Question about Motorola Mobility W375 Cellular Phone
Camera When ever i try to use the camera on my w375 Motorola it goes on the the screen which is completely black and then refuses to let me quit enless i close the phone. Is this something wrong with the phone that i have caused because it worked when i first got it?
    Brigadier General:
  • 7,752 Answers
Do a master reset on the phone and have the camera check to see if it need to be replaced.
Posted on May 31, 2008
I lost my drivers. it s not getting connected to pc
HOWTO_Connect How to connect Motorola W375 to a Windows computer Introduction¶ This document describes how to connect your Motorola W375 to your computer in order to use it as a modem, or to administer it with Motorola W375 Manager software.
Connecting¶ To connect your motorola W375, follow the next steps:
  • Download and uncompress Motorola W375 Driver from this site.
  • Connect your W375 to your computer with its lid closed.
(You can also connect the device with its lid open, and choose "not" when it asks for permission to connect as an storage device)
  • When Windows asks you for a driver, select Motorola W375 driver folder.
This way, the next time you connect your mobile phone closed, your computer will recognize it as a new communications port and you are ready to use it with Motorola W375 Manager. If you open this "COM" port with a terminal emulation software (i.e Windows Hiperterminal) and type "AT", the mobile phone will respond you with an "OK" string.
Using it with Motorola W375 Manager¶ To use your mobile with Motorola W375 Manager, simply connect your mobile phone closed and then, start Motorola W375 Manager software.
Using it as a modem¶ To use your mobile phone as a modem, install "Standard 19200 Modem" driver and select the communications port associated to your motorola W375.
About Motorola W375 driver¶ Motorola W375 driver is basically the same driver known as Motorola USB Charging Driver. You can download Motorola USB Charging driver from motorola US support web site for Motorola W375. If you try to use Motorola USB Charging driver directly with your Motorola W375, device type will not be recognized, but if you change device ID from "USB\VID_2811&PID_0702" to "USB\VID_22b8&PID_4061", this usb charging driver will become completely compatible with wour Motorola W375 mobile phone. The driver you can download from this site, is exactly a Motorola USB Charging driver with the mentioned modification.
Dec 07, 2010 | Motorola Mobility W375 Cellular Phone
Does this phone have blue tooth and how do you switch it on
The Motorola W375 is a basic quad-band GSM flip phone that sports a built in FM radio and VGA camera. Other key features include a 2.5mm headset jack, speaker phone and external indicator lights.There are Bluetooth adapters that plug into your Motorola W375 cell phone's 2.5 mm jack and convert your non-Bluetooth phone into a Bluetooth wireless device.
Oct 25, 2009 | Motorola Mobility W375 Cellular Phone
When my motorola W375 chages the screen goes white
Take the battery out, wait 10 seconds then replace it. You might need to reset the clock afterwards but your phone should be back in action.
May 23, 2008 | Motorola Mobility W375 Cellular Phone
Camera gone blank
Hi,thanks for that. I tried that one, but it didn't work. It still had the same problem. I've now sent it out for repairs. Found it was still under warranty anyway. Thank you very much.
May 14, 2008 | Motorola Mobility W375 Cellular Phone
How do I connect my Motorola w375 to PC
try downloading the motorola usb drivers and installing them.
i would try that first.
you could also get motrola phone tools software which comes with the drivers and can transfer the photos from your phone
Apr 12, 2008 | Motorola Mobility W375 Cellular Phone
Camera
try giving restore factory settings.........
if problem persists then have a have whether the camera is working correctly not,....
before taking pic just check whether it is showing or not,,,
try to record video once ... if it cannot able to show means then the camera strip is gone so you get it changed..
visit the technician..................
Apr 01, 2008 | Motorola Mobility W375 Cellular Phone
Motorola w375
Use a cotton bud, damp, if it very dirty. Then, use a food cocktail stick to go round the circumference of the camera a couple of times. Do this as many times as needed, it will help with the outside of the lens. Hope this helps, even if just a little bit.
Mar 16, 2008 | Motorola Mobility W375 Cellular Phone
Camera on a W375
I had the exact same camera blacked-out malfunction. I followed booj's advice and it cured the problem. What I did: I turned off the w375 phone by pressing and holding the red button (not just closing the clam shell, like I normally do), after the phone powered down, I restarted it by pressing and holding the green button. After it powered up, the camera at first had the same black screen, then, all of a sudden, the view finder started working normally and it now takes pictures correctly. - MGB
Feb 02, 2008 | Motorola Mobility W375 Cellular Phone
"busy" camera
it sounds like its a software problem
Jan 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility W375 Cellular Phone Logo
26 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
