Question about Kitchen Ranges
I have a ruud PVP40F hot water heater, it is not working keeps showing a 2 flash then 3 flash lockout condition. I have replaced the Flammable Vapor Sensor, but it still will not work what can I try next
  • 2976 Answers
SOURCE: ECO failure. Replaced the gas control thermostat & vapor sensor
It sounds like your gas/air mixture needs to be adjusted. The flame should have just the slightest amount of white, at the very tip. The rest should be evenly blue. There is an air vent adjustment in the line to the burner, right after the gas input.
Posted on Sep 03, 2009
  • 9 Answers
SOURCE: .After spraying my dog with
Yes the sensor got wet & your pilot lite is probably out from the water
Posted on Oct 04, 2010
SOURCE: I have a GPVH 40 100 AO smith hot water heater.The
AO smith manuals
http://www.hotwater.com/lit/im/r-gas.html
GPVH series manual
http://www.hotwater.com/lit/im/res_gas/315465-000.pdf
You can search the manual for FV
The FV sensor shorted because it detected flammable gas
Quote manual:
Flammable liquids (such as
gasoline, solvents, propane (LP or butane, etc.) and other substances
(such as adhesives, etc.) emit flammable vapors which can be ignited
by a gas water heater's hot surface igniter or main burner. The
resulting flashback and fire can cause death or serious burns to anyone
in the area. This water is equipped with a FV sensor for detecting the
presence of flammable vapors, see Figure 3. When the sensor detects
those vapors, the unit will shut down and not operate. Should this
happen, please refer to the troubleshooting guide on pages 28-30.
Troubleshoot step 14-15 says
replace the FV sensor
call tech assistance number that shows on water heater
AO Smith will refer you to a plumber
I don't believe homeowner can buy these parts due to Federal regulations
The shorted FV sensor probably saved you a flash-over
The cost of 2nd degree burns from a flash-over would be astronomical.
Fortunately you're ok, and the other folk in the room are ok.
In the old days.
Two guys I knew, winter 1978 Chicago, were laying VA tile using the black mastic.
They were killed and the house burned down because of the water heater.
Main office marked the event with a memo saying they still owed money on their account.
The only company with a re-settable FVIR that I'm aware right now is Bradford White
http://www.thetankatwaterheaterrescue.com/forums/forum3/2679.html
http://411plumb.com/bradford-white-defender-water-heater-review
Bradford White Defender FVIR is resettable without buying parts.
Posted on Oct 25, 2010
SOURCE: Rheem tankless water heater. Takes
Before calling service technician, open following link for Rheem tankless resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Since you don't have error code, the problem might be simple plumbing problem.
The following information could help isolate the problem(s).
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Low-hot-water-pressure.html
Posted on Jul 11, 2011
  • 5245 Answers
SOURCE: hot water heater womt light, flammable vapor sensor code
Most likely: Combustion chamber got too hot because air intake is clogged with dust, causing less air to flow upward through vent pipe ... the slowed flow of air caused combustion chamber to overheat.
What brand and model water heater?
Look at label on side of unit and add comment.
Otherwise call service tech to repair/ replace water heater and clean arrestor screen (air intake) and replace or reset parts as needed, depending on model number and brand water heater.
AO Smith, Bradford white, and Rheem are main manufacturers.
Each has slightly different repair protocol, and each gas control valve can also be different. So more information is needed.
Identify gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Rheem TRD/ FVIR glass vial
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
How to remove combustion parts to inspect for Rheem glass vial and clean arrestor screen located under combustion chamber:
http://waterheatertimer.org/How-to-replace-thermocouple.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Oct 01, 2012
GE hot water heater pilot will not lught
Bad gas control valve.
Low gas pressure.
Bad themocouple
FV lockout caused by overheated combustion chamber due to flammable vapor, poor venting, or clogged air intake
Clean air intake located on bottom of heater.
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
Copy following link for troubleshoot by type of gas control
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment with results.
