Question about Watches
I have a frontier international wind up mechanical clock that displays date and time it also has a pendulum, i would like to know when this clock was made.
escapement
  • 2334 Answers
SOURCE: I inherited a grandfather clock which runs slow
You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
Posted on Mar 23, 2009
FixinFax
  • 3085 Answers
SOURCE: I have an old seth thomas mechanical clock that is
http://clockparts.com/
Posted on Nov 29, 2009
SOURCE: I have an out-of-commission German-made Anniversary Clock
I had the same problem; I inherited a clock by that description with my office. I'm not sure if it would help you, but I was able to at least figure out the mechanics of the clock from this site: http://www.clockworks.com/cintro1.html
They claim that you can order the spring there.
  • 2501 Answers
SOURCE: Don't know how to properly wind Elgin 400 day anniversary clock
Wind the clock until there is a sudden increase in resistance (it is then fully wound). So not apply a great force, as older clocks may be weaker and overloading the spring may break the termination and result in a new spring being required.
If you think it is becoming too stiff, just stop winding and see how long it runs for. I have often heard the term "over winding at clock" but have never quite understood the term. As a retired engineer I think that springs that break because of overenthusiastic winding are probably near the end of their life anyway.
Posted on Jan 14, 2010
mcdevito75
  • 1970 Answers
SOURCE: I have a Seiko Westminster Whittingham Clock,
mcdevito75 here, I would figure the pendulum serves 2 purposes, 1 it acts like a seconds hand on a watch and 2 more important it acts a s a counter weight keeping the clock in Balance. It sounds like the Pendulum mechanism needs cleaning and or adjustment, look for a small watch repair shop in your area, they can advise you on a clock repair shop in your area, or you can always check with the repair service directory right here at fixya, bottom of page, click on repair service directory the watches / clocks.
Posted on Jul 03, 2010
Brand new Hamilton automatic watch, but we can't get it started running.
If this is a self winding watch then you will have to rotate the pendulum inside it about 200 times before it will start. The directions should show you the proper way to rotate the watch to move the internal mechanism.
Dec 25, 2012 | Watches
Tip
Cuckoo Clock Repair
CUCKOO CLOCK
REGULATION AND REPAIR TIPS
REF: 30 hour and 8 day clock
[From my shop notes:]
{FACT}
-1/8 inch movement of the pendulum bob is equal to about 3 min per 24 hours running.
-To increase the time of the clock, move pendulum up.
-To slow down the time move, pendulum down.
Regulation notes:
These novel clocks are at best only a "fair" time-keeper. You can expect 100 to 120 sec per 30-hour winding period. I recommend that if it is within a few minutes per winding, simply RE-set the time.
-The regulation obstacles are obvious:
1. Open pendulum, this allows even the slightest breeze from a fan, ceiling fan or even cross-winds inside your house to affect both time qualities and/or its running ability.
2. The Pendulum material is wooden, and sensitive to climatic condition, during times of high humidity the clock will slow down.
REPAIR TIPS:
1. Recommend regular servicing every 2 to 3 years for these unique clocks, mostly due to the fact that the movement is open to the elements (dust and dirt is easily deposited on the movement).
2. Sometimes the clock is "over weighted", meaning that the actual weight is to heavy for the clock. I have seen some very new clocks with the wrong weights added. Instead of the clock simply stopping after the lubrication qualities are gone it continues to run and ruined the bushings.
-To find the correct weight of a newly serviced clock, you can use a small scale. Anchor it to the floor, connect chain to the top end, wind it until it is more than double the weight of the existing weights, and then start the clock to running after the clock stops running, X's the weight figure on the scale by multiplying 1.25 or 1.35 X's the weight figure on the scale by 25 to 35 % maximum = the amount needed. [Example scale indicator is on 1 lb x 25% = 1.25 lb
BELLOW REPAIR:
-Unfortunately many repair persons have opted to simply replace the bellow, this is unfortunate because it can so easily be repaired.
-I use a "RE-COVERING BELLOWS" kit.
-This kit comes with bellow replacement material, glue, one wooden handling tool and great instructions.
DO NOT attempt to simply patch work this, it is not fair to the customer and it will not work long.
THE CHAIN:
If needed, don't be afraid to replace the chain as they are easily ordered and replaced. Most cost about $3 to $4 a piece.
The problems are:
-If there is a child, pet, or adult in the house, the chain can be stretched. If the chain becomes damaged, it will get hung up inside the clock. "Even one damaged link can stop the clock."
-Wrong size chain {the differences between 72 links per foot and 67 links per foot are easily confused). Recommend actually laying the chain on the chain drive gear and seeing if it fits.
MUSIC BOX GOVERNORS:image008.jpg
Clean and oil only. Check the pivots if worn. Don't waste your time to try and repair, just replace the Governor. Only the actual music drum can be sleeved with a new bushing. Cost for a new governor is about $25. Well worth having a few assorted governors in stock.
-If a complete replacement is necessary, the cost is about $40 to $50.
Hope this tip helps.
R/ David
http://antiqueclock.clockstop.com/CUCKOO.htm
on Jan 22, 2010 | Watches
Coaster model 900723 grandfather clock doesn't keep time
Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
Nov 20, 2010 | Watches
Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
Jan 28, 2010 | Watches
Jan 13, 2010 | Watches
I have an out-of-commission German-made Anniversary clock. I would like to try to fix it myself. The thin long spring that is responsible for moving the pendulum at the bottom (Pendulum = 4 balls that...
Nov 12, 2009 | Watches
Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
r/
David
Aug 25, 2009 | Seiko Chiming Pendulum Tambour Mantel...
Does anyone know where to get a replacement 'movement' for the Michael Graves's Alessi mantle clock.
Yep - I know a clock repairman in California who still has some of the original Hechinger Quartz Movements for the Alessi pendulum clock . Definately worth repairing .
Jul 13, 2009 | Watches
What ports wind what?
On mine, the center one (@the 6 position) is the one that keeps the pendulum swinging. It is the one that lengthens the most during the week and if I forget to wind it, that pendulum is all the way down when the clock stops.
May 02, 2009 | Watches
Mar 23, 2009 | Watches
Watches Logo
57 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
