Question about Microsoft Windows XP Professional
Vartual Memory i have a os(operating system) of windowsxp . I can't doing much vartual memory what i accpt. what proceder i have to do ? plz seggest me as soon as.
  • Sumeet Gohel
    Sumeet Gohel Jun 09, 2008
    Q1 i would purchase "assemble" desktope what should be require of that my budget is 25000/- and i would like to processor of "core 2 duo" and 250GB sata harddisk and 2 gb ram. what a best company of motherboard, Dvd writer, Cabinet, LCD and other parts of it. give me best suggestion that i can purchase good Desktop Pc.
  • Sumeet Gohel
    i would like to purchase "Assemble" Desktop Pc So, plz give me good suggestion of the good company parts with worrranty year.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
I think what you are asking is: first, how to tell what memory (RAM) and second, how to tell what processor you have, so this response primarily addresses those two questions (item 1). Then, as you have mentioned virtual memory, I will also explain how to review that current setting, and change it as you desire (item 2).
(1) There are two ways to get to the System Properties window, which gives you basic information re your PC components, devices, and settings. Click on Start, right-click on My Computer, and select Properties. (This is the most direct method to get to the information.)
A window will open with a number of tabs, and most likely, the General tab will be visible. If not, click on the General tab. Here you will see general summary information regarding your PC, including the processor (CPU type and speed) and the amount of memory (RAM) installed.
(2) Virtual memory refers to the usage of hard drive space to supplement physical memory (RAM), and is a little more complicated and complex. In effect, when you are running a process where system needs exceed the amount of RAM available, the PC will use a paging file to supplement the PC's RAM. The paging file is a designated amount of hard drive space set aside in order to be used as "temporary RAM". In other words, the paging file on the hard drive swaps information back and forth between the hard drive (used for temporary storage) and the active memory being used to run your process.
Usage of the paging file is a process that has both advantages and disadvantages. RAM (random access memory) is immediately available to any process run and is always active. This is the primary resource used in running various processes, from the basic tasks required by your OS to, for instance, holding the text you are typing into a document until that text is saved to the hard drive and retained in a named file. This is also the information subject to loss until it is saved to the hard drive, such as when there is a power failure and you have not yet saved the data currently held in RAM (including paging file contents).
Although the paging file is stored on the hard drive, it is temporary just like RAM (acting basically as "substitute RAM"), in regard to saving information for long-term use and later reference. It replaces RAM when system needs exceed actual physical RAM; so, if your computer has 512 MB of RAM and your paging file is set at 256 MB, for example, the system treats this basically as if you had 768 MB of RAM in your PC. This helps to speed up processing because there is more memory usable by your system to process currently. However, the usage of the paging file for that additional 256 MB (in our example), while allowing more information to be processed based on the total, has drawbacks in that the speed is much slower than actual physical RAM. This is because the computer is actually having to write data back and forth between the hard drive and the physical RAM (swap the data).
In order to see and manage the virtual memory settings of your PC, on that same System Properties window, click the Advanced tab. On that tab, select Settings under the Performance section. This opens a window titled Performance Options. The bottom section, titled Virtual Memory, exhibits the size of the paging file. In order to see all the parameters in this regard, click on Change, which will pull up the exact parameters relative to the paging file. You will note then that under "Total paging file size for all drives", a specified size for minimum, recommended, and currently allocated. For most individuals, if you are not expert at managing complex systems, the best choice is to select System managed size (under "Paging file size for selected drive"). That section includes custom size settings (initial and maximum), system managed size, and no paging file. Again, unless you feel that you are quite knowledgeable in managing system complexities, the best choice is most likely System managed size, as this will allow Windows to set, and adjust as required, the size of the paging file. This lets Windows take into consideration all the various parameters of your system, including hard drive(s) size and physical RAM, among other things. If you have selected no paging file, this would likely contribute to system performance issues, as your system is limited to processing only the amount of information as can be accommodated by physical RAM at one time.
Hope this answers all your questions, and if not please feel free to post back. Otherwise, thank you for rating FixYa!
Posted on May 29, 2008
  • Cheryl Whalen Jun 09, 2008
    I'm sorry, I am not sure what you mean by an "assemble" desktop. Do you mean you want to build your own or buy one already put together with specs you chose? If you are referring to one where you choose basic items and the manufacturer builds it, HP and Dell are two of the favorites, at least for the US consumer market, and where Windows is the preferred operating system. Please post back if you have more questions. Otherwise, thank you for using and rating FixYa!
