Question about Avery Wizard for PC
My labels will not print in the designated boxes. They used to with my last printer Now I have a HP Offcejet Pro - is that the problem?
    Genius:
  • 1,478 Answers
Hrllo,
you will need to read and digest the manual of you hp office jet pro to get how you can set the features to print in the designated boxes, all you need is the settings on your printer.
Take care.
Posted on Oct 07, 2010
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
Mar 15, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
I have stomper X64024 labels. What do I need to print CD labels using my HP 8500A printer? Thanx
you need to install the stomper software, the stomper package should have come with a free link to downoad the printer software. you may also be able to print if you can pull up the template in your printer software, but I doubt that. best bet is to use the stomper software., its free
Feb 21, 2011 | StompSoft CD Stomper Pro Labeling
Avery design pro will not print with my HP C5500
I found an odd workaround. Probably a better one available, but this worked for me. When you select Print from Design Pro, in the printer drop down box select Microsoft XPS Document Writer instead of your printer. Click OK, enter a file name, and save. That will save a .xps file. Next, open the .xps file and print it.
Dec 13, 2009 | HP Photosmart C5580 All-In-One InkJet...
Smart LabelPrinter Seiko 440
The code between the labels indicates either you are using labels designed for another model or that it is thinking it has a shippinhg label opr some lareger type installed. IT is more likely to be the first option, you are usinjg the wrong coded labels
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | Seiko Smart Label Printer Pro Thermal
C6180 will not print labels as set out in the avery template. will bunch up as they go down sheet
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
  • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
    1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
    2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
Lexmark won't print on Avery labels
The printer is expecting the label stock to be loaded into the manual feed tray, not the regular paper tray. If it does not sense anything in the manual feed tray it will not continue. If you are loading the stock in the tray, it may need to be pushed further into the try to trigger the sensor.
Jul 05, 2009 | HP LaserJet 4650 Color Printer
Please help. Printer not printing. Urgently...!!!
Sounds like you chose print to file for the port in the driver instead of what it should be set for. comm for serial cables. lpt1 for parallel, usb for usb. by having it set the way you do it is told to save the code. goto printers and faxes and right click on the zdesigner print driver and chose properties. then click the ports tab and chose the correct port.
Jul 02, 2009 | Zebra S4M Thermal Label Printer
Read and print .DAT files on labels
you must embed ZPL/CPCL or EPL command to your program.. or use Zebra Designer Pro then connect the .DAT file to it and design your sticker..
Mar 20, 2009 | Zebra 105SL Thermal Label Printer
Printing directly onto CD's/DVD's
try and use the watermark setting to put your logo on the print but not in the print
the same as when you see draft, copy on the page under the print
May 24, 2017 | HP Officejet Pro L7680 All-In-One Printer
Avery Wizard for PC Logo
95 people viewed this question
Top Avery Computers & Internet Experts
Donna Sander
Joseph Coppeto
Joseph Coppeto
Are you an Avery Computer and Internet Expert? Answer questions, earn points and help others
