Question about Aurora Electronics AS890C Shredder
If I put the document in straight it won't shred. I can get it to shred if I insert it on the left hand side - there seems to be some kind of jam on the right hand side.
  • 37 Answers
Unplug it first. If you are certain that there is a jam, take the top off and flip it upside down. Use a pencil or other object that is NOT YOUR HAND and try to remove some of the paper jammed up. It is also possible that there is only a sensor on the left hand side. If this is the case there isn't much that you can do. Hope this helps and tell me how it works out!
Posted on Oct 07, 2010
Hi, I am having problems printing a Word document. When I press Print, it only prints two-thirds of the page. What am I doing wrong please?
Okay, the paperfeed at the top, on the left hand side there is a grey slide, (right in the printer) to hold the paper in place. Use it to keep the paper straight! It seems that if the paper goes in straight, the whole page is printed, if it doesn't it messes up the page.
Worked for other people having trouble with Epson Printers
Sep 15, 2011 | Epson Office Equipment & Supplies
My office Max OM01287 Shredder will only run in reverse. There appeared to be a jam in the cutters and with tiny tools and very careful grabbing I seem to have cleared the jam from tiny pieces of paper. ...
There is still a shred of paper jamming the microswitch that sets the shredder into reverse to avoid an even worse jam. Find that microswitch, usual;ly on the left or right side, activated by a plastic flap on the basket side of the shredder. Clear it. As you move the plastic flap up and down you should hear it click. No click, the switch is jammed.
Mar 12, 2011 | OfficeMax Office Equipment & Supplies
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
I have a Fellowes shredder P - 35C It will work in reverse but not inwards. I have left it for considerable time but still won't start up when I insert paper.
Unplug the shredder and check the shredding blades to be sure they are not jammed with paper. If paper is stuck in the blades, it will not function to add more paper to the jam. It WILL work in reverse to remove it's jam. Also make certain the blades have not been bent by discs, credit cards, or thick amounts of paper. If all looks well, blades are straight and not clogged with paper, be sure the door (if you have this type of machine) is closed properly. If not of this helps it run, you might need to have a professional look at it OR it might be time for a new shredder.
Oct 28, 2010 | Vacuums
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
I was shredding some old check books and jammed
Try soaking the clogs with hot soapy water overnight.
Soap disolves paper.
Dec 23, 2009 | Royal 160MX Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Replace rear turn signal bulb on 2007 H3 - driver side
1st::Unscrew the 2 screws that hold the light in.
2nd::Slide your hand behind the light and pull the light towards you. Make sure that you pull it straight, as if the h3 was driving away from you, so you dont break the two pins that are holding the light in...PULL ONE PIN AT A TIME!!!
Dont pull it to far away from the hummer as there are wires attached that need to stay attached.
3rd::turn the back of the bulb to unlock it from the lens...
4th:: slide the bulb out and remove thebulb by pulling it straight out.
5th::put the new bulb in, lock it back into the lens, then insert it back where you got it from,...
MAKE SURE you move the wires out of the way when you put the lens back in...they will get in the way and can be damaged.
Jan 10, 2009 | 2006 Hummer H3
How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Dec 04, 2008 | HP Office Equipment & Supplies
Aurora Electronics AS890C Shredder Logo
174 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
