Question about Indesit 24 in. D61 Free-standing Dishwasher
Indesit D61D Sticks In Its Cycle
Please help! 3 year old Indesit D61D stated to stick. Set on program 2 then when the controller reaches about 4 o'clock it just stays there with the dishwasher just washing away continuessly. Can cure it by manually advancing the switch, but normally we set it going last thing at night and I don't want it washing all night! Washing still seems good and it gets up to temperature fine. Any Ideas ??
  • Anonymous Jun 03, 2008
    I have the same problem on my DG6100W. I removed the panel but there is no obvious place to grease the dial. There is only a "lump" of electronics behind the cycle dial so I stopped at this point. Excuse my ingnorace but is liquid wrench a similar thing to WD40 i.e would WD40 do?
    Desperate Housewife!!!
  • calanga Aug 24, 2008
    I have the same problem with an Indesit D 61 P dishwasher. I tried the suggested solution, using a silicone spray, since I couldn't find liquid wrench on the local market, but that did not solve the problem. How can I find the part number to replace the faulty part and where in Nelspruit (or elsewhere in Mpumalanga province) can I buy the part? I live in Mozambique and the shop where the dishwasher was bought does not carry spares or provide technical assistance. I would be really grateful for any advice.
    FC, Maputo
The repair can be done yourself you need to first purchas a can of liquid wrench with extention. and first shut off power or disconnect power. there is a acess panal that you need to remove to get at gears to grease once it is greased you will need to turn the dial a couple of times (powerless) and replace the panel and plug or turn on power (when you are turning the knob besure to return to the start cycle ) if you need more info please email me kcord44@yahoo.com thank you and good luck
Posted on May 31, 2008
My motherboard cant see the 512 ram
sometimes, the apg card video ram, especially with ati rage cards, takes away from the maximum visible system ram on 815 chipsets- which is normally right at 512mb. the motherboard also might be limited on what archetecture of ram is being used. i believe an 815 ram controller an only recognize 4 ram banks at once, each bank being a side of as stick . if you have 3 double sided sticks, the first 2 may be occupying your ram controller (2 sticksx2sides=4), leaving no room for the third. those old boards are real picky about ram sticks, some just arent compatible.
try changing your video card, try using single sided ram sticks, or just plain different ram sticks.
Jan 31, 2011 | Gigabyte GA-6OX Motherboard
Won't recognize all my ram
Clear the CMOS with the jumper, and download the latest BIOS file for your motherboard. Make sure DUAL channel is not enabled.
Jan 25, 2010 | VIA Asus A8V Socket 939 Motherboard -...
New ram makes my pc freeze
Many motherboards when booting from dual sockets wish for ram either of same manufactuer or same capacity per stick
Jan 14, 2009 | Biostar GEFORCE 6100-M9 Motherboard
2x 512mb sticks
Are you using an older AMD processor? older socket 939 AMD processors had the memory controllers built into the chip and tended to be a bit wonky with RAM. If you have 4 Ram slots check to see if they are different colors and try to insert the RAM into every other slot matching the colors.
Aug 03, 2017 | Compaq Presario 2580US Notebook
DE73 A04 Error code
you may have a bad heating element..or temperature sensor the water temperture is not getting hot enough to let the dishwasher run. you my reset it and try running the water in the sink until it reaches hot ... then try stating the dishwasher...let me know if this helps
Aug 28, 2007 | Indesit 24 in. DE73 Evolution...
Indesit D61D
the solenoid has gone you will need to replace the soap unit. meaning panel off of door and removing unit.
Jan 13, 2007 | Indesit 24 in. D61 Free-standing...
Permanent emptying on Indesit D61D Dishwasher
tilt it back the base is flooded have some towels to mop up the excess water then you are away again
Oct 01, 2006 | Indesit 24 in. D61 Free-standing...
Indesit D61D tripping RCD
the heater is faulty(shorted) and check that the hot water is getting to the appliance as the buzzing is the soliniod being powered but the water is not passing through
Aug 15, 2006 | Maytag 24 in. MDB8600AW Jetclean II...
Indesit D61D getting stuck
hi yes, well done! you fixed the problem by yourself now all you got to do is change the element buy a new 1 for this specific model and switch them a little more work then a light bulb switch good luck
Mar 26, 2006 | Indesit 24 in. D61 Free-standing...
Indesit 24 in. D61 Free-standing Dishwasher Logo
720 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
