The fabric conditioner drawer stays full of water and wont drain. Ive cleaned it thoroughly?
    Scholar:
  • 78 Answers
There should be a drain tube, or something like that, inside the machine that goes to the drawer that may be clogged.
Please rate, and write testimonial if you feel the need to, if this was helpful.
Good Luck
cookieMonster
Posted on Oct 07, 2010
  • David Seilhan Oct 16, 2010
    To add to this solution.
    After think out it there is a switch that should activate the fabric softener dispenser at a certain point in the washing. This switch may be bad or stuck.
Excell 7 VarioPerfect: fabric conditioner compartment will not drain
perhaps you need to contact Bosch website for tech support
Sep 21, 2016 | Bosch Washing Machines
Why does the fabric conditioner compartment stay full of water after wash has finished ?
The compartment has to be flushed to prevent conditioner residue from hardening and clogging it.
Apr 16, 2016 | Washing Machines
Bosch maxx 1000 - when finished cycle, leaves central fabric conditioner drawer full of water + trace of condtioner.
Check that the hose that connects the drawer to the tub is clean, fabric conditioner normally gunks up especially on colder wash cycles.
Apr 01, 2015 | Bosch Washing Machines
Fabric tray does not clear
Usually means soap dispensing drawer needs to be cleaned, as conditioner is dispensed by syphoning system, Take out soap detergent drawer, clean thoroughly in warm water, make sure drain hole in conditioner compartment is clear.
Nov 20, 2011 | Washing Machines
Kenmore electric range gets a f1/f3 error code
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 10, 2010 | Kenmore Slider/Casement Air Conditioner
Drawer not emptying
Suggest you pull the drawer right out and look for the hole in the bottom of the drawer where the conditioner is meant to drain out.
The top of this hole whould have a removable cover over it. What normally happens is that the inside of this cover gets choked with old conditioner.
Take the cover off and give the whole thing a really thorough clean with hot water and an old toothbrush.
A.
Apr 30, 2010 | Tricity Bendix AW1000W Front Load Washer
The conditioner part is always full of water and does not take down any fabric condtioner that is put in. Have cleaned drawer an inside but does not work.
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. Use a pipe cleaner, cotton buds or piece of coiled curtain wire to ensure that the U shaped pipe is clear of obstruction. Pull it back and forward to dislodge any accumulated fabric conditioner. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. A good idea is to slightly water down fab con concentrate as it will eventually clog up the dispenser. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Oct 18, 2009 | Bosch Washing Machines
Washing power drawer, the fabric softner section
Pull the drawer out as far as it will come and then grasping it firmly, give it a good tug towards you, this will free the drawer to enable you to thoroughly clean every piece of it, particularly the conditioner parts of it.
Get a piece of wire with a bend on the end, and poke it in to all the holes in the top of the dispenser compartment, this will clera any blockages there.
Plz rate my solution, and feel free to leave any comment.
Thanks.
Jan 09, 2009 | Indesit W 123 Front Load Washer
The fabric softener drawer is half full of water which does not drain away, even after the washing machine has finished. The detergent drawer is fine. how can I drain this water away? Kind...
Remove drawer and thoroughly clean, you must have a blockage in it for the water to remain.
Make sure that you clean every piece of it, taking all the components out.
Please leave feedback.
Nov 30, 2008 | Siemens WM5487A Front Load Washer
Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
Nov 03, 2008 | Miele W865 Front Load Washer
Washing Machines Logo
151 people viewed this question
Top Washing Machines Experts
