Question about RCA RCR-4258 Remote Control
Im trying to reprogram my remote and I know the code. But while I am holding down tv and I press 0 (the first number), the light flashes before I finish the code. I tried starting with other numbers, doesnt flash immediately after, only for 0. I tried new batteries, same thing. Is it fixable or is it time for a new one??
    Champion:
  • 226 Answers
Press and hold the component key (TV, SAT•CBL, DVD•VCR, DVR•AUX) you wish to program. The LED turns on and remains on.
Keep holding down the component key. If you release the component key any time during the Direct
Code Entry procedure, the LED blinks four times, and the process is exited. The last programmed code under the component key is retained
get the full manual for free including all codes HERE
Posted on Oct 07, 2010
Testimonial: "Found it in the manual Thanks for the link!"
The sky remote will not operate the volume on my grundig gu22dvd have tried all the usual things codes etc but still doesnt work
Try an auto search with the remote, you might have already tried it :
1. press tv
2. press select and the red button simultaneously untill the LED light flashes twice
3. Then keep pressing the TV and Standby buttons one after the other (not at same time) until the tv swithches off, then press select to store the code, the LED should flash twice to confirm this.
Once you have the remote working the TV, you can get the remote blink back the TV code so you can write it down for future reference.
  • Press the TV button on the Sky remote
  • Hold down Select and the Red buttons together for approximately two seconds until the LED blinks twice
  • Key in 9, 9, 0
  • Key in 1 on the numeric keypad and count the number of times the Red LED blinks. This is the 1st digit.
  • Repeat for 2 and 3
  • Note: no Blink = 0 (zero)
Sep 09, 2014 | Grundig GU22DVDPX 22 in. LCD TV
Have grundig gu22dvd tv and can not get volume on the sky remote have tried the normal things and have code but still doesn't work
1. press tv
  • Key in 9, 9, 0
Trying to program a direct tv remote to work with my 46" lcd, Vizio tv. Have tried the codes provided, but they don't show when I type them...not sure if actually being entered. Or, maybe have...
1 Vizio tv.code 0864 OR 10885 OR 11756OR 10178
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Oct 03, 2011 | Televison & Video
My 40" toshiba tv nexxtech
Please let me know if this works for you! would love positive feedback! if this doesnt work let me know as well will continue to help
toshiba codes are 0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
an to reprogram it you have to follow these directions if found from an online manual for this model
Turn on the device you wish to program the remote to, point the remote at the device and press the key for that particular device (TV, etc.) on the Nexxtech remote. For TVs combined with a VCR or DVD player, use the "TV" key, and for VCR/DVD combination units, both "VCR" and "DVD" will need to be set up if your particular remote offers both.
  • 2 Locate the code (or possible codes) for your brand and type of device in the list supplied with your remote. Press and hold "P" until the display light blinks twice and then enter the first code. The display light will blink with each digit and blink twice if the code was accepted; repeat using the next code if it was not. Press "Power" once the code was accepted to see if the device responds by shutting off. Repeat the steps for all the codes listed under that brand name.
  • 3 Search for a code if none of the listed codes were accepted or if you do not have the list by pressing the appropriate device key, pressing and holding "P" until the display light blinks twice and pressing "9-9-1." Press "Power" to see if the device responds, and press "CH+" to try more codes if it does not. Press "P" again to lock in the code when successful.
  • 4 Point the remote at a programmed device, press the device key, press and hold "P" until the light blinks twice and enter "9-9-0" to learn the code for that device. Press "1" to see the code for the first digit; count the number of blinks on the display light and write down that number. If the number is 0, the light will not blink at all. Repeat for the next three digits by pressing the number key for that digit (2 through 4).
  • 5 Press "9-9-2" after pressing "P" to reassign a device key if, for example, you have two DVD players and no VCR and want to program the "VCR" setting to the second DVD player. In this example, follow "9-9-2" by pressing "DVD" and then "VCR", and then program in the code for that device.
  • Mar 17, 2011 | Toshiba Televison & Video
    I lost my code sheet. how do i get a new one.
    Try to do this:
    Guide to Programming the Remote
    Follow these steps to program a device into your remote control. Thereare two ways to program your remote. If you already know the code foryour device, you can program it into your remote manually. If you donot know the code, you can use the code search function to program theremote control.
    Using Code Search:
    1. Turn on the device you want to program into the remote.
    2. Point your remote control at the device
    3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
    4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button toprogram the DVD player, etc. The light on the remote control willblink and stay on.
    5. Slowly press and release the power buttonrepeatedly until the device turns off. Each time you push the powerbutton the light should blink once.
    6. Press "Enter" to save the code into the remote and the light will turn off.
    Program a Manual Code:
    1. First turn on the device that you want to program such as your TV or DVD player.
    2. Point your remote control at the device.
    3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
    4. Press the "Code Search" button for about 3 seconds until the light stays on.
    5. Enter the code for your device using the number pad. The light willblink each time you push a button. If the code works, the light willturn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work,start from the beginning by holding down code search until the lightstays on and use a new code.