    Genius:
  • 2,785 Answers
Right click on my computer> click on properties> on the system properites box >click on advanced tab> on performance click on settings>then click on advance>in the below you will get virtual memory click on change>click on custom>and give atleas 1024 both in intial and maximum(if you see more than 1024 in the maximum area than give that value in both)>then click set then click on ok.
your memory will increase
Memory
System memory is in use by the operating system. A reboot will free it all, but as the OS loads, it will use much of what was freed. A long-term answer is to start with a 64-bit OS that can access more than 4gb, and then to increase your memory.
Sep 11, 2014 | Computers & Internet
Securety code eror
check this one
Master Code Generator will Instantly generate your Nokia's Master security code.
This service can be used if you need to reset your Security Code.
Your IMEI: 356924034968264 --
Your Nokia Master Code: 2401254345
or this one
Nokia 5000 hard reset
You can format your Nokia 5000 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YESRestore factory settings
To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options:
Restore settings only - to reset all preference settings without deleting any personal data
Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys
IMPORTANT!
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings
goodluck
Apr 21, 2014 | Nokia 5000 Cellular Phone
My sumsang SGH ZV 10 go off if am downloading anything or access vodafone
my samsung modal sgh-zv10 ,sim no accpt /plz solution ---- i m kashif from pk
Sep 12, 2011 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
How to make geforce6100pm-m2 read both memory slots
make sure your memory meets these guide lines.
? 2 x 240-pin DDR2 DIMM socket support up to 16 GB*
? * (Due to the DRAM maximum size is 2GB at present, the memory maximum size we have tested is 4GB)
? Dual-channel DDR2 memory architecture
? Support DDR2 800/667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows?32-bit OS.
For Windows?64-bit OS with 64-bit CPU, there is no such limitation
which means win xp will only read 2gig and win vist/7 will read 4g so if you have 2x 2gig and only 1 is registering its working fine with win xp.
Jan 31, 2011 | EliteGroup GeForce6100PM-M2 Motherboard
My laptop when i turn it on, it will do two beeps and then go to a screen that says "press f1 to resume, f10 to setup. When i press either button nothig happens. I don't know if my keyboard doesn't...
hi..
  • it's because of your operating system corrupted ...
  • re-install your operating system again correctly..
  • and install anti-virus too...
  • this problem may be happen to your system due to file corrupted..
  • If it's useful for you means plz rate me the 4 Thumbs ....
Jan 11, 2011 | HP Compaq Presario V2000 Notebook
What is the vartual memory and how change the sharing memory
virtual memory is page file and it locates in the HDD.In the C drive you can see .
RAM collect data from page file.sys and run .
You can change the memory just click here= http://www.delete-computer-history.com/increase-virtual-memory.html
Hope it will help you.
Dec 11, 2010 | Gigabyte GA-G31M-ES2L Motherboard
I have a sylvania notebook i want to change os how do i do that i have no cd rom do i use a usb flash windows ce is harable.
To the best of my knowledge, you cannot change the OS on that notebook as it is an embeded system. The Gsystem is burned into a chip on the mother board and the only way at present is to reprogram a like chip and solder it in place after de-soldering the old chip. Then you would have to buy another embeded system and learn to program an EEprom chip.
Sep 17, 2010 | Sylvania G-Netbook
5000d-2 unlock security code
MY MOBILE NOKIA 5000d-2 this mobile number lock activetd
but this mobile password code missing
serial no:324838029646143.
Type:RM-362
Code:0568255
imei no:354838/02/964614/3 PLEASE HELP SUPORTING PASSWORD
Sep 30, 2009 | Nokia 5000 Cellular Phone
WindowsXP professional, start up
This needs some understanding of OS only. Don't worry.
Now, coming to ur first problem... u can change the bootup xp options by modifying the c:\boot.ini (be careful too...and u r right, it will not slow down ur pc)
reg. the bootup disk problem, ... u may need to create a bootable CD for installation... u may get the 'bootstrap' CD image from internet (but, r u having a licensed version???)
Have a nice day
I hope, my suggestion was helpful
Mar 15, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Professional Logo
108 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
