Question about AMD Athlon XP 2600+, 2.13 GHz (AXDA2600DKV3C) OEM / Unboxed Processor
Install oem driver how to make usb flash drive as bootable drive when installation windows xp(f6 button)....how to solve this problems because of my laptop need to install this driver(problem detected=0x000007B)
2 Suggested Answers
  • 11 Answers
SOURCE: Lite on DVD Combo disk read failure
You could take the drive out of the encloser and hook it up. There could be a flaw in the enclouser ive had that happen before to me. I just took it out and put it in standard if this dosent work then there is a flaw in the dvd burner
Posted on Jul 21, 2009
Keep getting 0x0000007b (0xf78d2524, 0xc0000034, 0x00000000,
So, where did you get the Windows XP drivers for the controller? Are you sure that they are XP compatible?
Is the USB floppy even being recognized and read by the setup program?
The Windows Setup program only supports a handful of USB drives for F6 driver installation method, that is explained here:
A connected USB floppy disk drive does not work when you press F6 to install mass storage drivers during the Windows XP installation process
Adding the standard Microsoft USB storage drivers to the txtsetup.oem file on the floppy diskette usually resolves this problem, see here: http://www.intel.com/support/motherboards/server/sb/CS-026606.htm
Adding the USB floppy's vendor ID should also fix the problem, see here for an example:
http://blog.mreza.info/archive/2007/09/19/windows-f6-driver-and-usb-floppy.aspx
None of my business but why not use Windows 7 on the new laptop, instead of going through all this trouble installing an operating system that is 10 years old and that is living on borrowed time?
Jan 19, 2013 | Dell OptiPlex 330 Desktop Desktop Computer...
I have a emachine netbook and it say no bootable device
Failed hard drive (assuming one is installed), or could be that it has "lost" the Windows installation.
Possibly a virus, you need to reinstall windows, or hopefully, repair the installation
To do this, as this does not appear to have a DVD rom, you will need the following:
  1. A legit copy of windows (whichever is installed currently)
  2. A spare computer or preferably an external USB DVD Drive (if the latter, skip to the end)
  3. The SATA drivers for this laptop (essential if using windows xp, may not need if vista)
  4. a USB pendrive of at least 4 GB
  5. A USB Floppy drive (possibly)
  6. a copy of win to flash
http://wintoflash.com/home/en/
Uisng the spare computer, extract the contents of the Windows disc to a folder on the spare computers hard drive. Run win to flash and follow the instructions, it will build a boot copy of windows on the pendrive that you specify (it will format the pendrive also).
Copy the sata drivers to the USB floppy drive (you might get away with copying them to the same usb bootable you have just made but I doubt it)
Now, in the bios, set 1st boot to USB drive
Then boot and install, when you reach the F6 prompt, point it to the usb floppy drive and let if find the sata textmode drivers.
Its hould then find your existing windows installation and repair it
IF you ahve a USB DVD / CDROM drive, ignore the above and just install from that, you may need to use a floppy usb to install the sata drivers though
Feb 08, 2011 | Acer eMachines eM2501162 Netbook
I have laptop hp compaq 6710b, it cannot boot completely, when i run HDD diagnosis from setup it passes the three tests successfully,if i boot it with a bootable winxp cd to repair OS, it indicates that...
The hard disk on your laptop is a SATA, which a generic XP install disk doesn't support. You will either have to create a custom XP install disk by adding to it the required drivers as explained here
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
or you could load them to an USB stick and when prompted by the install to load external drivers from A you could reassign the A to the USB and load them from there.
Mar 23, 2010 | HP Compaq 6710b Notebook
Need a password
Dear i have send some instruction of need a password.
please follow the instructions.
and you receive a password.
Thanks.
1. Download a free demo version of Windows Key (to reset a "Demo12345" password for a trial) or buy an instant download online (to reset an unknown password)
2. Run the downloaded file to install Windows Key. You can install Windows Key on any PC you have access to
3. At the end of the installation process enable the "Run Windows Key" check-box and click the "Finish" button. Windows Key will be launched automatically
4. Create a password reset CD, USB Flash drive or a driver floppy following the instructions below:
Using a Windows Key bootable CD 1. Click the "CD image" link
2. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. The file is usually located in the 'I386' folder of the Windows Setup CD. Click "Next" (Don't have any Windows Setup CD? Request a Windows Key .ISO download)
3. Enter you name and set your own password for the bootable CD (you may set an empty password). Click "Next"
4. WindowsKey.iso file is created
5. Insert a blank CD, specify your burning drive from the list and click "Next"
6. Windows Key password reset CD is ready
What should I do next?
