Question about Ovens
I need a element - Ovens
    Genius:
  • 1,478 Answers
I will advice you check ebay.com
Posted on Oct 07, 2010
Why won't the lower element heat?
DID U TEST THE NEW ELEMENT B4 TRYING IT? U MIGHT BE SURPRISE. OTHER WISE I WOULD D SAY CHECK THE WIRING AND CONNECTIONS IF ITS NOT WORKING, CHECK FOR VOLTAGE AT THE CONNECTORS?
1.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Jun 25, 2015 | Ovens
After autoclean the oven elements don't work
the broil element
The bake element
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
Jul 24, 2014 | Whirlpool Ovens
How much would it costs to replace heating element on Whirlpool gas oven.
I would not replace the elements just yet it may be ur oven safety valve, u can test the elements with a multi meter for continuity and ohms..
THINGS TO CHECK:
the broil element
The bake element
Jul 15, 2014 | Whirlpool Ovens
No elements working on kenmore range
THINGS TO CHECK:
the broil element
The bake element
Apr 17, 2014 | Frigidaire Ovens
Oven
THINGS TO CHECK:
the broil element
The bake element
Apr 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore md3 both elements stopped working at same time
the broil element
The bake element
Mar 15, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Oven element is sparking
you have a short and need to check it ASAP SHOULD BE ABLE TO VISUALLY INSPECT IT
the broil element
The bake element
Mar 12, 2014 | Frigidaire FGB24S5A Gas Single Oven
Oven element
The bake element
THINGS TO CHECK:
the broil element
Feb 15, 2014 | Frigidaire Ovens
Frigidaire elements oven will not ignite
the broil element
The bake element
Feb 05, 2014 | Frigidaire Ovens
Oven elements warm but do not get hot.
whats the resistance on the elements, how many watts are they?
make sure all wires are good, could have one broke about half way. you will need to check the resistance on the elements. you need to actually check the volts and use whats its closer to 240/220 you will have to find out the ohms so you know the element will get hot. if all the wiring is good start with the elements, you need w/v will tell you the amps. e/i will give you ohms, just use the equations in the pic to figure out what you need to know. it as to have enough resistance to get hot
Mar 29, 2017 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
