Question about Epson Stylus 1400 InkJet Photo Printer
My Epson 1400 printer head is on the far right side, and the printer will not turn on. I can not get to the cartridges, can I remove the cover? and How? Yes,I have checked all connections and power source. Pat DIACCA Topp
  • ctopp83 Oct 07, 2010
    The solution I was sent won't work, because I cannot move the print head, it is tucked under the right side of the main cover. I did get it on, but it ran the cleaning and then tucked it back under the cover where I can't get to it. It registers that I have no ink. I tried force, to move the head, but it is locked somehow. Thanks, Clarence Topp
    Brigadier General:
  • 3,513 Answers
Please check the bellow link if it helps:-
http://files.support.epson.com/pdf/pho140/pho140pg.pdf
http://www.vtechplace.com/manual-instructions/epson-printer/epson-1390-1400/guide-to-install-df-model-ciss-for-epson-1390-1400-printer.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 07, 2010
My epsonr230x cartridge is moving abnormally. it moves and hurts right side inside the printer. pls solution...
Epson printers have a lock to keep the print heads/carts over on the right side. The lock can get stuck and covered in ink. There is a lever under the edge of the heads that should unlock the carriage so you can get to the "cleaning station" under the heads. Unplug the printer while the heads are moving, and you may be able to move them over and clean. Often the bar the heads run on can be lubricated with light oil, like what you use on a sewing machine, too.
Nov 02, 2014 | Epson STYLUS R230 InkJet Photo Printer
How can I open cartridge holder on my epson stylus photo 1400. It's stuck over on the right and red lights are flashing.
Turn on printer, and unplug power chord while the carriage moving.
Then move carriage by hand freely.
Sep 02, 2014 | Epson Stylus 1400 InkJet Photo Printer
Epson printer error codes
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Sep 01, 2014 | Epson Stylus DX6050 All-In-One InkJet...
Remove cartridge cover on Epson 1400
you can download the manual for your printer here: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Pages 46 through 52 should detailed steps on how to chenage an ink cartridge. The top of page 51 shows you how to remove the cartridge cover.
Dec 29, 2009 | Epson Stylus Photo 1400 Printer
How can i remove the ribbon cartridge of EPSON LX-300+ii?
open the top cover and pull up the cartridge if ribbon stock near head pull properly...........
Oct 09, 2009 | Epson Dot Matrix LX-300+ II Printer
Can not change ink for epson c 91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head carriage to replacement position.
Jun 21, 2009 | Epson Stylus Photo 1400 Printer
Epson 1400 Printer Banding and color issues.
Try to print without high speed. If it's ok, you need to head alignment both black and colour.
May 26, 2009 | Epson Stylus Photo 1400 Printer
Cant change ink cartridge on my Epson C91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head by hand to replacement position.
May 02, 2009 | Epson Stylus Photo 1400 Printer
1400 carriage
if the printer power light is off and the paper and ink light are flashing there are a few things you can try.
1. remove all paper from the printer.
2. lift cover and check for paper jam
3. check to see that the ink cartridge cover is completley closed. (the covers do actually pop themselves open and jam)
if none of these fix your problem then your in the hands of epson tech support. they can be reached @ 562-276-7282
May 12, 2008 | Epson Stylus 1400 InkJet Photo Printer
Cartridge dock malfunction?
I answered a similar question 5 mins ago
It sounds as though your print head got jammed and did not resturn to its 'parking place'
Open the cover and look at the printing head (where the ink sits).
Is it located to the very far right or is a couple of inches out from the right?
If it is out, gently push it back to the right as far as it will go, then power it back on, it should do all of its checks as normal and the head will move a few times, but it should return to the far right and then be ready for printing.
Check there is no paper jammed anywhere and reload any paper.
Try to print again
Does it now work??
Apr 06, 2008 | Epson Stylus C48 InkJet Printer
Epson Stylus  1400 InkJet Photo Printer Logo
386 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