7. Reboot your system with this CD
8. Windows Setup process starts
9. After all the required files are loaded from the bootable CD, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable CD
Continue to step 14*
Using a Windows Key bootable USB Flash Drive 1. Click the "USB Flash Drive" link
2. Connect a blank USB Flash Drive. Click "Next"
3. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. Click "Next" (Don't have any Windows Setup CD? Request { /iso-request.htm } a Windows Key .ISO download)
4. Enter you name and set your own password for the bootable USB Flash Drive (you may set an empty password). Click "Next"
5. Windows Key password reset USB Drive is ready
6. Reboot your system with this USB Drive. To reboot your PC with USB Flash Drive you may need to set the following options for the BIOS Setup Utility: after rebooting your PC please press "Del" or "F2" to run BIOS Setup Utility, go to the "Boot" section and press "F6" to move the "Hard Drive" device up, press "Enter" on the "Hard Drive" option and press "F6" to move the "USB Drive" device up. After all the changes are set please press "F10" to exit and save the settings
7. Windows Setup process starts
8. After all the required files are loaded from the USB Drive, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable USB Flash Drive
Using a Windows Key driver floppy 1. Click the "driver floppy" link
2. Insert a blank floppy into the floppy drive and click "Next"
3. Enter you name and set your own password for the driver floppy (you may set an empty password). Click "Next"
4. Windows Key creates three files on the floppy: winkey.sys, winkey.inf and textsetup.oem. The driver floppy is ready What should I do next?
5. Insert Windows Setup CD or bootable floppy and reboot your PC
6. Windows Setup blue screen appears
7. Press "F6" when Windows Setup prompts for additional drivers at the bottom line of the blue screen
8. Windows Setup continues loading required files from the bootable CD or floppies
9. Windows Setup prompts you to press "S" to specify additional drivers. Press "S" and insert the Windows Key driver floppy
10. Press "Enter" to specify the "Windows Key" driver
11. Windows Setup loads the files from the floppy drive
12. Windows Setup continues loading the files from the Setup CD or prompts you to continue with the rest of the bootable floppies
13. After all the required files are loaded from the Setup CD or bootable floppies, Windows Key starts working. It displays your license info and asks to enter the password that you set for the driver floppy
Boot Mode 14. Please enter the password that you have set for the Windows Key bootable media
15. Select the Windows installation to be unlocked
16. Windows Key asks: "Undo Windows Key changes? (Y/N)". Press "N" if you want to reset the password or "Y" if you want to leave the original passwords and cancel the program changes
17. Select the account to reset the password for
18. Windows Key asks: "Reset 'account_name' password? (Y/N)". Press "Y" to reset the password or "N" to leave the original password
19. Windows Key asks: "Reset password for another account? (Y/N)". Press "Y" to reset password for another account or "N" to quit Windows Key
20. Remove the Windows Key bootable media and restart your PC.
Mar 02, 2010 | Computers & Internet
Need to install sata driver on hp dc7100 windows xp sp3
Drive a:\ refers to a floppy drive, if you have not got a floppy drive in the laptop then i suggest that you borrow or purchase a USB one, they are not expensive !!!
When you have got a USB floppy drive all you have to do is format a floppy disk in the FAT file system and copy the drivers to the floppy disk.
Plug the floppy disk in the machine that you want to install XP on, start the install as you normally would and look at the bottom of the screen for where it says "press F6 to install third party drivers" and hit F6 as soon as you see that prompt, let it get to the stage where it displays your drive and it should pick up the SATA drive you have in the machine and install windows.
Post back if you need any more help or advice.
Good luck.
Jul 27, 2009 | Toshiba Laptop Keyboard for Satellite L10,...
Unable to install XP in CQ60-104tu compaq Presario
You may find that if you insert a blank CD instead of DVD you have more luck (the image you have created is a CD image not a DVD image). Another tip is that you should not copy the ISO image to CD but using Nero burn image to disk. Let me know if you need more help.
Jun 09, 2009 | Computers & Internet
Asus P4S800D-X mobo and sata hdd problem
I believe you need to load in the SiS 180 RAID controller for this MOBO during the Windows Install.
Do this by loading the driver onto a floppy and pressing F6 when told to do so by the windows install.
Mar 20, 2009 | ASUS P4S800D-X Motherboard
Unable to install XP on my laptop cq60-104tu
Disable SATA in Bios and reinstall windows XP
Mar 08, 2009 | Computers & Internet
AMD Athlon XP 2600+, 2.13 GHz (AXDA2600DKV3C) OEM / Unboxed Processor Logo
227 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