Oct 13, 2012 | Water Heaters
Detecting gas and won't light
Open following link for troubleshoot error codes showing 7 flashes on Honeywell gas control valve is system lockout due to flammable vapor:
http://waterheatertimer.org/pdf/Honeywell-gas-control_error-Damper-series.pdf
The FV system in Rheem can be tripped by presence of flammable vapors such as gasoline or paint fumes etc, or it can be tripped if water heater was dropped, or mis-manufactured, or if gas control valve is defective, or if water heater is not getting adequate fresh air, or there is inadequate venting of combustion by-product.
When combustion chamber overheats, then glass vial breaks and damper shuts off air supply to water heater and it will not light.
Open following link for possible help fixing the problem:
Jun 13, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Is there a reset button for a 6G50NVH-FV-02 hot water heater
Depends on gas control valve, and if cause is overheating high-limit event or FVIR flammable vapor event.
Turn off water heater when using flammable vapors, clean burner parts to prevent overheating.
1) GSW Residential power vent gas water heater with FVIR system:
Some models have intelli-vent gas contol
Others have robershaw gas control with auto-reset
2) Parts manual shows #15 'auto-reset' high limit switch on the blower
http://www.gswpartsonline.com/model/27484
http://www.gswpartsonline.com/schematic/137/view
3) Possible manual:
http://www.gsw-wh.com/pdfs/GPD135NInstall.pdf
Shows resettable lockout page 15
Water temperature must be 120 degree F or lower for reset. Unplug power cord, and then plug back in and wait 15 minutes or 60 minutes depending on gas control valve.
Some intelli-vent controls must be replaced when 195 degree high limit event locks out the water heater.
If high-limit lockout repeats, then gas control must be replaced.
Also clean burner parts, air intake, and make sure flame is clear blue. and not yellow-or-orange.
4) Intelli-vent service manual might apply to your water heater:
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
If FVIR flammable vapor event locked out heater, then unplug heater and plug back in.
Immediately press two temperature buttons. Wait for green light to blink. Release buttons.
Page 34 in troubleshoot chart.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 31, 2011 | Fasco GSW Hot Water Heater Exhaust Draft...
Whilpool hot water will not light
Unknown if this is new heater, or heater that worked before.
1) New heater: more information is needed about installation, type of gas valve, and what you have tried so far.
2) Heater that stopped working:
Manual is good start point, and then add a comment with which type of heater you have and what you have tried so far:
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
Problem can be simple or complex: dirty combustion parts and tubes; thermocouple is bad if gas control valve is not-electronic type; bad gas control valve thermostat; overheating tripped ECO because of bad thermostat or dirty burner parts; lockout due to FV event and exposure to flammable vapors; air in gas line need to be bled off; overly hot environment needs better ventilation; bad air supply because air intake needs cleaning; bad venting or downdraft or tight house needs ventilation; deteriorated burner parts need replacement because of moisture leak or exposure to chemicals; etc.
Open following link for some troubleshoot resources and illustrations and more reading.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 12, 2011 | Water Heaters
My water heater say i have flammable vapors present and is locked out how can i reset it or fix it there are no vapors present
Contact Rheem
http://www.rheem.com/Contact.aspx
1 800 432 8373
Locate product information on label on side of tank.
Typical manuals say if lockout occurs, then refer to gas valve codes and/or troubleshoot section:
http://globalimageserver.com/fetchDocument.aspx?id=a92c7d0e-8a95-48ba-8810-cd714f33d47a
http://globalimageserver.com/fetchDocument.aspx?id=80b1d50e-695f-49ac-9aae-3e9489ef1e5a
For example the manual says:
1. Verify no gasoline or flammable
vapors are present
2. Reset control using ON/OFF switch
on the gas control valve
3. Replace the flammable vapor sensor
http://waterheatertimer.org/images/Wiper-FVSensor-100.jpg
http://waterheatertimer.org/pdf/Rheem-Parts-Guide.pdf
http://waterheatertimer.org/pdf/Rheem-parts-list.pdf
Aug 11, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light will not stay lit on GE 40 gal. gas water heater tank
You have tank-type gas water heater:
Gas water heaters need working thermocouple, adequate incoming fresh combustion air with no trace amounts of chemical, open vent to outside that drafts poison combustion product upward, clean burner tubes and combustion parts, correct gas pressure with no air in line, working gas control valve thermostat, no lockout condition such as tripped ECO caused by runaway heating and dirty combustion parts, and no lockout condition such as exposure to flammable vapors.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
Jul 30, 2011 | General Electric Water Heaters
Hot water heater pilot is off. It's not gas,
Open following link to watch thermocouple replacement.
