Question about Zanussi FLA1201W Front Load Washer
Zanussi FLA 1201 w. The program stops on 'G' position and water continually pumps through.
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Zanussi FLA 1001W does NOT spin
You need to check the brushes in the motor first, replace if less than 3 or 4mm long.
If brushes o/k, then could be a module or motor problem, apart from the belt being broken or worn of course.
Hope this helps.
Posted on Jan 23, 2010
Zanussi ZSF6161 dishwasher. the program starts, I can hear some water being moved around then it stops. All happens in the first minute. There is no error code, it just humms it's way down to the end of...
Maybe a clogged pump. Take the pump a part and clean the filters and inside the pump. Check to see if there is food jammed in the hoses while you are at it.
Oct 31, 2013 | Zanussi Dishwashers
I have a Whirlpool 1200 Spin AWM 1201 Washing Machine. There is a funny smell coming from it like suage. Also sometimes there is water on the floor after its use. We have checked the pipe going outside and...
The smell is a build up of bacteria which can be flushed out to help/ The leakage could be a few things a hose , pump or door boot seal ,a small rip in this you need to check further....
Feb 22, 2011 | Whirlpool Washing Machines
Machine stops half way through program
One looses touch with all the codes available, but normally if washer stops mid cycle its due to a blocked or faulty drain pump. OR incomming water is to slow or defective inlet sensor. Switch off and start from the beginning. See if you can get machine to drain by moving the timer etc. If not, rectify pump problem. Take note where in the cycle the problem arises.
Jul 21, 2010 | Zanussi ZWD1680W Front Load Washer / Dryer
Does not empty the water and does not rinse or spin
Need to remove pump to open and check what is sticking in the impellar. Check pipes for blockages. Also check pump motor by itself. reassemble and retry.
Jun 06, 2010 | Zanussi FLA1101W Front Load Washer
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Hope this helps.
Jan 23, 2010 | Zanussi FLA1001W Front Load Washer
Washing machine: water level is high
PRESSURE MAY HAVE KINK OR DEFECTIVE
Nov 22, 2008 | Washing Machines
Zanussi FLA 1001W washing machine - Programme selector dial
you can buy a new indicator as a spare - quite cheap. best souyrce would be service force - assuming you are in uk, its in the phone book
Feb 07, 2008 | Zanussi FLA1001W Front Load Washer
Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Aug 01, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FLA1201W Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
