Question about iLO MP3 Player
My ilo mp3 player has always worked fine. now all of a sudden its not able to download the device driver and my computer is not detecting the mp3 player when plugged into the usb port
  • 10,421 Answers
Problem with mp3 player
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
Jan 06, 2009 | Jwin MP3 Player
Ilo mp3 player
Reset it , restart your computer, and try again
Apr 23, 2008 | iLO (2 GB) MP3 Player
Ilo mp3 player
what is the model and brand of the mp3 player?
if when you plug the device to the pc, the device ask you for a mode, you could try some option called transfer mode.. that way the pc could detect the device as some sort of pendrive...
Mar 11, 2008 | Audio Players & Recorders
Ilo 1gb mp3 player
install the ilo driver cd that came with your ilo. Because you never know, not all ilo mp3 players have the same software.
Thats just my opinion, hopefully it works
Dec 30, 2007 | iLO MP3 Player
Not detected by computer - cannot recharge battery
yay I found a solution! so I kept getting the error about an MTP device, so I did a big search. I am running vista on a 32 bit processor. what you need to download is the MTP installation programme from windows. so click on http://support.microsoft.com/kb/939211
and then just select what processor speed you need. should do the trick! I also downloaded http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en initially, but it didn't appear to work. hope that you all get to the bottom of this frustrating problem :)
Dec 18, 2007 | Samsung YP-U3 MP3 Player
Ilo mp3 driver
I had the same problem but on different computers, home works great, office won't detect it.
Try using some other computer just to see if it the players fault.
I am loving my ilo, but its just day 2 so hope it stays good
pwatson
Dec 13, 2007 | iLO MP3 Player
Ilo mp3 driver
I have windows vista...when I try to download the cd in order to use my mp3 player. It says to download a newer version of start up cd.....however the site it takes me to says my version on my windows vista is 'newer' than the download and I cannot find the 'newest version'
Dec 11, 2007 | iLO (2 GB) MP3 Player
ILo 1GB MP3 player.
Whenever I try to download music and I plug in my mp3 player, it always says, "It is not possible to to change the sync settings at this time. Please try again later." I try again later and it still doesn't work. I am using Windows Media Player and I can't do it on iTunes. What do I do?
Oct 17, 2007 | iLO MP3 Player
Ilo mp3 player
ummm did you FIRST install the drivers? I have one, and you FIRST have to install the drivers, some MP3s are already supported by windows by default, but this ones requires it's own drivers!
Oct 13, 2007 | iLO (2 GB) MP3 Player
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
