Question about Saitek R660GT Wheel And Pedals Set
I have a Saitek R660GT steering wheel, but if you are about 5° off centre, it goes full lock (either direction), but otherwise works fine. Anyways to fix this?
My ford flex 2011 steering wheel locked permenantly ,car working normaly ,fluid ,built fine ?
put the key in and just jiggle the steering wheel while turning the key.
Jan 19, 2015 | 2011 Ford Flex
Does dodge pu use any pressure control valve for power steering control
There is a pressure relief valve to prevent the pump locking up and destroying itself. You will hear it working when you hold the steering hard on full lock. Otherwise the fluid is recycled back to the reservoir through the valves until you turn the wheel and that upsets the valves which close off until the wheel movement stops and no fluid is let in or released until the wheel is again moved.
Apr 27, 2014 | 2000 Dodge Ram 1500 Truck
98 freelander stalling fault
Explore the problem to see if its the power steering, or physical steering or engine:
Does it stall when its in neutral and you go to full lock?
If so its the power steering, or the engine isnt ticking over fast enough to generate the extra pump pressure needed when on full lock. Check pump belts are good and tension is correct. Then buy a used idle valve and swap it out.
Also do basic checks to see if wheels are catching on some part of car. Jack it up so front wheels are off ground, on full lock in neutral do the wheels turn freely, or catch on something? Slowly lower the vehicle down and check same as you do it. When its down put it in gear and see if it stalls.
Dec 15, 2013 | Cars & Trucks
Key will not turn over
Check to make sure gear shift is in Park. Rock the steering wheel hard without the key in. Try the key...you may have to hold the steering wheel all the way in one direction and try or the other direction and try. Good luck. Sometimes the steering wheel lock does not line up when you removed the key.
Oct 22, 2017 | 2000 Lincoln Navigator
Steering is noisy at slow speeds when turning
This car is essentailly the same as the Lincoln LS & T-Bird.
Here is their solution.
please rate if this helps you. Thanks.
ISSUE: Some 2003-2005 Thunderbird, Aviator, and Lincoln LS vehicles may exhibit steering gear squeak when turning the steering wheel, especially during low speed parking maneuvers. The noise may sound like it is coming from the steering column area and may be felt as a roughness in the steering wheel, while turning.
ACTION: Refer to the following Service Procedure.
SERVICE PROCEDURE NOTE: USE ONLY THE FLUID AND ADDITIVE SPECIFIED IN THIS ARTICLE. USING ANY OTHER FLUIDS OR ADDITIVES MAY RESULT IN SEAL DETERIORATION AND LEAKS.
  1. Open the hood and remove the power steering reservoir cap.
  2. Raise the vehicle on a hoist. Refer to Workshop Manual, Section 100-00.
  3. With engine off, drain power steering fluid by disconnecting steering lines and clamp plate from steering gear. Refer to Steering Gear Removal and Installation procedure in Workshop Manual, Section 211-00, follow only the steps required to disconnect the steering lines.
  4. Turn steering wheel lock-to-lock to drain fluid completely.
  5. Reconnect steering lines and clamp plate to steering gear. Torque retainer to 15 N-m (11 lb-ft) for Lincoln LS and Thunderbird, torque to 25 N-m (18 lb-ft) for Aviator.
  6. Lower vehicle.
  7. In a clean container mix 50 ml (10 teaspoons or 1.7 oz.) of Motorcraft Additive Friction Modifier, Part Number XL-3, with 50 ml of Motorcraft MERCON® Multi-Purpose Automatic Transmission Fluid, Part Number XT-2-QDX. NOTE: DO NOT PERFORM STEPS 8 AND 9 ON A HOT VEHICLE.
  8. Pour the above mixture into the power steering reservoir.
  9. Top off (fill) the power steering system with Motorcraft MERCON® Multi-Purpose Automatic Transmission Fluid, Part Number XT-2-QDX and reinstall the power steering reservoir cap.
  10. Raise vehicle on hoist enough so the front wheels are off the ground and can be turned from lock-to-lock.
  11. Start the engine and keep it at idle. Remain inside of the vehicle.
  12. Slowly cycle the steering wheel from lock-to-lock for two (2) minutes.
  13. Quickly and forcefully turn the steering wheel in one direction to full lock (either side). Bounce the steering wheel on/off of full lock twenty (20) times forcefully. NOTE: IT IS CRITICAL THAT THE STEERING WHEEL IS TURNED QUICKLY AND FORCEFULLY IN ORDER TO CREATE A PRESSURE SPIKE IN THE POWER STEERING SYSTEM.
  14. Repeat Step 13 in the other direction. Return the steering wheel to on center position.
  15. Slowly turn steering wheel to full lock in one direction (either direction) to achieve maximum pump pressure. Hold at full lock for one (1) second, then turn the steering wheel back 90 degrees as quickly as possible. Repeat this procedure twenty (20) times. NOTE: DO NOT HOLD THE STEERING WHEEL AGAINST THE STOPS FOR MORE THAN THREE TO FIVE (3-5) SECONDS AT A TIME. DAMAGE TO THE POWER STEERING PUMP MAY OCCUR.
  16. Repeat Step 15 in the other direction.
  17. Cycle the steering wheel slowly for 1 minute to confirm that the squeak is corrected and return vehicle to the customer. NOTE: IF THE SQUEAK CONTINUES, REPEAT STEPS 13-16 ONE ADDITIONAL TIME. IF THE SQUEAK IS STILL NOT CORRECTED PROCEED TO STEP 18.
  18. If the squeak is still present after performing Step 17, replace the steering gear. Refer to Workshop Manual, Section 211-00 for removal and installation procedures.
PART NUMBER PART NAME XL-3 Motorcraft Additive Friction Modifier XT-2-QDX Motorcraft MERCON® Multi-Purpose Automatic Transmission Fluid 5W4Z-3504-A Steering Gear (LS) 5W6Z-3504-A Steering Gear (Thunderbird) 5C5Z-3504-AA Steering Gear (Aviator)
Aug 15, 2011 | 2003 Jaguar X-Type
When i'm trying to use the scrolling wheel it just
go control panel --click on mouse right click to get properties
check compatibility tab
adjust scroll speed to suit
Dec 17, 2017 | Saitek GM3200 Mouse
The key will turn far enough to start the accessories but will not move far enough to turn the engine on.
try turning steering wheel a bit, or move shifter up past park. Otherwise ignition may have a broken or stuck pin and will need to be replaced.
Oct 07, 2009 | 1990 Jeep Cherokee Limited
What Steering Wheels are able to be used with 18 WoS-ALH
Saitek R660 GT force feedback wheel works fine (for me any way) hope that helps
Jul 07, 2009 | ValuSoft 18 Wheels of Steel: American Long...
Can not turn the key .on my 1996 toyota camry
Look for a certified diagnostic centre so your car can be properly checked. I suspect that it has a security code issue. It can only be corrected that way. Try it out and get back to me. +2348023080045
Mar 17, 2009 | 1996 Toyota Camry
Saitek R660GT Wheel And Pedals Set Logo
50 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
