Question about Keurig Platinum B70 Coffee Maker
Hello, My Keurig says de-scale on the screen.
Hello, My Keurig says de-scale on the screen. I've tried running vinegar through it, but it just squirts out a little into the cup and just sits there. It doesn't seem to want to cycle at all. I have to turn it off and unplug it before it will allow me to press brew again, Then it will say brewing with nothing happening. How am I supposed to get it to de-scale if it won't even cycle the vinegar through it? Is the problem greater than just the descaling? Thank you!! Georgia
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
SOURCE: Keurig only brews about 2-3 oz. of coffee.
Doesn't sound like a descaler issue. I am having problems with mine and noticed that water is flowing back into the reservoir when it is pouring into the coffee cup. I think there is a valve that is not closing properly.
Posted on Mar 23, 2010
  • 60 Answers
SOURCE: Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Posted on Mar 26, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: My keurig machine wasn't brewing a full cup so I
do another descale..add more vinegar....run the entire full tank of water....you must have a big buildup of scale...
Posted on Dec 18, 2010
woobie dog
  • 1273 Answers
SOURCE: my keurig elite heats but won't brew a full cup of
Could be. I pass a fine wire up into the needle, and downward out the outlet needle when mine gets sluggish, and it helps.
Posted on Jan 17, 2011
Keurig Platinum B70 Coffee Maker not de-scaling properly?
Purge and blow out the lines. Debis is in tubes and ports.
Jan 12, 2012 | Keurig Platinum B70 Coffee Maker
De scale kruig coffe maker
Empty the reservoir of water and fill it with four (4) cups of white vinegar. Run the Keurig WITHOUT a K-Cup until the vinegar has been run through. Rinse out the reservoir with hot water, dry it, then fill with cold water normally used to make coffee. Run the maker 3 times, or until vinegar taste disappears.
Dec 25, 2011 | Keurig B60 Coffee Maker
It says to de scale, ive been running vinegar and water through it but it's having a hard time coming out and still says de scale.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 21, 2011 | Keurig B60 Coffee Maker
I ran a cycle of vinegar through special edition brewer and it continues to say de-scale after doing scaling. it won't pour water sometimes and has to be turned on and off to get it to pour water. ...
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Jun 14, 2011 | Keurig Platinum B70 Coffee Maker
The water comes out the top of the manuel filter so not all the hot water goes through the holder. the coffee is loosely put in the filter
Try running vinegar through the Keurig to clean and de-scale it. You should use white vinegar, run it through using several cups until there is no vinegar left, then use clean water to brew plain hot water until you can no longer smell vinegar. This will help de-scale the Keurig and potentially remove any plugged bits of coffee that may remain.
Mar 01, 2011 | Keurig Coffee Makers & Espresso Machines
Why is the keurig not brewing coffee, just hot water is coming out everytime
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
Dec 29, 2010 | Keurig Special Edition B60 Coffee Maker
"not ready" frozen on screen
Try to unplug and plug back in..plus follow the below
Dec 23, 2010 | Keurig B60 Coffee Maker
Hello, my kuerig machine is randomly switcing to the menu when i try to brew any thoughts???
Sorry to read about your problem, I hope this helps you out.
Dec 22, 2010 | Keurig Special Edition B60 Coffee Maker
I have a Keurig B66, the reservoir water gets heated but then comes back into the water reservoir from the top vent tube. The water coming back into the reservoir is very hot; almost no water goes into the...
Try this first....
Dec 22, 2010 | Keurig B60 Coffee Maker
Does not dispence right amount of water
2,,2,2 you can contact Keurig at 1-866-901-2739 or Keurig.com
Dec 19, 2010 | Keurig B60 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
360 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
