Question about Dell Inspiron Mini 10 Notebook
My computer turns on and then if i try to start it, it goes to a blue screen
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
The fatal blue screen occurs due to0 the OS issues.. So reinstall the OS... The mini computers dont have CD drive so use the following option
Dell has a default partition on the computer and you can install with the same..
If you have windows 7 on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you have windows Xp then you have to turn on the computer and when the dell logo appears you have to simultaneously press control and the F11key.. You will be able to reinstall the OS in this way..
If the restore option is not available then call up the tech support of dell(18006249896) they will replace the HDD to fix the issue
Posted on Oct 15, 2010
I have a compaq presario cq 60 to and when I turn it on it just sounds like it's going to start up and goes to a blank bluish black screen if I did it says the main screen and then it goes to that after I...
The blue screen typically would have a error message on it. I would recommend hitting the F8 key once a second after turning the computer on to get the windows diagnostic menu with choices such as safe mode. If you can select this then try a system restore point to when the computer was working properly. If you are unable to have it start up by hitting the F8 key then you either have a failing hard drive or a corrupt windows.
Dec 25, 2014 | Computers & Internet
Blue screen acer 5517
Boot into safe mode and use System Restore. You have to try several dates.
Aug 28, 2012 | Acer Aspire 5517-5671 15.6" Wifi 1.6ghz...
Starts up then goes to a blue screen
This happens to old computers after time. Start your computer up several times, and if you still get a blue screen, try formatting your hard drive.
Jul 17, 2012 | Dell Latitude D610 Notebook
My emachine laptop has a virus. When you turn it on it goes to black screen with the option to start recovery mangement or start windows.When pressing either,it goes to black screen for a little bit then...
You may have files that you want to keep that you saved on your hard drive, but if you haven't backed them up then you will have to lose them because the only thing you can do to fix this is use the factory recovery disk which will wipe your hard drive clean.Just put the disc into the disc tray and you should get an option to start the recovery disc when you turn on the computer, it will tell you to press a key to start it which might be f3 or something different, I'm am not sure what key but when you have done that you should be able to start the recovery and wipe the hard drive clean and it should solve your problem
Oct 29, 2011 | E-Machines eMachines Desktop PC
My computer won't turn on and it goes to a black screen with words and then i click start windows normally and it goes to a blue screen then stops, how do i get it to turn on?
The blue screen states that it has a hardware error. Usually the problem is in the memory card. All you have to do is open your computer (cpu) and removed the memory card. Try to blow the memory slot and try to clean the memory card pins with a clean cloth and return it back to the memory slot. After that try to turn it on if it works. If not, try to replace the memory card if you have a spare.
Aside from memory card problem is the hardisk problem but usually rare. Try the memory step first before the hardisk step.
Jan 03, 2010 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Laptop Will Not Boot
chose start windows normaly
Apr 14, 2009 | Acer Aspire One PC Notebook
Only have a blue screen on starting up iBOOK G4
Hello
It looks like you have a hardware related problem. have you tried anything since? I would guess that the hard drive is dead. Tell me if I'm wrong!
Mar 25, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
Computer wont go past a blue error screen
Your hard drive may have quit(died). No good solution other than replace the hard drive. Do you have a restore disk for you computer, to use after replacign the HD?
Here is the website for Acer PC
Dec 19, 2008 | Acer Computers & Internet
Blue error screen when starting up computer
looks like a OS software problem on reboot try pressing F8 and choose last good known configuration
if that fails to do the trick
This option will put your comp back to how it was when you bought is so all you saved stuff will be lost
press contrl and F12 together on boot up this will restart pc as it was when bought new
Aug 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Wont let me log in
I think the blue screen you are reffering to is the blue screen of death. This happens when a serious failure occurs. Your OS's system files may have got corrupted and that would be the reason for this. Try reinstalling Windows.
If the problem persists, get your Ram memory checked by a technician.
May 13, 2008 | HP Pavilion zd8000 Notebook
Dell Inspiron Mini 10 Notebook Logo
99 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
