Question about Polti Eco Pro 3000 Canister Steam Vacuum
I plug my Polti in and absolutely nothing happens, no lights come on nothing, I've changed the fuse but still noting
  • 171 Answers
There maybe a broken switch or the motor may be burnt out. Take it to a used vacuum store and they will give you sound advice.
Posted on Oct 07, 2010
Filled with water, pressed both buttons and nothing happening ??
Are you sure it's plugged in and if so, is it plugged into a live socket?
Nov 02, 2013 | Polti 3000 Vaporetto Eco Pro Steam Vapor...
Mine is the polti vaporetto leco aspira. 4 years old. while using the vacuum only, it had a strange noise for a few days then the unit started smoking and died. can i change a part or is there a fuse that...
the vacuum motor might be overheated hence smoked and burned the winding, dissamble it it you can try to replace fuse with the same rating only. if there's no fuse then motor winding already burned.
Feb 02, 2011 | Polti AS700 Canister Steam Vacuum
How do I undo the torx screws that hold the Polti 2400 Steam Cleaner (Polti Vaporetto 2400) together? There is an electrical fault and I will have to strip it down to investigate.The house RCD trips when...
With a torx screwdriver! There's nothing special about these screws except the shape of the hole in the head. Commonest size in small domestic machines is T15.
Oct 15, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
No steam from my almost new Polti 2600
It sounds like the solenoid isn,t activating when you pull the trigger which then lets the steam out. It either wants stipping and checking or returning to where it came.
Apr 19, 2009 | Polti Vaporetto 2000R Vacuum
Polti spare parts
i have a 950 and it does not heat up any more . the red light comes on but thats it
Feb 13, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
When turning on the unit blows the fuse every time
you need a 60amp to run this have a quilified elec in stall
Feb 12, 2009 | Polti Vacuums
Starting a polti vaporetto steamer
Put a couple of lts. of water in the tank, replace lid, assemble hose with tool you require. Plug in switch on, wait for needle to climb into yellow then pull trigger for steam
Jan 23, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Nov 04, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Eco Pro 3000 Canister Steam Vacuum Logo
315 people viewed this question
Top Polti Vacuums Experts
cwradio73
Kolbrun...
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
