Question about E-Machines eMachines Desktop PC
Computer powers on but does not do anything. mo beeps or anything on monitor
    Scholar:
  • 78 Answers
You need to get into the PC with it unplug from wall. Pull the memory sticks out, they look something like this -->
Then power the PC back on with them out. If the PC makes no noise then you mother board has a problem. If the PC screams at you the mother board should be okay.
There are a few things that could be causing you problem.
Please rate, and write testimonial if you feel the need to, if this was helpful.
Good Luck
cookieMonster
Posted on Oct 07, 2010
I get no display on the monitor and there are no error beeps
Plug in a working external monitor to the video output of the all in one. If that works then the internal monitor is ng. If the plugged in monitor also does not work then the video circuits are shot. Too expensive to replace the internal mo bo - you get ripped off on mo part cost and labor. Replace unless under warranty.
Nov 22, 2013 | HP Omni 100-5050 20" 1.8G3GB 500GB...
Hp pavilion a1220n comptur will not start unplugged unit and when i plugged to back in it would not start
Do you see anything on the monitor screen? Does the tower make any beeping noise or clicking noise, or does the fan tries to start up when you power the computer on? Are the cables connected properly?
If you see anything on the monitor screen, or if you hear a beeping sound, let us know so we can diagnose further.
Aug 07, 2011 | HP Pavilion a1220n (A1220NED904AA) PC...
Ayaw po magopen ng aoc computer monitor.. may mahinang click sya pag ini on mo tapos mag off sya then on ulit then off ulit...
ang problema jan ay power supply mo bka mababa masyado ang kuryente marunong ka na bang mag set up ng PC
sana natulungan kita
Jul 14, 2011 | AOC LM729 17" LCD Monitor
Walang Display sa pentium4 pero sa pentium3 Display siya
baka di makayanan ng Monitor mo ang required resulotion ng Video Card sa Pentium 4 mo.
if thats the case.. mag down grade ka sa VGA Card ng Pentium 4 mo or Buy a new monitor that fits the specs of your Pentium 4 setup
Jun 01, 2010 | AOC 193FW LCD Monitor
Computer won't boot , constant PWR problem (
i am also using same motherboard dg31pr intel but it does not reboot .......
because this is the problem with you monitor , just you change the monitor and try again .
this is only the solution to solve this as the tecnition said me.
Mar 20, 2009 | ASUS A7V400-MX Motherboard
No display on my asus P4GE-MX mother board
hi! im in philippines also.. did you here some sound? o kaya meron kang narinig na beep? kapag meron kang narinig na 1 long beep pki check ung memory mo. bka LOSE connection lng yan. tpos try to reset the BIOS setting. mikita yan sa loob ng motherboard. malapit sa CMOS battery.. meron jan na 3 pin na my numbr 1,2 and 3. tpos my mkikita kng mliit na item na kumakapit sa 1 and 2 ilagay mo xa sa 2 and 3 tpos mg hintay ka lng ng 7-10 seconds then ibalik mo xa sa 1 and 2.. tpos try mo paandarin.. ^^
Feb 09, 2009 | ASUS Computers & Internet
Blank screen on AL 2223W
When you switch on the computer and monitor does the monitor power light illuminated?
If not check the power cable, if the power light is on try connecting it to another computer, if it works on another computer then the fault is in your computer or a faulty video cable (try another video cable).
If the monitor does not work then it is faulty, if it is OK then your computy is faulty.
If the fault is in your computer, you didn't exactly pinpoint the nature of your fault.
Does the power light on your computer illuminated when you power up?
Does your computer actually boot up, does it give and beep code (count the number of beeps - 7 beeps usually means video problems, depends upon the type of BIOS)?
When your computer first boots up and you see POST information on the screen then nothing, it is most likely :-
1. The refresh rate of the video card has been set too high beyond the monitor's specification.
2. Video card configured with incompatible monitor.
If you computer fires up and the monitor is OK the you have a faulty graphics card, you need to replace it.
Nov 12, 2008 | Acer Monitor
No signal on monitor
Check that the power is plugged into the back of the monitor and also to the power point, make sure power point is ON. If anything pull plugs out and re-connect both just to make sure.
Make sure monitor cable is also plugged into the back of the computer.
Turn computer on and make sure it beeps and looks like it has hard disk activity to show it is booting into windows. If it doesn't beep or show activity it could be your PC having an issue else it is possibly your monitor.
To double check try your monitor on another PC and try another monitor on your PC to see which has failed.
Jan 25, 2008 | Dell Dimension 3000 PC Desktop
No Display
Be sure that your power supply is working!
If the PS is working ,Try to examine your memory . if your computer getting long beeping. means that CPU is working if not beeping something wrong with your CPU. if beeping Unplug the memory clean it and connect it back. then test the computer. if doesn't solve the problem try replace the memory.
Dec 10, 2007 | Computers & Internet
Blank moitor
can you chk anything abt the lights on the monitor ? ie.. the small ones near the power switch .. is it green / orange ..
Also do u hear any beeps when you power on your computer ? I vaguely remember that in case you hear three beeps, it could be a video card issue.
- Ranjit
Nov 08, 2007 | Dell Dimension 4600 PC Desktop
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
