Question about Kenmore Elite 45986 Front Load Washer
02 F with a beep comes up and the water does not drain out. What is it?
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
The "F02" on your model of washer indicates the machine has detected a fault or obstruction in the drain process.
The same error as the "F21" on the later model Kenmore/Whirlpool units.
Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, although the faulty pump can`t be ruled out...yet.
Here`s how to check it and clean it...
Though it being full of water may make it messy. A wet-dry shop vac is handy in this situation.
If it is in a position that allows you too lean it back against something strong or a second set of hands it will help if tilted back almost all the way.
Careful not to hurt the machine or yourself, and undo the fill hoses and drain hose.
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
( If the problem still exist`s the "F02" will re-appear. If so you`ll need to check the hose/rubber bellows from pump to tub...back-flow ball...for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a couple hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
**NOTE: if this still fails to remedy the F02 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc.
**This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
b0ac102.jpg02 F with a beep comes up and the water does not - 02d1e9d.jpgan> 02d1e9d.jpg
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Posted on Oct 07, 2010
Why does my kennmore smartwash elite keeps beeping and fashing f 02 signal
Your drain pump can't drain all the water, so your drain pump has a cap on it to clean out the filter. Clean the filter and try again, if this code comes back, replace the pump. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 17, 2014 | Washing Machines
Washer is flashing a signal of 02 F and beeping
F02:
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes • Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Why does my whilpool duet washer flash F2: Its holding water and beeping.
First please verify this is a f2 and not a fo2 error
they mean almost the same thing i have it listed below
F/02 Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Beeping and flashing 02 F Whirlpool front load washer
here is a website with your code as shown below
This will help you out
http://www.applianceaid.com/duet_washer.html
Sep 01, 2010 | Kitchen Ranges
During wash cycle it stops and beeps, then f 02 scrolls on screen
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 29, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer he3t- beeping F02
"F/02"
Long Drain
Feb 13, 2010 | Kenmore Washing Machines
Wash stops, beeping, flashing F and 02
I'll just take a swing at this one, without model number.............F-02 is typically a Whirlpool error code for " slow drain". If this is a Kenmore or Whirlpool front loader, pull off the bottom panel and check the pump filter, (pump should be right up front, turn counter-clock-wise to remove filter) clear of any debris, check hose from tub to pump as well. NOTE! If there is water in the machine, it will pour out of the pump, first remove the water either with a wet-vac, or just do it very slowly and carefully at the pump, draining the water into a pan.
Apr 21, 2009 | Washing Machines
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops during middle of cycle and post 02 F
f 02 is the error code for taking too long to drain the water disconnect power remove 3 torex 20 screws from lower front panel revove cap from pump asm to check for any obstructions beware there will be water in the pump
Dec 15, 2008 | Whirlpool GHW9100L Front Load Washer
Error message f 09 and f 02
remove bottom panel..reach up from bottom to door lock area pull down on small tab hanging there door will release ..dip all the water out you can ..shop vac will help..remove the knob on front of pump have towels handy clean pump trap ck pump impeller for obstructions reassemble and ck if problem persists may be loose impeller on pump
Aug 27, 2008 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
223 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
