Question about Fantom Vacums FM741 Twister Bagless Upright Vacuum
I had my Fantom in for repairs (filter, light, belt, and cleaning) less than 7 months ago. Now its not picking up again and the brushes are not rotating. Does this mean another belt? At $69+ every 6 months, I'm thinking of getting another vacum. Any suggestions? Thanks, Judy
  • ocholler Oct 10, 2010
    Thanks for the suggestion, but I'm trying to avoid another repair bill by doing it myself. I had asked for the type of belt for my model and instructions for replacing it myself. Thanks, again, for your time.
    Judy
    The directions sound easy enough, but I'll need to wait until I get the belt to know if it works. Thanks for your prompt response. Judy
  • 11,896 Answers
Sounds like you are going to need a new belt. It also wouldn't be a bad idea to have the edges of the roller clean because hair and carpet can wind up on the edges making it harder for the roller to turn.
Posted on Oct 07, 2010
My Hoover windtunnel brush is spinning but not picking up. I cleaned everything out, but still not picking up. There is another small set of 2 wheels that is not spinning. Could that be the problem?
If it's been over 6 months replace the belt or belts. stretch belts lose elasticity soon after being installed which is why they should be replaced frequently. Your belt may still spin the brushroll but not fast enough to clean carpets properly. After a few months it will pick up some of the sandy gritty soils but will force some of it down into the carpet fibers. Eventually it will become so stretched. It will not pick up hair and lint.
Jan 03, 2015 | Hoover Vacuums
I have a Fantom 500 DX and it seems that it doesn't pick up anything anymore. It looks like machine is working well, but it doen't pick up. I would like to take to the repair guy, but I don't know where to...
The type of bagless that has sharp turns in the hose and plastic parts are easy to become stopped up. You have to follow the path of the air flow to find the blockage.
Mar 29, 2011 | Fantom Vacums FM760 Twister 500DX Bagless...
I have a Fantom Thunder Vacuum. Missed placed my book. How do you replace the belt on the brush?
depending on your model, and I am going from memory on this one. I have not seen this model in a while.
1 headlight on the unit:
there are 2 screws on the back of the cover for the brush. Just above the wheels. Remove those two screws and the cover will come off.
2 headlights on the unit:
use a small screwdriver to remove the headlight lens covers, remove both of the light bulbs, and then the two screws are under the lights. there MAY be 2 more screws again at the back of the unit above the 2 rear wheels to remove as well. again the cover should come off and you will have full access to the belt/brush under there.
Nov 04, 2010 | Fantom Vacums Cyclone XT Upright Vacuum
Does not pick up
Hi There,
It may be that your belt is broken, or stretched out. This will cause the brushes to slow down dramatically when vacuuming the carpets. When the belt stretches, this causes the machine not to pick up on the carpets, and makes it seem that the vacuum is loosing suction.
In order to test this, turn the vacuum on it's side while it's on. Are the brushes spinning? If they aren't, this is because your belt is broken. If the brushes are spinning, the belt still may be stretched. Listen to the brushes as you put them onto the carpet. Can you hear a change in the sound like the brushes are slowing down? If you put just a little pressure on the top of the vacuum by stepping on it, do the brushes stop then?
It may also be the filter is clogged in the machine and needs to be replaced. Bagless vacuums use a HEPA filter in the dirt cup instead of a bag. With a bagged vacuum you just replace the bag when it gets full, but on a bagless vacuum the HEPA filter continually gets debris and fine dust accumulating on it, and needs to be cleaned, and replaced occasionally.
Here's a link to the owners manual for your vacuum. This will explain step by step on how to replace the belt, as well as servicing the filter.
http://www.dirtdevil.com/manuals/?id=83831cab-2807-439b-811d-52aab2fd84ee
If you still need some help, please just use the comment field here on Fixya to ask your question. I'm always more then happy to answer all follow up questions, and I really am not completely satisfied until you are able to fix your vacuum.
If you found this repair helpful, please be so kind and rate the repair, or leave feedback. This is greatly appreciated.
Thanks,
Chris Jones
GoVacuum.com
Apr 23, 2010 | Dirt Devil Featherlite Bagless Vacuum...
It makes a very loud noise and doesnt pick up much
When they make noise like that there is usually an issue with the drive system (the belt and roller brush). I would try cleaning off the roller brush and putting a new belt on. You can access the roller brush and belt by turning the vacuum over so the brush faces up. There is a cover plate over the roller brush which can be removed by removing the (4) phillips screws. with the cover plate off, you can remove the brush and old belt. clean the brush off really good and put it back with a new belt. This is normal maintenence for this model and should be done every 6 months.
You can get the replacement belt here:
http://www.vacbelts.com/bissell-powerforce-belt.htm
Oct 24, 2009 | Bissell 6594 PowerForce Bagless Upright...
NO SUCTION COMING FROM BOTTOM OF VACUUM
even though the belt isnt broken you should replace it also make sure the height is raised up on the nozzle. try dropping a marble through the hose to double check there is nothing stuck ( the attachment hose and the small hose that runs to the floor )
Sep 07, 2008 | Hoover U5507900 Elite Rewind Bagless...
Brushes not working
Check the filter from the bottom, it has a red frame, pull it out far enough to clean it, if it is clooged, then the brushes won't spin. If it is clean, pull the brush block out, make sure the shaft that goes up into the turbine is not brokked off, if it is replace thebrush block. With the brush block out, turn on the machine and look up where the brush block goes, there is a square hole, if it is turning, then it is ok, if not, then the turbine is either clogged up or the turbine has gone bad.
Jun 20, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Broken Belt for Fantom Crosswind 600XL
Hello, your Fantom vacuum will take a Panasonic U vac belt, to replace it, their are two screws in the back, one on each side of the back of the housing, take out the two screws and lift off the top hood, and the vac belt is on the side, remove the brush roller clean any debis away, put the new belt around the metal motor shaft first then around the brush roller, and pull down into the housing, make sure it locks in evenly, then turn the roller to make sure it moves freely. then put the hood back on front first, hold down and put the screws back in, in the back. now your ready to vacuum. Any question or more help I can give, please call 1561-848-3387 Thank you, Teresa.
Jun 16, 2008 | Westinghouse WST1550 Wired Deluxe Upright...
Fantom Twister
On my fantom cylone I use a 2 foot wire with small hook. Open bottom and push wire up the vacuum channels. There is also a channel that goes to the brush. Check for suction at hose. If none then your one of your channels going up are blocked. If you have suction at hose but none at floor brush then channel to floor brush is plugged.
Dec 09, 2007 | Fantom Vacums FM741 Twister Bagless...
Fantom Vacums FM741 Twister Bagless Upright Vacuum Logo
156 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
