Question about Hunter Dryers
Fan works intermitently, works for awhile then looses power. Doesen't matter what speed.. Model #20436. The fan worked fine for a few months before this problem developed. Thanks, Gary
    Genius:
  • 1,478 Answers
The blades of your fan may be bent or worn out, or perhaps, there is a partial contact on the wiring, i will advice you first check the wiring of the fan to ensure it is well attached to its connectors, if it is, it means the blades of the fan are worn out, you will need to replace the fan blade.
Take care.
Posted on Oct 07, 2010
The blower fan cuts out intermitently regardless of fan speed when I go over a bump or take a corner. The dash had been removed to replace the evaporator and this is when the problem started. When the fan...
From what you said I would think you have a bad/loose connection. I have never had to change the fan resistor but from what I under stand usually when the resistor is bad the fan only run with the fan speed on the highest setting. If the fan quits working try putting the fan on the highest speed setting, see if fan starts working. Sorry but that all I got for now.
Sep 10, 2017 | 1999 Buick Century
Blower does not activate when a/c mode but works fine without a/c
on your fan motor. red is low speed ,blue is med speed, black is high, red for heating . blue works good for cooling. black is high speed. re look where the forth speed was hooked up. put blue there.
Apr 16, 2010 | Honeywell L4064B2236 Fan/Limit Control...
I have a 1996 Jeep Cherokee Classic. My Tachometer, Fuel Gage, and Speedometer quit working a few months ago. The Oil pressure,and Temperature gages work fine. All fuses are fine. I suspect a grounging...
have you tried working on one problem at a time?
have you check the body computer for any codes?
and to also verify the bus line is ok.
if you find nothing wrong with BCM or bus,
try checking the speed sensor for an output signal or if the gear is bad.
Nov 18, 2009 | 1996 Jeep Cherokee Country
Heat/ac blower motor works on high. intermittent on other speeds.
Check the blower resistor pack - usually located in the heater air ducting in the blower fan airflow. Check for loose connections and open circuit resistors on the unit.
If speed 4 works always, its unlikely to be the blower motor ground connection.
Aug 10, 2009 | 2004 GMC Canyon
The climate control will not work properly ,,work intermitent .19
Blower motor control module probably , but without testing that's just a guess . Do you know how to do automotive electrical testing ? Testing B+ to the module ? Do you know where the module is ? You can find a wiring diagram here , http://www.bbbind.com/free_tsb.html There is a fuse for the blower motor in the I/P fuse box , HVAC blower 10amp ,
Mar 21, 2017 | 1995 Oldsmobile Aurora
Kenmore a/c window unit fan not kicking on with compressor.
Likely a bad motor, when this occurs verify the board is sending voltage to the motor.
May 30, 2017 | Kenmore Heating & Cooling
1996 A-4 Intermitent Heater Problem
may need a new heater matrix
Dec 15, 2008 | 1996 Audi A4
TV flickers intermitantly
loose con some where in the set very time consuming
Dec 03, 2008 | Televison & Video
Kenmore whispertone model 11620412003
I am getting suction to the power mate, but the mate doesn't
work. The belt seem fine, but the light and beater doesen.t
go on. Tried the reset - no result. Thanks
Dec 29, 2007 | Vacuums
Overheating
98% of what?
It's fine for a cpu to run at 98% of capacity, especially processing video files.
Nov 17, 2007 | Computers & Internet
Dryers Logo
27 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
