Question about Epson Aculaser C1100 Printer
BLACK TONER The printer is saying to change the black toner but when I do it you can not clip in the black toner correctly. Please help.
    Scholar:
  • 187 Answers
I assume the new toner is the same brand/model as the previous one? If you still have the previous one, can you compare them for size/fittings etc?
Posted on May 29, 2008
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
Printer is saying black toner is out but i just replaced it with a brand new one from Staples
I've been having this problem and it turns out (and here's that bit that makes me look stupid) that I had been supplied with the imaging unit and not the toner cartridge so you may wish to check you've changed what it is you think you've changed. Toner carts are the top row, image units the middle and waste on the bottom.)
Aug 05, 2010 | Konica Minolta magicolor 4650DN Laser...
Stopped printing needs black toner
I guess that you does not use a genuin cartridge
Mar 15, 2010 | HP LaserJet 2820 Printer
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
I have a C3530 MFP and it won't print because it says check toner cartridge black. Toner Sensor Error
Hi
Thanks for using FixYa. Toner sensor error is related to the agitator inside the toner cartridge, it occasionally falls out of its housing so it does not move the toner sensor which is the white plastic piece that moves up and down on the coloured handle, the toner sensors themselves see this white flag if it doesn’t move then the printer thinks the sensor is broken so toner sensor error is flagged and if the flag moves too quickly the machine thinks the toner is empty. To resolve the issue your printer is facing with please check that toner lock lever is in position and follow the following procedure---
Press the cover release and open the printer’s top cover fully. Make sure the Toner Cartridge in question is correctly positioned and the right hand clip is pushed back. While holding it by its top centre, lift the image drum, complete with its toner cartridge, up and out of the printer. On the Right hand side of the toner look for a sensor patch, make sure this is not dirty. If it is dirty clean it with a soft object such as cotton wool. Now look inside the printer opposite to where the sensor patch would sit. There is a black square with a sensor located inside and check that this is not dirty. Now replace the drum and toner, and close the printer cover. Try to print a test page and it will start printing normally.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2009 | OKI C3530N Color MFP Printer
Toner needs black toner how do i replace just the black toner
You shoulh have a button to rotate the carousel, or unplug the power cord and try again.
Mar 03, 2009 | Epson Aculaser C1100 Printer
Black Cartridge just changed, but still says K-toner low
The only way to clear the message is to wait until the the display shows XXXX Toner Out, then change the cartridge and the message will clear itself.
May 18, 2008 | Epson AcuLaser C4000 Printer
543k toner sensor error
Your indication regarding the 100% does not necessarily indicate a damaged chip (sensor).
Many chips do not work by actually sensing the toner but by usage or other tricks.
We cannot be sure about what happened but replacing the drum and affected items
should solve the problem. Needed parts may be found at
http://www.inkfilling.com/toner-refill-OkiData--C5800Ldn.html
Jan 21, 2008 | OKI C5800dn Laser Printer
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
32 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