    6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
    Retrieving the Code for your Device:
    Ifyou used the code search function to program your device and want toknow the code for future reference, you can retrieve the code from theremote. To do this:
    1. Press and hold the Code Search for 3 seconds until the light stays on.
    2.Press the device button for the code you want to retrieve. Press TV toget the TV code, etc. The light will blink once and stay on.
    3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
    4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
    Programming the Sleep Setting:
    1. Press and hold the "SLEEP" button until the light stays on.
    2. Use the number pad to enter 2 digits for how many minutes to use forthe timer (01 to 99 minutes). The light will turn off and start timing.
    3. Make sure the remote is pointing at your device.
    4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
    SOURCE
    Sep 29, 2010 | Innovage Jumbo Remote Control
    I have urc-3220 one for all tv remote and a Emerson TV that it was once working for. Can't seem to get it to work, how do I reprogram it.
    EMERSON
    002 003 004 005 104 105 106 115 204 205 206 213 304 305 316 319
    405 502 505 506 519 604 605 705 804 805 903 904 905 906
    Follow these instructions carefully. These are as close as i can get you
    to getting you operations...the rest is up to you. GOOD LUCK!
    1. PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
    2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
    3. ENTER the 3 digit code for your brand.
    4. You should receive 2 quick flashes after entering your code.
    5. PRESS the POWER button to test the code.
    If you have tried all of the set-up codes for your brand of equipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
    1. PRESS the button for device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
    3. ENTER 9-9-1 (two blinks on the remote)
    4. ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
      Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
    5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
    Blinking Back the Code:
    1. PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
    3. PRESS 9 - 9 - 0.
    4. PRESS 1, carefully COUNT the number of blinks. (1st digit)
    5. PRESS 2, carefully COUNT the number of blinks. (2nd digit)
    6. PRESS 3, carefully COUNT the number of blinks. (3rd digit)
    If the remote DOES NOT blink it means the number is 0.
    This is your 3-digit setup code.
    Sep 12, 2009 | Emerson Televison & Video
    Whad code do i hse to control my sanyo dp19649 tv
    Hi! I will be more than glad to assist you in this concern. this are the tv codes for sanyo. 542, 589, 590, 591, 592,
    609. this is how to reprogram you remote to the sanyo tv. you need to press and hold the tv button that is on the upper portion of the remote, on the right side of the sat button. wait until all mode lights lit up, once all lights lit up, release it and then press number ex.. 542 then followed by the pound button, then you will see that the pound button will flash 3 times, it means that the code is program to the remote. note: while your doing the reprogramming of the remote you need to be in front of the tv about 2 to 3 feet away and the tv should be on.. granting u try all the code and none of them works.. try to scan the code of the tv by pressing and hold the tv button wait until all mode light lit up, then press 500 then pound, tv button will flash 3 times, lets say the last code is 500 and it did not work, press again the tv button and wait until all mode lights up, press on the re tv button if you have, but just incase u have only 1 red button for the power, press it once, then press the up button every 1 sec for 5mins. once the tv turn off then press the pound button and the tv button will flash 3 times, it means that you got the code for the sanyo tv, to check the code: Press the POUND (#) button twice. The mode button
    flashes the number for each digit of the device code, with a pause between the groups of flashes. A quick flash is for zero. For example, if the code is 570, the mode button flashes five times, pauses, flashes seven times, pauses, and flashes once quickly... lets say that this remote works before with the sanyo and suddenly it quit working , pls call 1-800-333-3474 and ask for the replacement for the dishnetwork remote, remote is bad. please feel free to get in touch if you have any query..
    Sep 07, 2009 | Televison & Video
    Need code for Directv remote for 26LG Flat Screen TV
    Program TV Code
    1. Turn on the TV.
    2. Locate the 5-digit code for your TV.
    3. Slide the MODE switch to the TV position.
    4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
    5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
    6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
    7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
    Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
    The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
    1. Turn on the component you wish to control (e.g. your DVD Player).
    2. Locate the 5-digit code for your component.
    3. Slide the MODE switch to the AV1 (or AV2) position.
    4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
    5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
    6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
    7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
    Satellite - 0
    TV - 1
    VCR/DVD - 2
    Verifying the Codes
    Jan 14, 2009 | Directv RC23 Remote Control
    Just changed batteries in universal remote don't know the code to reprogram the remote the inside says it's an rcr3273 with the numbers of r55lb5711p
    Make sure the device is on. Hold down the tv (or whichever device your trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly letting it flash until the device turns off. Then press the stop button...and it is programmed.
    Aug 19, 2008 | RCA Universal Remote Control
    Directv remote
    1) Use 2 new AA batteries in RC32 remote control;
    2) Slide mode switch to "TV";
    3) Press and hold the MUTE and SELECT keys at the same
    4) Enter 9-9-1-1.
    5) Press PWR button on TV.
    6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
    7) Use the CHAN- key to step back a code.
    8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
    9) To verify the code, slide the MODE switch to the appropriate position.
    10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
    11) Enter 9-9-0. (The green light under the selected
    12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
    13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
    To control TV volume from Directv RC32:
    flashes 4 times.)
    Feb 11, 2008 | Polaroid TLA-01511C 15 in. LCD Television
    RCA RCR-4258 Remote Control Logo
    226 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
