Question about Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50"
How do i remove front wheel on lt1046 - Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50"
2 Suggested Answers
  • 123 Answers
SOURCE: Cub Cadet Problems
Sorry it has taken so long to reply, busy time of year. It is very possible the wheel bearings are going bad, but you should notice it at all times. Some lawn and garden tractor front wheels are that way for steering. The John Deere lawn tractors are toed in for example. Wouldn't hurt to check the wheel bearings as well as the spindle bearings. They should all be greasable, and if the issue is better after greasing, you have found your problem. If not, let me know and I will see what else I can come up with, Daniel.
Posted on Nov 04, 2011
White smoke comes from front of the mower when you first start the engine.
It just take a couple of starts to disappear - of course, if you removed all the creepers from inside
Aug 07, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub Cadet Problems
Oct 23, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Front tire is off rim. Can this be fixed?
Find a local lawn mower or small engine repair shop in phone book and take it to them.
Oct 03, 2010 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I am trying to get the wheel assembly apart to change the front bearings on a 1996 mercury villiger
http://groups.yahoo.com/group/villagerquest/
Item Part Number Description 1 — Cotter Pin 2 — Nut Retainer 3 1131 Insulator 4 3B477 Front Axle Wheel Hub Retainer 5 1195 Front Wheel Outer Bearing Retainer Washer 6 1104 Wheel Hub 7 1107 Lug Bolt 8 3K050 Snap Ring 9 3123 Front Wheel Bearing 10 2K004 Front Disc Brake Rotor Shield 11 3130 Front Wheel Knuckle
Wheel Hub, Wheel Knuckle and Wheel Bearing SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Tie Rod End Separator T85M-3395-A
Removal
  1. Raise and support the vehicle.
  2. Remove the wheel (1007) and tire assembly.
  3. NOTE: It is not necessary to disconnect the front brake hose (2078).
    Remove the disc brake caliper (2B120) and suspend it with mechanic's wire out of the way. Refer to Section 06-03 for the removal procedure.
  4. Remove the front disc brake rotor (1125).
  5. Remove and discard the cotter pin.
  6. Remove the nut retainer and insulator.
  7. Remove the front axle wheel hub retainer (3B477) and the front wheel outer bearing retainer washer (1195).
  8. Remove and discard the cotter pin from the front suspension lower arm ball joint (3050).
  9. Loosen the front suspension lower arm ball joint nut until it contacts the front wheel driveshaft joint.
  10. Strike the front wheel knuckle with a hammer while pulling down on the front suspension lower arm (3078) until the front suspension lower arm ball joint separates from the front wheel knuckle.
  11. Remove the front suspension lower arm ball joint nut.
  12. Remove the front suspension lower arm ball joint from the front wheel knuckle.
  13. Remove and discard the cotter pin.
  14. Remove the tie rod end nut.
  15. Use Tie Rod End Separator T85M-3395-A to separate the tie rod end (3A130) from the front wheel knuckle.
  16. Remove the front brake anti-lock sensor bolt.
  17. Remove the two front shock absorber-to-front wheel knuckle nuts.
  18. Remove the two front shock absorber-to-front wheel knuckle bolts.
  19. Remove the front shock absorber (18124) from the front wheel knuckle.
  20. Use 2-Jaw Puller D80L-1002-L, or equivalent, to separate the front wheel driveshaft and joint (3B436) from the front wheel knuckle.
  21. Remove the front wheel hub, front wheel knuckle and front wheel bearing as an assembly from the vehicle.
  22. If necessary, match mark and remove the steering stop bolt and steering stop bolt jam nut from the front wheel knuckle.
Installation
  1. Position the front wheel hub, front wheel knuckle and front wheel bearing as an assembly on the front wheel driveshaft and joint.
  1. Install the front wheel knuckle into the front shock absorber.
  1. Install the two front shock absorber-to-front wheel knuckle bolts.
  1. Install the two front shock absorber-to-front wheel knuckle nuts. Tighten the front shock absorber-to-front wheel knuckle nuts to 113-123 Nm (83-91 lb-ft).
Apr 10, 2009 | 1996 Mercury Villager
Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50" Logo
99 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