Make sure new thermocouple sits into pilot flame. Instructions for relighting water heater are usually printed on side of tank.
http://www.youtube.com/watch?v=v0aBPsNg6vo
Jul 29, 2011 | Whirlpool Water Heaters
I have a rheem w/h Md 42vp50pf. It heats my shop floor through the radiant heat tubes. I noticed the shop was getting cold so I checked on it. The pump was on circulating water but the pipes are cold. The...
Similar 42vp50 direct vent product appears on following link:
http://www.rheem.com/product.aspx?id=C24E3F52-A6A4-4BC7-AF5B-0DF23A7A0263
sample manual for power vent series:
http://globalimageserver.com/fetchDocument.aspx?id=c0471d58-5e59-4be6-96f7-68361b8fb515
Manual has troubleshoot section:
If this is combustion-shut-off or FVIR or flammable vapor event, then manual says to call qualified technician.
Service call is certainly less expensive than any fire or injury caused by fire.
Other brands of water heater, for example Bradford White, have customer-resettable FVIR on some models.
Another thing that can be causing problems is air intake, especially in dirty environment like a shop, or if shop chemicals are being inhaled by burner. Burner parts are susceptible to chemicals in trace amounts below odor threshold. You might need fresh air intake for water heater, and air intake needs to be cleaned.
'System lockout' shows on troubleshoot page 32:
1. Gas supply is off or too low to operate.
2. Hot surface ignitor not positioned correctly.
3. Low voltage to the water heater.
4. Electric polarity to unit is incorrect - test and correct.
5. Combustion shut-off device tripped, contact service
agency.
Rheem phone number: 1-800-432-8373
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 31, 2011 | Rheem Water Heaters
I have a GPVH 40 100 AO smith hot water heater.The FV (flammable vapor) sensor has been setoff from us painting the floor yesterday. How do I reset the unit?
AO smith manuals
GPVH series manual
Quote manual:
In the old days.
Oct 24, 2010 | Water Heaters
Hosed basement floor. soaked flamable vapor sensor. Removed and dried sensor. control now in lockout. How do you get control out of lockout???
    Certain Rheem water gas water heater models feature electronic controls with a flammable vapor sensor installed on the bottom portion of the water heater unit. This sensor is designed to shut off your water heater system to prevent fires in case flammable vapors are present within the area. If your flammable vapor sensor caused your water heater to shut down, check the area immediately for leaking gas or other flammable products. Common household chemicals such as bleach can also trip the safety system as well as unsuccessful burner ignition attempts.
    White Rodgers Intelli-Vent PowerVent Control Equipped Models
  1. Step 1 Turn the water heater's blower switch off and disconnect the power cord for the water heater (refer to your particular model's operation guide for the exact location of the blower switch). Disconnect the Molex connector attached to the bottom of the control pad (the left most connector with five pins).
  2. Step 2 Turn on your multi-meter and set it to read resistance or "ohms". Connect one of the multi-meter's probes to the number two pin and the other probe to the number three pin of the Molex connector (middle black wires). If the reading on your multi-meter reads below 9k or above 45k ohms, the flammable vapor sensor is faulty and in need of replacement; you cannot reset the system until this issue is resolved.
  3. Step 3 Reconnect the Molex connector to the bottom of the control pad, reconnect the water heater's power if and turn the blower switch to the "ON" position. Press both the left and right buttons on the control pad at the same time. Wait for the green light on the control pad to blink and press the following buttons in sequence: Left, Right, Left, Left, Right, Left, Right, Right (you will need to perform these actions within 30 seconds of reconnecting the power cord to the water heater in order to be successful).
Jul 23, 2010 | Rheem Water Heaters
Kitchen Ranges Logo
192 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
