation when Windows 7 installs.
    make the windows partition the "Primary" or "Boot" partition.
    When Windows 7 installs, it may ask if you want to delete the linux partition.Answer "NO" to this.
    The next concern is which operating system will boot by default,Windows or Linux.
    I had no problem doing this with Windows Vista, and whe Vista booted,it listed a choice of operating systems to boot,and I would select either Windows Vista or Ubuntu Linux.
    Apr 03, 2011 | Acer Computers & Internet
    How to install linux fedora 7, already i am using windows 7, now i want to use dual os's , please tell me how to install linux.
    WARNING: I will not be responsible for any data loss that occurs. It is recommended to backup your hard disk to external media before commencing any of these operations. 1. Download and burn the Fedora LiveCD. It is recommended that you use the latest version, Fedora 14, instead of 7, but you can use Version 7 anyways. 2. Boot up with the Fedora LiveCD. Select Install. 3. Follow the instructions displayed onscreen. When you reach the partitioning screen, you will need to resize your Windows partition. Resize it to a reasonable size (1024MB =1GB). Leave at least 5GB for Fedora to install. 4. After resizing, select the "Use Free Disk Space" option, and continue installing. 5. Your system will be installed with Fedora and the GRUB bootloader. The GRUB bootloader will allow you to boot into both Windows and Fedora.
    I hope this post helps you. I appreciate your vote very much!
    Mar 03, 2011 | fedora Linux Operating System
    OXCOOOOOOF I was doing disk partition
    Grab a copy of :
    EasyBCD is NeoSmart Technologies' multiple award-winning answer to taking control of your bootloader. EasyBCD extends and revamps the Windows Vista/Windows 7 BCD bootloader, and with EasyBCD, almost anything is possible. Setting up and configuring a dual-boot between Windows 7, Windows Vista, older versions of Windows such as XP & 2003, Linux, Ubuntu, BSD, and Mac OS X is a breeze. You just point & click and EasyBCD does the rest.
    EasyBCD is geared for users of all kinds. Whether you just want to add an entry to your old XP partition or want to create a duplicate for testing purposes; if you're interested in debugging the Windows Kernel or septuple-booting your seven test operating systems, EasyBCD is the key.
    • Boot into XP/Vista/7/Ubuntu/OS X and more!
    and if :
    Your "BOOT" folder has been deleted, was not created, or has been corrupted; and the Vista bootloader will not show.
    Solution Boot into a working copy of Windows and install/run EasyBCD.
    Go to the "BCD Backup/Repair" page:
    Select "Re-create/repair boot files" then "Perform Action" to begin recovery. EasyBCD will recreate (if possible) your boot files and re-configure your bootloader from scratch.
    If EasyBCD fails, that means a process has locked your BOOT folder. Manually delete this folder with a Live CD, recovery console, or other method, then try Type Three again.
    Dec 11, 2010 | Toshiba Satellite P205-S6287 Notebook PC
    Ubuntu installation
    Relax Sairam -- you don't have know all these answers.
    First step, download Ubuntu and burn to a CD .
    Second adjust your bios if necessary to change the boot preferences on your machine, so that it will try your CD/DVD device first before trying to boot from a hard disk.
    Third, let the Ubuntu Live CD execute and bring up a desktop. On the desktop, there should be an icon to actually install Ubuntu. It will guide your through all the decisions that you need to make.
    You may find it advantageous to have a "dual boot" configuration on your machine... i.e., having the choice of running some windows operating system, or ubuntu.
    Apr 11, 2010 | Dell Inspiron 1545 Notebook
    How can I uninstall Ubuntu from Dual Boot. I have a dual boot of Windows Vista Ultimate with Ubuntu 9.04 The specs of my computer is 2gb ram, 500 gb HDD and dual core processor 2.66ghz (E5300). I installed...
    How to remove Ubuntu from a Vista dual-boot config
    On my new PC I wanted (still want) to have toa go with Linux. I chose to experiment with Ubuntu. I downloaded thedesktop CD, burned it, freed up some disk space (inside Vista) andloaded up Ubuntu from the CD. After some experimenting I figured outhow to install Ubuntu in the empty disk space and it all worked fine(GRUB took over my booting (recognized Vista automatically!) and Ubuntuloaded up fine).
    Then I tried to install my GPU drivers andeverything went wrong.. For some reason Ubuntu wouldn't boot anymore(failed to load X-Server or something). I was completely lost andwanted to remove Ubuntu.
    This is where things start to get really messy!
    Ifyou simply remove the Ubuntu partition, GRUB (Linux boot loader) willstill be on your PC (in control). It will trip out, as the Ubuntupartition will be removed.. Bad thing!
    So you need to restore your Master Boot Record (MBR) for Vista (so that Vista will handle the booting, not GRUB).
    Googleonly pointed me to sites that explained how to REMOVE VISTA, whichisn't what I wanted. Many sites talked about the 'fixmbr' command, butthis is really only available in Windows XP.
    So how do you restore your MBR for Windows Vista?
    1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
    2. Press a key when you are prompted.
    3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
    4. Click Repair your computer.
    5. Click the operating system that you want to repair, and then click Next.
    6. In the System Recovery Options dialog box, click Command Prompt.
    7. Type Bootrec.exe /FixMbr, and then press ENTER.
    That'sit. Now when you reboot your PC, Vista will load automatically... Youcan now safely boot using your Ubuntu desktop CD, to use the built inGnome Partition Manager to remove your Ubuntu partition!
    Apr 06, 2010 | Microsoft Computers & Internet
    Dual Boot problem in Windows XP & VISTA
    Don't try to edit the xp boot.ini or the vista bootloader. It only leads to other problems and headaches.
    Try this first: Take note as to which drive has vista on it, put your vista installation cd in the drive and let it boot to the "installation window", then choose "repair", then "startup repair." Make sure you choose the drive that already has vista on it. Let that run and when it re-boots you should then be given a choice to boot to vista or "other windows".
    There is also a (free) program called EasyBCD. Download that, read the directions and have at it.
    If none of that works, you'll have to do a clean install. Install XP on one drive first, then Vista on the second drive in that order. The Vista bootloader will pick up the XP. However, XP is NOT forward compatible and will not recognize the Vista bootloader. Make sure that you don't have any flashdrives or media cards plugged in before doing the install.
    Another approach would be to shrink the Vista volume, creat a new partition, then install Linux Ubuntu that partition. Linux will detect all of the OS's and create a boot menu. Unfortunately, you'll lose about 5 gigs to the Linux OS and it's swap partition, but then, you get to goof around with Linux :-)
    Feb 25, 2009 | Microsoft Windows Vista Home Premium with...
    Downgrade from Vista to WinXP Pro
    No, you need to go into your computer's BIOS and set the ahcp mode to IDE. Then windows xp will see it just fine.
    Please take a moment to rate as fixya. Thanks!
    Feb 06, 2009 | Acer Extensa 4620 Notebook
    Dell laptop not working
    Please take a moment to rate our chat.
    Jun 22, 2008 | Dell Inspiron 1501 Notebook
    Computers & Internet Logo
    81 people viewed this question
    David Payne
    David Payne
