Question about Garden
I need a diagram for a Craftsman 50145 floor jack power unit
3 Suggested Answers
erickg
  • 116 Answers
SOURCE: floor jack needs sevice or seal replacement
you can do it two ways remove and match up the seals with a local distrubuter or try to find your make and model and order them.check your oil level also and the valve for dropping.
Posted on Apr 17, 2009
  • 67 Answers
SOURCE: craftsman 3 ton floor jack will not stay up
you need to bleed the air from the cylinder. there should be an air bleed or else you bleed it at the relief needle. also, if it still leaks down after you bleeed out the air, the seat for the relief valve or the seals at the relief valve cartridge are worn
Posted on Jun 25, 2009
Fuel filter location?
most are in the gas tank.
Easy job if you have a floor jack, 2 floor stands and wrench.
Empty the gas tank, place jack centered on the gas tank jack up the car, put the floor stands in place to hold the car steady, disconnect the wiring go to the gas tank then remove the bolts (most cars only have 2 holding the tank braces, slowly lower the floor jack with the tank on it, remove the fuel pump slowly and carefully as not to have anything fall in the tank.
https://www.youtube.com/results?search_query=remove+gas+tank
Dec 10, 2015 | Cars & Trucks
Craftsman lawn tractor will not move
There are a few things to look a. The belt, is it slipping or loose? Check and small idler pulleys from the drive belt to the engine. The large pully on the transmission is keyed to the shaft. If either the key is sheared or the shaft worn enough, the shaft will spin but not turn the pulley under load. Also note that the axles are keyed to the rear wheels. A sheared key there will cause it to not move also. You should see the axle turning freely inside the wheel if this is the case. Here is a parts diagram so you at lease have an idea of the areas to check.
Craftsman 917275810 diagram
Aug 22, 2012 | Craftsman Garden
I want to know how many engine mounts a 1997 sl2 saturn uses and if there is a diagram where I can see their locations in the car. Tanks
4 total. Two on the passenger side (upper and lower) and two on the driver's side, upper and lower. The "dog bone" type strut mount is the same for either side.
Jul 04, 2011 | Saturn SL2 Cars & Trucks
Purchased an alpine 3011 graphic equalizer that has no wiring diagram...cannot hook it up without knowing what wires do what
You are going to need the DIN plugs for the unit, on the back there are two imput jacks. The left jack is for the imput from your head unit, as far as I know, there is no other way for the EQ to accept imput except for the jack. The right one is for a digital time delay unit (rare). Coming out of the unit there are two output jacks, one is line out front, the other is line out rear. With these, there are also your power, ground, remote power, and speaker out puts. Good luck. I had one of these back in the 80's.
Nov 13, 2010 | Alpine Car Audio & Video
Floor jack won't stay
If you are having a problem with the jack slipping...if its Craftsman , they may take it back and provide a replacement. Even if you could fix it, it never works that same. It is not worth your life. I know, I lost my husband when a jack slipped 3 years ago this month.
Jun 01, 2009 | Hand Tools
Floor jack needs sevice or seal replacement
Apr 02, 2009 | Plumbing
Craftsman 3 ton floor jack will not stay up
Apr 01, 2009 | Home Fencing
2001 Saturn, need a Serpentine belt diagram
get a floor jack and a small block of wood. place the floor jack under the oil pan. jack up the jack until you feel it on the oil pan. remove the engine mount. you will need a deep 15mm socket and a 6inch extension. the mount has 4 bolts. remove it. then jack the engine up with the floor jack until the power steering reservoir almost touches the cowl. now take a long 14mm wrench and place that on the bolt head on the belt tensioner. pull the wrench until the belt slacks up. remove the belt. Installation opposite of removal. Here is a belt diagram. I hope this helps!! If you have any problems or questions e-mail me at: Redlinetech07@yahoo.com
Feb 23, 2009 | 2001 Saturn SL
Placement of jack beneath solstice
the best place for floor jacks is either under the rear axle or on the spot where you would place your OEM jack that came with the car your owners manual should have a diagram that shows you where these spots are.
Aug 28, 2008 | 2008 Pontiac Solstice
Garden Logo
165 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
