Question about Hayward Pro Series 18" Above Ground Pool Sand Filter System with Pump
We have a customer with a Weather King AC installed 2009 - who installed unit and is it under warranty Model # 13AJL24A01 Ser 7666W310903314 respond to chedges@crossfieldheating.com Thank you
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
How do I find out if my unit is still under warranty?
All you need to do is copy down the model and serial number and call the local weather king rep or even a dealer and they can tell you. Most units have a minimum of 5 year compressor warranty and 1 year on parts. Many units have 10 year compressor warranty and 5 year parts. It would be worth your while to check. Hope this helps.
Jun 24, 2011 | Weather King 12AJA4801AH Air Conditioner
Weather king #10PJA3101 /serial #6811 M1903 10232 from 1993. Needs a new compressor is it still under warranty?
Hi, I am sorry to say that the compressor on a new unit comes with a factory warranty of only 1 year. You can purchase a extended warranty of an extra 4 years, but you have to do that of the time you bought the unit.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration, Contractor
Jul 04, 2010 | Weather King 10AJA3601AH Air Conditioner
When turning on central air, our main electrical breaker is tripping. This is a brand new home barely over 1 year old. Should the AC have a warranty not covered by a builders contract??
Builders give a one year warranty but your air conditioner has five years on all parts. Anything outside the unit is not covered under the ac warranty. Breakers,stopped up drain and dirty coils.
Jun 09, 2009 | Weather King 10AJA6001AH Air Conditioner
What is your oponion of a Weather King Unit ? I am looking to purchase a 3 1/2 ton condenser unit. Weather King is the best price so far. I will install it myself
I installed Whethe king ,Goodman ,Philco,Intertherm condensing units and there's no much difference in prices and the quality is the same ,just choose the one with better warranty.But if you want to expend more money the next one will be a Rheem or Ruud unit ,and after that you have more expensive and more complicated units like Lenoxx or Trane but those have more electronic parts that can brake and they very expensive to fix.I'm in this business for a long time and if ineed to get a new one i'll go for a standar price one with a good warranty.
May 01, 2009 | Weather King 10AJA6001AH Air Conditioner
KING FURNACE MANUAL
You do not need a warranty card for your warranty to be valid. Your installing contractor provides the labor warranty and the factory provides the warranty on parts. All the necessary information to make a (parts) warranty claim is embedded in the serial number of your unit. As for a manual you should contact the installing company or visit the Weatherking (Rheem) site to request this information. www.weatherking.com
Mar 26, 2009 | Weather King 12AJA4801AH Air Conditioner
Warranty and repair
call the company that installed the unit first. if they wont pony up any reputable hvac service company can honor the warranty. the manufacturer will give him a free compressor and you will have to pay him labor to install it.
Jun 12, 2008 | Weather King 10AJA4801AH Air Conditioner
Warranty on compressor
The actual age of your unit can be determined by the serial number. Based on the age indicated there they can tell you if the warranty is still valid. Your local Rheem/weather king dealer can do this for you. Most compressor warranties are either 5 or 10 years. Good Luck!
Jun 11, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King contact info
479-648-4900 is the main line to the factory in Fort Smith Ar. Hope this helps, RepairUSA
Sep 03, 2007 | Weather King 10AJA6001AH Air Conditioner
Hayward Pro Series 18" Above Ground Pool Sand Filter System with Pump Logo
85 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
