Question about Toshiba TEC B-SX4 Thermal Label Printer
The RIBBON is not being saved on the front Roller after the Label prints
    Champion:
  • 254 Answers
You need to have the option installed and activated in the parameters of the printer. It's not standard on BSX4 printers
then in the driver choose optimisation.
Posted on Aug 05, 2011
How to clean the print head
No easy way to clean the print head. You will need to remove it from the printer to gain access to the area to clean. What does the label look like on the disc? Streaks is probably a dirty print head. If sections of the label are missing it could be the print head or heat roller. Look at the re-transfer (clear) ribbon. If the missing part of the label is left on the ribbon you have a heat roller issue.
Mar 12, 2013 | Rimage Everest II Printer
Intermec PX4i label printer. Paper/Ribbon loaded correctly, but ribbon is 'rippled' meaning barcode label being printed has white lines across it. Any ideas?
Ribbon Wrinkle as it called can be caused due to the main feed rollers (that touch the ribbon or the label) being slightly worn. Even if you have a sligh gradient on the roller(s) it will pull ever so slightly to one side. If you need the parts then please do not hesitate to contavct me. Jack Woodworth - Codeo UK, 01179064587
Oct 19, 2011 | Intermec PX4I Label Printer
I keep getting wrinkled ribbon in my zebra XiIII printers Part seems to be caused by static, the ribbon will not rewind properly
Its probably not static. 1. Wipe the print head and platen roller with alcohol dampened qtip or lint free cloth. Print about 30 labels while gently pressing on the ribbon supply, causing it to drag a little and observe if the wrinkles stop. If so tighten the nut on the end of the ribbon supply a little at a time until wrinkles disappear. Check the head pressure toggles on top of the print head and make sure they are adjusted about the same. If you have been printing a lot of the same size labels, check the platen roller (white) at the point where the right edge of the label rides on it for a slight offset where the roller is worn down. If it is worn, the only fix is to replace the platen roller.
Feb 17, 2011 | Zebra Xi Series 170XiIII Thermal Label...
My ribbon roller couldn't roll that suppose to be and now the ribbon keep rolling out. (front Roller)
Check that you are in thermal transfer mode and not in Direct thermal.
The motors are active only if you are in Thermal transfer
May 20, 2010 | Toshiba TEC B-472 Thermal Label Printer
Why does the label wrap around the bar every other label I print?
possible becouse the tear off position stop the gap on the wrong spot and wen you cut the label, left some label with glue expose, and wen you send other print, the printer make the backfeed and the label go stuck on the white rollar.
go througt the setings to TEAR OFF, and ajust to the front or back, untill hav the best gap/label rest possition and cut proply. don't forget to save (press setup button twice)
May 10, 2010 | Zebra Z4Mplus Label Printer
How to make change to print on thermal paper
On the front panel of the printer:
Press SETUP/EXIT
Press NEXT/SAVE until you see a setting call PRINT METHOD
Change the setting from THERMAL TRANS to DIRECT
Press SETUP/EXIT
Press NEXT/SAVE to make a permanent save
Hope that helps.
Apr 16, 2010 | Zebra 105SL Thermal Label Printer
Printer is paused alert ribbon out, but we don't use a ribbon
Sounds like you're just in the wrong printing mode. Go into your front panel setup and search until you see
PRINT METHOD:
THERMAL TRANSFER.
Press the arrow buttons until it says DIRECT THERMAL, then save and exit.
Apr 05, 2010 | Zebra S4M Thermal Label Printer
Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Mar 27, 2009 | Zebra Z4M Printer
Toshiba TEC B-SX4 Thermal Label Printer Logo
74 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
CheckitRight
CheckitRight
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
