Question about Microsoft Office Professional 2007 Full Version for PC
When the installation is running, it is always interrupted and stops the installation and views this message "an error has occured during the installation "
    President:
  • 2,571 Answers
Your install media must be damaged ( bad download file or scratched disc)
If it is a downloaded file, try again.
Posted on Oct 07, 2010
Ricoh 1515 is locked up with error message SC:820 code 612. How do I fix the problem
820 Self-diagnostic error: CPU
Symptom:
• An unexpected exception or
interruption occurs during the self-
diagnostic test.
• An error is detected in the MBU.
Possible Cause:
• Defective controller
• Defective firmware
• Loose MBU jumper
Code 820
MBU error (The jumper is loose.)
Set the jumper (on the MBU) correctly.
The following codes are displayed:
• SC: 820
• code: 612
• detail: 40000000
Feb 03, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
Error 1935 occured during installion of microsoft office
This issue may occur if a Microsoft .NET Framework file is being used when you try to install Office 2003. For example, this issue may occur if the Mscoree.dll is being used when you try to install Office 2003.
To work around this issue, restart the computer. Alternatively stop Windows Installer.
If these actions do not resolve the problem, repair the existing installation of the .NET Framework. Alternatively troubleshoot .NET Framework installation issues.
For more information about how to restart the computer and about how to stop Windows Installer, click the following article number to view the article in the Microsoft Knowledge Base:
308096 (http://support.microsoft.com/kb/308096/ ) BUG: Error 1935 during install of the .NET Framework For more information about how to repair an existing installation of the .NET Framework and about how to troubleshoot .NET Framework installation issues, click the following article numbers to view the articles in the Microsoft Knowledge Base:
306160 (http://support.microsoft.com/kb/306160/ ) How to repair an existing installation of the .NET Framework 824643 (http://support.microsoft.com/kb/824643/ ) How to troubleshoot Microsoft .NET Framework 1.1 installation issues in Windows XP or in Windows 2000 For more information, click the following article number to view the article in the Microsoft Knowledge Base:
926804 (http://support.microsoft.com/kb/926804/ ) Error message when you try to install a 2007 Office program: "Error 1935. An error occurred during the installation of assembly component" APPLIES TO
  • Microsoft Office Small Business Edition 2003
  • Microsoft Office Standard Edition 2003
  • Microsoft Office Student and Teacher Edition 2003
  • Microsoft Office Professional Edition 2003
  • Microsoft Office 2003 Personal Edition
  • Microsoft Office Basic Edition 2003
Please donot forget to rate these suggestions.
Mar 19, 2009 | HP Pavilion dv2000t Notebook
Error 232*
Error 232 Severity 16
Error message text Arithmetic overflow error for type %s, value = %f.
Explanation This error occurs when Adaptive Server detects an arithmetic overflow error during execution of a SQL statement. Arithmetic overflows occur when a variable has too few places to store the converted data. In particular, Error 232 is raised when an overflow occurs for a variable of datatype float.
Error 232 can occur during execution of the convert function. It can also occur during implicit conversion within Adaptive Server, either during a stored procedure run or during execution of a SQL statement which converts a float value to some other datatype.
Action Determine which variable is causing the problem based on the datatype reported in the error message output and the SQL statement on which the error occurred. If the error occurs within a stored procedure, an additional error message will be displayed showing the name of the stored procedure and the line number where the error occurred.
Increase the size of the variable that is causing the error. If it is in a procedure, re-create the procedure.
If this error occurs on a Sybase-supplied system stored procedure, contact Sybase Technical Support.
Versions in which this error is raised
Jul 24, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Error code
Hi Mike,
The error message "A communication error has occurred during the fax transmission" normally indicates that for some reason the fax call was interrupted or there was some interference on the telephone line during the fax transmission. Some possible interruption/interference on transmission(s) are:
1. the telephone line is not a dedicated fax line - there could be an extension which was inadvertently lifted/used during a fax call;
2. noisy/dirty telephone/fax line - corrosion on the terminal, joints, connectors, pins, plugs, jacks, telephone outlet or even on the provider's system. This could be determined by using the handset of the fax machine, dialing a single digit (to make the dialtone disappear) and listening to the phone's earpiece. There should be no crackling sound or static but a clean/dead air. In some cases where the telephone/fax line is shared with the DSL, then it could be the filter/splitter used;
3. some phone lines can still accept an incoming even though in use (call waiting) - the ringing of the 2nd call is more than enough interruption/interference;
4. RFI (radio frequency interference) - an electronic device that transmits a radio signal such as a two way radio, a WiFi router or mobile phone; and/or
5. noisy/dirty power AC mains -the outlet/AC power line where the fax device is plugged in has some other appliances/devices that draws power from it that can cause static/transients/spikes along the power line. Examples are water dispensers with built-in cooler/heater, dehumidifier, aircons, refrigerators and any other that switches itself on/off. A simple solution would be to use a different outlet and/or use a surge suppressor.
As to the "error code number 321*", pls post back the make and model of your fax device. Alternately, you can reference this site. If your fax machine/device is an HP brand (and/or the receiving end's fax machine is), pls check this link.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Office Equipment & Supplies
Bsod when i tried to install win2k
Error Message: PAGE_FAULT_IN_NONPAGED_AREA
Explanation:
This Stop message occurs when requested data is not found in memory. The system generates a fault, which normally indicates that the system looks for data in the paging file. In this circumstance, however, the missing data is identified as being located within an area of memory that cannot be paged out to disk. The system faults, but cannot find, the data and is unable to recover. Faulty hardware, a buggy system service, antivirus software, and a corrupted NTFS volume can all generate this type of error.
User Action:
This Stop message usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, either main memory, L2 RAM cache, or video RAM). If hardware has been added to the system recently, remove it to see if the error recurs. If existing hardware has failed, remove or replace the faulty component. Run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owners manual for your computer. Another cause of this Stop message is the installation of a buggy system service. Disable the service and determine if this resolves the error. If so, contact the manufacturer of the system service about a possible update. If the error occurs during system startup, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. At the resulting Windows 2000 Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time. Antivirus software can also trigger this Stop message. Disable the program and determine if this resolves the error. If it does, contact the manufacturer of the program about a possible update. A corrupted NTFS volume can also generate this Stop message. Run Chkdsk /f /r to detect and repair disk errors. Restart the system before the disk scan begins on a system partition. If the hard disk is SCSI, check for problems between the SCSI controller and the disk. Finally, check the System Log in Event Viewer for additional error messages that might help pinpoint the device or driver causing the error. Disabling memory caching of the BIOS might also resolve it. For more troubleshooting information about this Stop message, refer to the Microsoft Knowledge Base at http://support.microsoft.com/support.
Nov 20, 2007 | Microsoft Windows 2000 for PC
Installation of Canon Digital Camera Solution Disk. Ver.28.2
What version of Windows are you installing this on, or is it on a Mac?
Regardless, you can download an updated version of the software here:
http://tinyurl.com/22fgku
It's possible you have an outdated version that won't work with your OS, that's especially likely if you're running Vista. Or you could just have a corrupt version. Either way, the first thing to try is downloading the newest version for your OS and installing that. Let me know if you still get an error message when trying this (and what that error message is).
-Dyllan
Nov 17, 2007 | Canon PowerShot SD600 Digital Camera
Microsoft Office Professional 2007 Full Version for PC Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
